Question about Honeywell Programmable Thermostat Heater
Wiring a thermostat
How do I wire a RTH6300B thermostat i only have 2 wires 1 W and 1 R
  • bdmocklin Jul 06, 2008
    6 wires 5 connections
  • 148 Answers
What kind of system are you hooking it to? heat pump or heat/ac?
Posted on Mar 08, 2008
  • TERRI RODDEN
    TERRI RODDEN Mar 08, 2008
    there should be a jumper on the terminal between the R and Rc .. leave in place .. if this is not a heat pump .. connect the W to the W and the R to the R.
Rheem Heat Pump Thermostat Replacement (#41-20804-15)
you need a 2 stage heat and cool t-stat hunter t-stat is not 2 stage
I’m happy to help further over the phone at https://www.6ya.com/expert/vincent_f7b7c5f4dedd2565
Feb 19, 2013 | Heating & Cooling
Hi I honeywell,rth63oo b electronics thermo stat how do o change the accuracy from + - 1% to + - 3% Thankx
The following are the two manuals for ths product, I looked briefly and didn't see an answer to your wuestion. If you want to change the number of degrees between heating and cooling operation from 1 to 3 degress that can be found in the operating manual, under programming. 69-1723 - RTH6300B - Programmable Thermostat Operating Manual
69-1717 - RTH6300B Programmable Thermostat Installation Guide
Jul 20, 2010 | Heating & Cooling
Honeywell RTH6300B to replace Trane Baystat 239
Sad to say but you have bought an non compatible thermostat, what you need is a thermostat that has "Heat Pump" somewhere on the package, Honeywell makes those also in the same models, sometimes they can be tricky if your not looking. It should also say 2heat, 1cool too. Hope this helps and good luck!
May 23, 2010 | Honeywell Focus 6300B 5-2 Days...
I'm replacing an old thermostat with a new Honeywell RTH6300B programmable. I have propane heat and central AC. My old thermostat has a black, a red and a yellow leads with no ID on the old thermostat wall...
Open up the propane furnace and see what color wires are hooked to the gas valve or circuit board. If it has a circuit board, note which color is on the R terminal and W terminal, Connect the the thermostat the same way. Most likely the yellow wire powers your A/C so you can hook that one to the Y terminal.
Nov 27, 2009 | Honeywell Programmable Thermostat Heater
I am replacing old 220 volt thermostat with a programable 220 volt thermostat. There are 6 wires in the box. (3 black & 3 red) There are only two black wires on the new thermostat. On the old...
Hi, this can be confusing. Be sure you have the power off before you wire it, but first you have to have an elect meter. The 6 wires in the box you will only use 2 of them. Cap the other 4 off. Use the 2 that have the correct voltage across them, 208, 220, 240 volts. The new stat is only set up for 2 hot wires 120 each. That will do it. Not to bad. be careful! Use care. Good Luck, Sincerely,
Shastalaker7
Nov 08, 2009 | Heating & Cooling
Rewire an old 2 wire thermostat to a honeywell 5-1-1 programmable
I connected the blue wire to the R and the white wire to the W on the old thermostat and shoved the new Honeywell 5-1-1 Day programmable thermostat up the first guys *** that i ran into at Canadian Tire
Thanks for your help
Dec 28, 2008 | Honeywell Electronic Programmable...
RTH6300B - Not blowing the hot air
I currently have a 2 wire system. I have one red and one white. I hooked the red to the R and the white to the W. I had to go into the system setup using the UP arrow button and the FAN button. The first setting is the 1 setting, and I selected number 2 ( Heating Only ). Then the 5 setting. I selected number 1 ( Gas/oil steam or gravity system ). Then 14 is usually 0 for Fahrenheit. I was just messing around and that is the buttons I used and I tested it. The furnace kicked on and then 10 to 15 secs later the air began to blow through the vents. I hope this works for others who read this.
May 03, 2008 | Honeywell Focus 6300B 5-2 Days...
Wiring a thermostat
your red wire will go to the R, RC, or RH terminal on the stat does'nt matter which one ,this is the wire that provides 24 volt from the furnace. the white wire will connect to the W terminal on the stat. If there is a jumper wire that came on the stat going from RC to RH leave it on.
Mar 08, 2008 | Honeywell Electronic Programmable...
Honeywell 5+2 day programmable thermostat will keep heating to 29 degrees!
Is sounds like you wired it correctly, The black is a little unusual perhaps its blue, anyway, try disconnecting the wires from the thermostat and see if it shuts off. If so, then it may need to re calibrated. I will need some more info to help you anymore.
Dec 03, 2007 | Honeywell CT3200 5-2 Day Electronic...
Heating & Cooling Logo
242 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
