Question about SanDisk Sansa e250 MP3 Player
Red Circle with a white dash to the left of the battery status icon
What does it mean and how do we correct the problem?
Red Dot with dash means that your subscription (Rhapsody) has expired and there may be music that cannot be played on your player. A green dot signifies subscription OK
Posted on Mar 19, 2008
How do i turn on touch pad
You probably have a Synaptics Touchpad. What you have to do is look for the Synaptics logo(it's like a white circle on a red background) in your status bar(lower right corner of the scree, neer the clock). Double click that icon. A window called Mouse properties appears. The last tab is Device settings that also has the Synaptics Icon. If you click it you should see a list of all Synaptics devices on your laptop. Since you only have one you will only have one item in the list. Double click that item and a new Properties window will open. You have a list on the left side of that window. Select tapping and make sure Enable tapping is Checked. That should be it.Good Luck!
Nov 16, 2011 | Compaq (153515-001) Touch Pad
How do i turn on the flash?
On the menu there should be an icon that looks like a yellow lightning bolt with a red circle around it and a red line thru it (this means that the flash is off)....in the lower right hand corner you should see a white lightning bolt. Tap the red circle 2 times and you should notice that the yellow lightning bolt now stands alone and the red circle and the red line has been removed (now your flash is on). Note: Each time you turn on the camera and you need flash, you will have to make this adjustment...I hadn't figured out a way so that it happens automatically..
THANKS.
Apr 11, 2011 | Vivitar Cameras
A red circle symbol came on on my 93 BMW dash board. What does this mean.
what do the red circle mean on the dashborad of 1993 bmw?
Sep 17, 2010 | 1993 BMW 3 Series
What is the icon on the LG100C phone that is next to the battery icon? It is a circle with a + inside it. My icon also has a red line going through it. What does that mean?
The correct answer to your question.....the icon means that your phone is set for E911 GPS Locator only. If you make a 911 call your gps location will show up at the 911 center that is receiving your call. It will be your actual location and not that of the tower that is sending the signal.
Jan 03, 2010 | LG TracFone 600 Cell Phone - TF600GP4
I am trying to install a new stereo in a 94 rodeo but my wire harness is cut off
here are the wire colors and what each does.
1994 Isuzu Rodeo Car Audio Wiring Guide
Car Radio Battery Constant 12v+ Wire: Red/White
Car Radio Accessory Switched 12v+ Wire: Brown/White
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red/Green
Car Stereo Dimmer Wire: Red/Yellow
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 4′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Blue/Yellow
Left Front Speaker Negative Wire (-): Yellow
Right Front Speaker Positive Wire (+): Green/White
Right Front Speaker Negative Wire (-): Gray/White
Car Audio Rear Speakers Size: 4′
Car Audio Rear Speakers Location: Side Panels
Left Rear Speaker Positive Wire (+): White
Left Rear Speaker Negative Wire (-): Red/White
Right Rear Speaker Positive Wire (+): Orange
Right Rear Speaker Negative Wire (-): Black/Orange
Nov 22, 2009 | 1993 Isuzu Rodeo
When charging battery green light flashes then red 3 times
KODAK Easyhare digital camera light status
1. Blinking green light(or blinking blue or white light in some models) - Means camera is performing a power up procedure. Note: Wait a few moments to see if the camera displays a solid green (or blue or white) light or a blinking red light.
2. Solid green light(or blinking blue or white light in some models) - Means Camera has sufficient power
3. Blinking red light - Means camera batteries are weak or need replacement; If battery are new and still red light camera needed to be repaired
For futher assistance contact Kodak support line 1 800 235 6325 (23KODAK)
Nov 21, 2009 | Kodak EasyShare M863 Digital Camera
Cannot hear anything incoming. Speaker has a red
options/advanced options/accessibility/home screen
Nov 02, 2009 | AT&T Blackberry Curve 8300 Smartphone
Cant receive txt there is a envelope icon with a stop sign by it
Most of the time that symbol means that your inbox is full. If your inbox is not full try taking the battery out for 3 min so your phone will do a hard reset
Mar 21, 2009 | Motorola Mobility C168 Cellular Phone
Red Flashing Icon
The icons from the left: 1. Power indocator 2. Hard Disk indicator --> it is a tube icon, not battery, but means hard drive. 3. Power Source indicator 4. Bluetooth indicator
The third from left means the power source indicator. Normally it is light green. If there is battery problem (can not charge or battery overload) it flashes amber/orange. If flashes red, it indicates that the battery power is low. You need to change the battery or connect the AC adapter.
Regards,
Dapid Candra
Dec 02, 2008 | Dell Latitude D505 Notebook
Flashing red icon
It must be the internal battery problem. Change the button cell that is located near the charging input jack.
Oct 03, 2007 | Canon Elura 100 Mini DV Digital Camcorder
SanDisk Sansa e250 MP3 Player Logo
106 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
