Question about Pioneer PRO-200 60" Rear Projection Television
My rear projection T.V.
So I just had a repair man out and he told me one of my resisters burned. The part is ONLY 1.99 and he wanted to charge me 300.00. Money is tight right now so I'm attempting to do it myself. HA. Any advice PLEASE!!
Thanks
Danielle
  • 2 more comments
  • DanielleMehl Mar 09, 2008
    I'm having a hard time finding where the resistor is. Can you give me a hint of what to look for. Maybe what it looks like. I know he was working on the right side. Would R231 be close to the number? Or was that just an example?
    Thank you so so so much!
    Danielle
    By the way the model # is SD643HD5
    ok so I think I found it. Does it look like a glass tube with silver caps on each end? One of them definetly has a burn in the middle. The # is FU303 and right underneath it is 4A/1205V. Does this help?
    Thank you! Thank you! Thank you!
I HAVE A PROBLEM WITH MY TELEVISION PRO/200
WHAT HAPPENS TO ME I CONNECT A RECEIVEIR TO HEAR LIKE HOE TEATHRE , I JUST PLUG AN RCA TO DVD I, BUT IN THE SPECIFICATIONS SAYS THAT THE SPEAKER HAS TO BE LESS THAN 8 OHMS, AND I CONECT THEM ALL OF IT IN ONE POWER SUPLLY,AND WHEN HEAR IT IN AUDIO, WAS MAKING A CLICK , THEN AFTER 3 DAYS IT TURNED OFF , SO THEN I CALL TO A TECHNICAL BUT HE SAYS IS THIS FLYBACK CHARGIN ME BETWEEN $ 280 AND $ 300 DOLLARS,
ME CAN YOU HELP WITH THIS PROBLEM, CAUSE I WANT TO DO IT BY MYSELF , SO I JUST NEED YOUR ASSISTANCE TO DO IT, A FRIEND FROM OF LAREDO TEXAS MY PHONE IS 956 333-9324 ASK FOR CRUISE
Posted on Mar 11, 2008
  • Pioneer Master
  • 8,617 Answers
Do you know which resistor is burned? It should have a number stamped on the board near the resistor such as R231 or simallar number starting with R. Post that number and I will tell you the specs on the resistor.
Posted on Mar 08, 2008
  • 1 more comment
  • Sonny Berry
    Sonny Berry Mar 09, 2008
    no R231 was just a indication of how they identify parts of the board. The burned resistor should be very obvious as it should appear burned in the center.
  • Sonny Berry
    Yes that is a fuse you can get one at radio shack. tell tell you need a 4amp 125Volt fuse and just pull out the old one and install the new one. If that fuse blows again you will need to diagnose your TV. The fuse should cost less than a dollar at radio shack.
  • Sonny Berry
    Youre very welcome. If you need any more help please let me know.
WILL NOT POWER ON
hello unless the engineer tested the fuse then there could be a number of thing's wrong 1 it could be a transistor 2 could be a diode 3 could be a capacitor 4 it could be a resistor and so on . there could be just a dry joint i'd get another couple of quote good luck
regards
shaun
Apr 14, 2010 | Sony KP-51WS510 51" Rear Projection...
BLUE CONVERGE NOT WORKING
most likely convergence IC's usually 2 of them
Aug 10, 2009 | Philips 60PP9202 60" Rear Projection...
White smoke came out back then i shut it off. turned back on and
yes call repair man.make sure shop is authorized for your particular brand if possible .i have never seen a lamp burn with smoke.Its possible something else caused smoke/shutdown
Aug 06, 2009 | RCA HDLP50W151 50" Rear Projection HDTV
Our picture shows double. The repair man came out
Not advisable. $500.00 is way over board what we charge for that repair. 250-300 max. I don't know of any shop or with our tech web site that charges that kind of money. I would still shop around.
Jul 20, 2009 | Mitsubishi VS-60803 60" Rear Projection...
Yellow tv screen
i have the same problem. I had to take the whole thing apart and found that the red filter has a burn pattern in it. I am still trying to find a red filter for it.
Feb 16, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Samsung HCM553W 55 in. Rear Projection Television - image duplicated
Hello, I am a Samsung TV repair man. What happened was one of your bulbs in your tv has burnt out. you have to contact your samsung repair phone line. how old is that tv? do you have a warranty? if you do, it might be repairable for free. I hope this info is useful!
Apr 20, 2008 | Samsung HCM553W 55" Rear Projection...
Panasonic 47 inch rear projection
Have you checked the lamps. Rear projection TV's have bright lamps, that can burn out. If you have had this TV for a while, that is the first thing I would check. If you still have to manual, it should tell you how to check the lamps and which ones you need to order.
These should be special lamps only Panasonic sells. Therefore they might cost a few bills.
Feb 01, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Pioneer PRO-200 60" Rear Projection Television Logo
42 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
