Crossley top load rear feet /levelling issue
How does the self adjusting rear feet mechanism work?
One leg of mine has a pin that has fallen out and I'mnot sure if it can be replaced or if I have to have the entire mechanism replaced. The pin has a knurled segment in the middle looking like it was a press fit.
Obviously the problem manifest by high vibrations and on checking the rear of the washer is lower than front and the front legs are fully retracted.
  • lost engine Mar 09, 2008
    This solution appears to require taking the whole bottom pan off the machine as the case is a three sided box where the front comes off and it is impossible to get hands to the back corner to work on the mechanism.
    Problem Solver:
  • 7 Answers
I would tip it ovn the side and repair it. It's a simple mechanism.
Posted on Mar 08, 2008
Affinity washing machine not level/unbalance. Harm machine?
It's definitely not healthy for it. adjust the legs at the front and use a level on top while leveling. The rear feet self level
Nov 28, 2013 | Frigidaire Affinity ATF7000E Front Load...
I have a 1973 whirlpool washer. I am trying to adjust the back legs on it. It appears to have a spring loaded bar between each of the back legs. The back legs are not adjustable and look to be self...
Disconnect ac/cord,hoses and drain pipe, lay machine down on front side. Inspect the self-leveling bar ***'y and spray liberally with WD-40 if rusty and/or stuck.
Feb 22, 2011 | Whirlpool Washing Machines
The Maytag PAV 2300 does not spin right if the load is slightly off balance. It bangs on the side and ordinarily lists to the right. On inspection, the washer is on level.
The list to the right should be resolved. Use a level and level the case left and right, and front to back. The final step is to tilt the machine fully on to the front legs, releasing the self leveling rear legs, and set the machine back down. It should be stable on the 4 feet.
usually this will center the drum and it is more forgiving on balance issues, most of which are common. Be sure to use MORE than enough water for more even loads.
Feb 05, 2011 | Maytag PAV2300 Top Load Washer
Leveling legs during set-up
If you just purchased this wahser and had it delivered, make sure you remove the shipping bolt(s). There is a large pin inseted in the back of the washer that must be removed BEFORE you attempt to use it. All the balancing in the world will not prevent it from vibrating if the pin is still installed.
If the shipping bolt has been removed, the following link can give you some added pointers on how to level your washer:
http://www.fixya.com/support/r3868923-level_whirlpool_top_loading_washer
Whirlpool manufactured top loaders have an auto-leveling mechanism on the rear feet that needs to be adjusted first. Once the rear feet are set, adjust the front to match the back, by turning the front feet. Make sure you check the level side-to-side as well. DO NOT place the level on the washer lid when checking the level as the washer lid is usually bowed and will not give you an accurate reading. Once you have the washer leveled, you can place nuts on the front feet to lock them in place and prevent them from becoming unleveled. The rear mechanism should be rechecked periodically by following the procedures in the link I provided.
If you have any questions, please post back and let me know. I hope this helps you.
May 10, 2010 | Roper RAS8445KQ Top Load Washer
My Kenmore Dryer drum is vibrating after running for a while with and without clothes. What Maybe the issue, 110.76972130
Could be that the unit is not level. If the unit has self adjusting front feet, make certain the unit is level from left to right, by adjusting front legs, then pull the rear feet and inch or so from the floor, by leaning unit towards front, set back down evenly. Unit should be level.
Mar 24, 2010 | Dryers
During the rinse cycle, my washing machines shakes violently from side to side (It just started doing this a couple weeks ago). Is it off track, and is this issue self-repairable?
If this is a Kenmore top loader, it could simply be off level. The rear feet on these washer have an auto-leveling mechanism that you can easily reset yourself. Just follow these steps:
1. With the wash tub empty, open the washer lid and grasp the rim of the tub opening (do not grab the tub).
2. Now place one of your feet at the base of the washer along the front of the washer to keep it from moving.
3. Now pull the washer towards you so the rear feet lift off the floor. You should hear a clicking sound as the rear feet auto-level.
4. Carefully set the washer back down (do not slam it) and the rear of the washer should now be level.
Using a level, check the washer front to back and side to side to make sure it is level in all directions.
If you need to adjust the washer washer front feet, carefully lift the front of the washer and turn the feet to either adjust them up or down. The slightest difference can cause excessive vibration on the final spin. Check by placing your hands at opposite corners on top of the washer (diagonally - one on the rear, one on the front) and try rocking the washer to see if it moves. If the washer wobbles, you need to readjust.
I suspect that auto-leveling the rear feet will take care of the problem, since this just recently started happening. This needs to checked from time to time.
If you still have problems after checking the level of the washer, please post back and let me know. The problem could also be related to a balance spring issues. I hope this helps you.
Jan 05, 2010 | Kenmore 24032\24036 Top Load Washer
My comercial washer does not stay level when spinnig,seems like the self leveling device is not staying put ,i can lift it up to level it but it still wants to dance around.
YOUR REAR LEVELING MECHANISM IS SELF LEVELING FROM SIDE TO SIDE YOUR FRONT FEET ARE INDIVIDUAL MAKE SURE THE REAR OPERATES PROPERLY AND RELEVEL THE MACHINE IN BOTH DIRCTIONS. EACH TIME YOU MAKE AN ADJUSTMENT TO THE FRONT FEET WETHER IT BE THE RIGHT OR THE LEFT RE-RAISE THE REAR SO THAT THE REAR ADJUSTMENT WILL AUTOMATICALLY SET ITSELF TO WHAT YOU HAVE CHANGED ON THE FRONT FEET. YOU MAY HAVE TO DO THIS REPEATEDLY TO GET THE BEST POSSIBLE LEVELNESS IN BOTH DIRECTIONS. ONCE YOU ARE SATISFIED THE FRONT FEET SHOULD HAVE A SET NUT RUN THIS NUT UP TIGHT TO THE BASE OF THE WASHER.
Apr 08, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Speed Queen Top Loader heavy duty washer
First unplug the machine, now take off the front panel, two screws at the bottom of the front panel, front panel swings up and off.
check to make sure the six springs are still in place.
Under the tub is bearing housing between the tub and base usually white in color, under this is a plastic ring, does it seem to float easily when you move the tub. it could be broken. Also look around for loose or missing screws.
If all seems fine, make sure you have all four rubber feet on, level machine, in the front first side to side, then pull machine toward you to bring rear legs off floor, these are self leveling, have someone assist and make sure they are not stuck, use a pliers and break loose if they are. So with the machine on its front feet and the back feet off the ground set the machine down on all four feet check level front to back adjust as needed on the front legs. You should reset rear legs as you adjust the front. now with machine level tight the nut between the front legs and the base locking them.
This should help, if machine still shakes it could be the balance ring, has lost if solution its filled with a salt water solution, the hard part is you need to find it under the tub cover. we will go into the detail if we need to. ask more questions later
Jun 24, 2008 | Speed Queen AWS75NW Top Load Washer
Leveling a washer tub how to do so
first get a level. second, some have self leveling rear legs, just lean the machine forward and set down slowly. the rear legs are now level. if you dont have self leveling rear legs, the legs screw in, so just screw them in or out as well as the front legs untl it appears level by eye. now place the level on the washer. check it front to back and side to side. try rocking the machine to see if there is any movement. if there is adjust the legso it stops rocking, all the while keeping an eye on the level
Sep 27, 2007 | Kenmore 3.2 cu. ft. Top Load Washer
Washing Machines Logo
93 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
