Question about Intel D845GVSR Motherboard
Bootup problem Abit SG-80 motherboard Socket775 When I turn on power I get one long beep, then the power supply fan starts to go on then off. Fan for cpu does the same, both are on same time frame. System never boots up
  • Anonymous May 04, 2008
    When I use 2, 1 gig memory modules the system bombs, and when I take one moudle out and run just 1 gig of memory all is oki...strange. It took me hours to figure this out.
    Brian
  • quickturn Nov 23, 2008
    time frame. No display on monitor. Sometimes it will boot until the windows xp screen then suddenly it will turn off again.
  • 36 Answers
Fiend your solution direct from intel. Here is your solution........
http://www.intel.com/motherboard/prob676ijt65/solution
81
Posted on Mar 13, 2009
  • 818 Answers
You have problem with the memory (RAM). check it
Sergio
Posted on Mar 08, 2008
Problem installing wiring
do you have the book that came with board if not go to abit web site then look for support motherboards then to your boards number type it in if you have to.look for manual download it ok jim.
Nov 12, 2011 | Abit SG-80 (MBABITSG80) Motherboard
Hi I am working on a abit A 17 mother board it was taken apart by my nephew. I think I have every thing back togather, but when I turn it on it beeps and shows code 92,well I think thats what the l e d box...
Hi, you can download a manual here:
http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=AI7&fMTYPE=Socket 478&pPRODINFO=Manual
The fault could be the cpu, wrong type of ram, a faulty ram module
or a fault in the mainboard.
Check all the settings in the manual and the bios aswell.
Here is a list of beep codes:
Basic Beep Codes for ABIT AWARD BIOS Motherboards
  1. No beep at all - this means your motherboard is dead, either due to a defective or underpowered power supply, poorly seated CPU or RAM, or a dead-on-arrival board
  2. One beep - board is working fine
  3. One long beep then machine shuts down - faulty, improperly installed or missing CPU
  4. 1 short(Beep) System booting is normally
  5. 2 short(Beep) CMOS setting error
  6. 1 long - 1 short(Beep) DRAM ERROR
  7. 1 long - 2 short(Beep) Display card or monitor connected error
  8. 1 long - 3 short(Beep) Keyboard Error
  9. 1 long - 9 short(Beep) ROM Error
  10. Long(Beep) continuous DRAM isn't inserted correctly
  11. Short(Beep) continuous POWER supply has a problem
  12. A two-tone siren, generally caused by overheating or out of specification voltages
  13. Four beeps then machine shuts down. This is because this version of the BIOS will shut down your machine if no fan tachometer signal is detected on the fan header. Make sure you attach a fan to the FAN1 or FAN4 header or clear CMOS to reset to default (no checking).
Sep 07, 2011 | Abit AI7 Motherboard
When I turn on my computer turns off quickly with out show me the boot up screen
hello,
maybe your sata connection or ide connection is not connected well or in some cases it doesn't detect the processor fan control sensor it turns the comp off after a couple secs. Are there any beeps associated with it turning off? Also, just open up the case and make sure everything appears to power on.
Aug 21, 2011 | Abit SG-80 Motherboard
Working SG-72 MOBOs failing 1 by 1, no POST after BSOD, just fans
test the cpus in other machines. if your not getting any boot or beeps, then it is the bios or cpu.
Jun 30, 2009 | Abit SG-72 Motherboard
GPU heat/fan problem
Here is some great PC solution by Some FIXYA EXPERT. Get any kinds of PC solution from bellow.
  1. Intel MotherBoard
  2. Mercury Motherboard
  3. Gigabyte Motherboard
  4. MSI Motherboard
  5. P5GC-MX/1333 Motherboard
  6. ASUS Motherboard
  7. IBM
  8. Packard Bell
  9. via
fardinkh7
Apr 09, 2009 | Abit SG-80 Motherboard
Abit sg-80 1.0 bios driver
go web site dl bios make floppy show su on site how to do it or maby flash tool tanks nick
Oct 10, 2008 | Abit SG-80 Motherboard
Abit SG-80 Rev 1.0 Motherboard beep codes
type in beep codes into search engine find the ones for your M/board it usually means you have a fault on it try changing video card or ram
Jul 30, 2008 | Mercury P4VM800M7 Motherboard
Data broplem
have you checked all you condesers? sounds like you might have some that are almost ready to pop...
Sep 19, 2007 | Abit SG-80 Motherboard
Post Problems
These are the codes 2 short(Beeps) CMOS setting error 1 long - 1 short(Beep) DRAM ERROR Check you CMOS settings again. Move the memory to another slot or replace the memory.
Jul 13, 2007 | Abit SG-80 Motherboard
Intel D845GVSR Motherboard Logo
335 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
