Question about Amana ALW480DA Top Load Washer
No hot water
When temp. is set on hot/cold setting washer does nothing water never gets to hot
    Problem Solver:
  • 7 Answers
Hot fill solenoid.
Posted on Mar 08, 2008
No matter what the temp setting is at it only has very hot water
Your water temp is determined by 2 things. First the hook up to your water supply. If you are able to turn off the hot water valve that feeds the unit and then select a cold water only wash, do you get cold water?? If not then someone hooked up the hoses to 2 hot water feeds. If hot and cold feeds are installed right, the second thing is your computer which monitors the incoming temp through the boards atc control and a thermister. If you select cold, and only get a hum and the cold water valve is on, you may have to clean the screens in the valve of any sediment. If no hum, and no cold, dead solenoid on valve, but that would throw an error code usually. All fills are monitored by the board and usually begin with a hot/wrm mix and then changeover to a monitored cold temp , about 70 degrees.
May 05, 2010 | Kenmore Elite 45986 Front Load Washer
My Kenmore front loader sometimes fills with warm water on cold setting.
Most washer today use automatic temp. control fill valves. If water is too cold the control might mix in some hot to bring up to a preset temp. The same is true when control set for hot. For energy savings cold water will be mixed in to maintain a semi hot temp. Check with manufacture just to be sure.
Feb 03, 2010 | Kenmore 3.5 cu. ft. King Size Capacity Top...
On the warm setting only get cold water. on the hot setting i do get hot water. please help
You might not be able to do much about this. It seems most manufacturer are concerned with reducing energy usage on washers. To that end, the biggest user of energy for a washer is not the motor, but the energy used to heat your water. Reducing the temp's will allow them to lower the energy used rating.
As an example, let's say you measure your cold water at a faucet and it's 55 degrees (of course this varies with the part of the country you live in. It is basically the average year round temp. Here where I am in Minnesota, that's about 44, but in Texas or Florida, it might be close to 70) Measure the hot at your faucet also, and let's say you get 125.
Now, if you measure the incomming water on your washer, the cold might be close to the cold measured at the faucet, say 60 in your area, but the warm might only be 70. Maybe not enough of a difference that your hand would even notice. Checking the hot, you might see not much over 100.
As I've said, the energy guidlines your government set forth are driving companies to make these type of adjustments. There is not much you can do about it short of re-wirering and possibly replacing the multi selenoid thermostatically controled water valve to make it into an older style washer fill system. The temp settings now are actually set to deliver temps which more accurately hit the ranges clothing manufacturers want when they say COLD, or WARM wash, in spite of your incomming water temps to the machine.
Sep 27, 2009 | GE WBSR3140DW Top Load Washer
Automatic warm/cold water temperature setting does
The temperature control board is bad . Pt # 388246
Aug 17, 2009 | Kenmore 22422 Top Load Washer
Kenmore HE 3.8 washer has only hot water even with cold settings
If the washer fills very slowly when you have it on a cold setting the cold water may be shut off behind you washer or possibly the hot and cold are switched. if that is not the problem then you have a relay problem with the machines electrical system.
Jul 01, 2009 | Kenmore Washing Machines
70 series washer will not fill with cold water, only with hot wat
hot/cold selector switch replacement imminent.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 07, 2009 | Kenmore 22422 Top Load Washer
Frigidaire washer hot water only
sundsas if you have a bad temp select switch. only selecting hot/hot
Oct 31, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag washer
It sounds like you have the hot and cold water lines to the washer reversed.  Try turning off the tap for the hot water then setting the washer to just cold wash and then  hot washif you get nothing on the cold and cold water when set to hot they are probably reversed.  Typically if the auto-temp control is broken you will only get hot or cold coming out on any setting.
Oct 01, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Washer is a top load set it hot water and starts with hot and then will go cold willnot stay on hot G E Profile ,model wwa8350g
most new washers sense water temp and will try to adj final tub water temp by alternately running cold or hot as needed ..most hot settings are not faucet temp but a predetermined temp so if your hot water is 140 degrees coming in the control will switch the cold on to bring final tub water temp down to preset ..which could be as low as 100 degrees the industry's way of energy conservation
Sep 23, 2008 | GE Washing Machines
Washer tub will only fill on the hot setting
Is the tap to te cold water turned on
I would check that
Jan 13, 2007 | Maytag MAV3905EWW 13 Cycle Washer
Amana ALW480DA Top Load Washer Logo
66 people viewed this question
Top Amana Washing Machines Experts
Charles T Nevin
Charles T Nevin
Sal De
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
