Question about Packard Bell AudioDream MP3 Player
AudioDream only plays 1e file
When i want to change to the second song my AudioDream shuts down power and restarts, then it replays the first song...i dont wanna keep listening to the first song :( help? i got version 2.511.302
2 Suggested Answers
  • 10 Answers
SOURCE: lost manual, cannot operate audiodream
Here's a link to some online documentation for that player (I couldn't find a link to download the manual itself):
http://support.packardbell.com/uk/item/index.php?m=home&i=platform_audiodream&dhepn=C040370000
Posted on Dec 30, 2008
Does the Eclipse Fit Clip Plus have resume play functions?
I have just discovered that if you pause the player and then let it shut off on its own then press pause again later to wake up the unit and again it will pick up where you were. Now, I don't know if it uses any battery life when it's sleeping so will just have to experiment there. But the key here seems to be NOT actually turning it off. Turning it off will reset it to song #1 every single time. Which is really obnoxious.
Feb 01, 2015 | Eclipse Fit Clip Plus 8GB* MP3 Player
How do I get it to play the entire song?
Its because the songs are set to shuffle every 10 seconds. Click on a song (any song will do) hit pause so it stops playing. Click on the gear icon at the top right of the screen. Scroll down the list to "Advanced" then make sure "Replay Interva" is set at 1. If it already is I would contact Visual Land Support witch can be found here: http://www.visual-land.com/support_form.html
Mar 09, 2012 | Visual Land V-Touch Digital Media Player
Files coming up Invalid, and it shuts down when I go to delete, and only about half the songs are showing up on the mp3 player but can be played when attached the computer.
it shuts down may be because of virus you may scan it and cure it and some songs may be of any other file format which don't work in ur device so you may change the format ! ! !!
Dec 23, 2009 | Element Electronics Zr-Element Digital...
Pokemon platinum restarts with action replay have removed some cheats, still nothing
Yep. One or more of the Action Replay cheats you have enabled is making it shut down. Just edit/fix them or disable them.
May 13, 2009 | Nintendo DS Console
My mp3 player is constantly skipping during songs
just replay it over or you probably have the wrong type of mp3 player to fit your song
Apr 02, 2009 | RCA Pearl TH1102 MP3 Player
Won't turn on
Tetasonja40 , your problem may be the same as some of the other players. IF you don't have a license in the music you are copying the player loads it and it is visible but will not play and may even lock up the unit that it will blink on then when you hit play it shuts off or the light remains on but solid and will not play. Try removing the songs one at a time till the offending file releases the unit. I spent hours resovling this on other units. another problem that occurs is the players stop recognizing mp3 files for replay. converting them to a wma may resolve this problem.
Jan 31, 2009 | Coby MP-C883 MP3 Player
Uploading songs onto the Missil flashMP3 player
Drivers required only for Win98. Other versions on Windows have drivers installed. Plug usb cord into PC and into Missil Player. Open my computer, removable disk which is the Missil player) and file where desired music is. Drag music from storage file to "removable disk in "my computer". Treat it as a hard drive copy to, delete or format. To continue playing where you left off when restarting, hold off/pause button down for 3 seconds before shutting off.
Dec 29, 2008 | Aiwa HZ-WS2000 MP3 Player
Element mp3 will not play longer than 20 seconds of each song
Best Solution!!! I called tech support (866-823-1671 - very nice/helpful) because my daughter's was doing the same thing. I was told to let the song start to play, press the M button during the song, choose 'Repeat' which will bring up a list of options and then choose 'Normal'. It worked.
Dec 23, 2008 | Element Electronics Zr-Element Digital...
Songs wont change
It is stuck on "Repeat One" - refer to p.23 of your user's manual -
You can set your player to play music tracks randomly (Shuffle All ) or repeatedly (Repeat One or
Repeat All ).
1. From the main menu, select Settings > Play mode.
2. Use the VERTICAL TOUCH STRIP to scroll up or down the options.
3. Press § to select an option.
4. Press § again to deselect an option.
While you are playing music you can see the following active play mode screen.
-Tha Mp3 Doctor
Oct 30, 2007 | Philips HDD1630 MP3 Player
Playback
Hi Vitt, There are two ways to switch off the AudioDream, the power switch or holding the Menu button for 5-6 seconds. When the power switch is used changes in the settings are not saved to memory. After changing settings always power down the AudioDream by pressing the Menu button. This will save the changes you made. Have a good one! El Duderino
Nov 17, 2006 | Packard Bell AudioDream MP3 Player
Packard Bell AudioDream MP3 Player Logo
Top Packard Bell Audio Players & Recorders Experts
David
David
Henry  Thomas
Henry Thomas
SHIVAJI YADAV
SHIVAJI YADAV
Are you a Packard Bell Audio Player and Recorder Expert? Answer questions, earn points and help others
