My Magnavox model19prc10121 has a communication issue. When you plug it in the screen comes on but it will not shut off or respond in any way from the control panel or the remote. The only way to shut it off is to unplug it from the wall. When you plug it back in it will come on but will not respond.
SOURCE: tv has an advertisement that wont go off
Press the up and down volume buttons on the TV at the same time. This will turn off demo mode.
SOURCE: Magnavox TR2510C101
Pressing the volume up and volume
down buttons on the set simultaneously should work.
Good Luck.
SOURCE: the TV does not respond to the remote control nor the buttons in the front panel
i am haveng the same problem p58h10nja
waynejman, I have the same exact problem, can you tell me what your outcome was?
SOURCE: only vizio light come on then nothing. have to unplug to turn off
there a problem on power side.. chage the ic and the resistor going to ic and check also the signal diode.
I am having the same problem with my Insignia. I believe my preschooler may have pressed some combination of buttons since she was the last one to use the television. The television does not respond to any controls, either directly on the tv or via the remote. To shut off the television, I have to unplug it. Several other sites have suggested either pressing the "display" button repeatedly or to hold it down. These suggestions did not work!
3-1-09 i have the same problem with my insgnia. i used it last night turned it off and this morning it would not respond.
ARE THE VOLUME AND CHANNEL BUTTONS WORKING ? IF THEY ARE AND THE POWER IS JUST STUCK ON THEN IT IS PROBABLY A BAD RELAY.
DON.
