Question about Elmo Projectors TRV-35H Slide Projector
Need software I am running a slide to video operation and would like to automate my Elmo TRV-35H with zoom in, iris control, timer, etc. I need the software that will allow my computer to do this via the projector?s serial port. Last version was for Windows 95, but I will take any version - Windows, Mac, etc.
  • 2 more comments
  • Arthur Aldrich
    Arthur Aldrich Dec 06, 2008
    The Elmo TVR-35H is not a projector, but is a telecine device for transferring slide to video. It automatically advances each slide, which I can then zoom up or change the iris. There is a RS-232 port, nine pin, but I haven't a clue as to the software that will run the unit from a PC.
  • Anonymous Dec 23, 2008
    I got the software from Elmo tech support emailed to me as a zip file for free. I am in the process of getting the RS232C connection going and testing. I have not been able to find the instructions for the software yet, but it is supposedly part of the ZIP file sent. I suggest contacting ELMO support for assistance as they were some of the best service I have had in years.
  • Arthur Aldrich
    Arthur Aldrich Mar 12, 2011
    UPDATE: I downloaded the software Elmo supplied. The application runs on an old Windows 98 computer. The application will allow you to forward and reverse slides, zoom in and put for composition, focus and adjust the iris to compensate for light and dark slides. Your white balance and color correction just be done manually from the projector. NOTE: The application does not store settings; you must repeat these for each slide. You must also use a null modem cable to connect your computer to the Elmo - a straight DB9 RS-232 cable does not work. Download the manual and operation guide from Elmp. This guide also shows the RS-232 connection and while it does not mention null modem, a null modem cable is essential for remote operation. The control program allows you to change RS-232 settings.
  • Arthur Aldrich
    Arthur Aldrich Mar 25, 2011
    I use two TRV-35H machines in a slide transfer operation. I run the Elmo app on an old Windows 98 machine via the 9-pin RS232 port. You must use a DB-9 null modem for the connection - these are cheap. The application will not store the commands for an 80-slide show, as far as I can determine. Each slide is a unique set of instructions. The app will run an entire show, however, without automatic zoom, focus and iris.
I believe he is looking for an updated version of the software for the projector that will run on modern operating systems. Will the OP please post the name and version of software that you have for this model projector? Thanks.
Posted on Aug 06, 2008
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 125 Answers
Try Windows Vista it sounds very powerful.
Posted on Mar 08, 2008
  • 3 Answers
I got software from ELMO support that loaded on my PC to run the TRV-35H. It is a ZIPPED file they sent me, seems pretty straight forward. I have yet to test as I have not gotten the RS232C cable to connect up yet. Instructions is supposedly in the zipped files, but I have not looked at it as of yet. Good luck. I have copies some slides by use of a Zippy and while a slow process, the images are great and corrections for any slide problems (color, brightness, etc..) have made the digital images on teh PC look great.
Posted on Dec 23, 2008
Can i convert to a dvd i have a trv-35h elmo
You can very easily. You may use the S-VHS output on your Elmo ( a 4-pin DIN socket on the rear) going into the S-VHS input on your DVD player. You will need an S-VHS cord. Very cheap at Radio Shack or on Ebay. This gives the best quality. Our you can use the more familiar RCA composite video output (yellow socket) from the Elmo into the composite or auxiliary input on the DVD recorder.Be sure you have selected the proper input on your DVD recorder. Use a TV set as a monitor so you can see what you are recording.When I convert slides to DVD, I do a test run through the carousel to be sure the slides are all facing the right way, not upside down or backward.I set my Elmo timer on 5 seconds and let the carousel advance automatically. You may want to zoom in or color correct as you convert. In that case, pause your DVD recorder between slides, make your adjustments, then resume recording. This is called assembly editing. It works very smoothly and you get a better show,
Oct 28, 2011 | Elmo Projectors TRV-35H Slide Projector
I bought a used Elmo TRV-35H 35mm projector. The camera works fine, but the tray only moves in reverse when I press the forward or reverse button. And after moving through a few slides it then moves...
Remember, mains voltages exist within the projector and thus the unit MUST be disconnected from the supply line whilst carrying out any servicing.
The reported fault sounds like sluggish operation of the advance/reverse mechanism. Lubricants used in the past tend to age and dry out so that the mechanism doesn't function correctly. IF YOU ARE CONFIDENT TO DO SO, remove the top of the unit and locate the slide mechanism. Carefully clean with cotton buds dipped in pure electronic cleaner and then re lubricate, using an oil dripper with the finest industrial sewing machine oil - emphasis is on a 'drip' of oil on the moving pivot points. Put the top back on and try again.
Problems with remote controllers are suually associated with tarnished contacts either in the hand unit or the projector. Once again, the contacts can be carefully cleaned and all should be well once more.
If you are using Kodak Carousel magazines, make sure you are using the correct magazine for your slides - cardboard or glass mounts. Don't mix slides in a magazine, as this can also cause problems.
Dec 13, 2010 | Elmo Projectors TRV-35H Slide Projector
Need to upgrade video camera in an Elmo TRV-s8
Not sure if that can be done but give Elmo Service a call. www.elmousa.com
Feb 23, 2010 | Elmo Projectors TRV-35H Slide Projector
I have a TRV-35G and the colour is predominately green which I cannot correct across the whole screen with the joystick control. Where the colours of the picture have been corrected (across 2/3 of the...
Try turning colour correction OFF. (button in up position). See what affect the iris control has. This control will changed the color of the slide from deep red at nearly closed to washed-out blue and white. at full open. I adjust the controls for each slide. The color temperature of the 8549 lamp varies with the brightness. lower level warmer, higher cooler.
Dec 02, 2009 | Elmo Projectors TRV-35H Slide Projector
What size tray doe the Elmo TRV-35H use? What mfg is comparable?
It uses a standard 80 slide Kodak Carousel or comparable tray. Transvue works the best. Sometimes I can coax the Elmo to use a 140 slide tray, but the slides sometimes jam.
Sep 17, 2009 | Elmo Projectors TRV-35H Slide Projector
Forgot how to use it!
Try Elmo's website. Google Elmo TRV-35 H. A PDF of the user manual is available free for download.
Apr 07, 2009 | Elmo Projectors TRV-35H Slide Projector
Elmo trv-35g & h - showing brite yellow color on areas in picture
I'm not too familiar with this unit but in general I'd check that the lamp is the correct type, not simply worn though not burned out, and that it's seated (aligned) properly in its socket.
less likely: If you are comfortable taking a voltage reading in the socket, it should read approximately 10 - 20% higher than the rated voltage of the lamp. This is because there is no load on the circuit with the lamp out of the socket. With the lamp in, the voltage would drop a bit. If your reading is significantly lower than the lamp voltage rating, I'd suspect a wiring problem but cna't specualte further.
Feb 11, 2009 | Elmo Projectors TRV-35H Slide Projector
Elmo TRV-35H 35mm SlideToVideo
Fred, there isnt really too much to these, ask any questions you may have and we will help you with it. I never saw one before and had it up and running in a half hour. ask away..
ZXR
Jun 12, 2008 | Elmo Projectors TRV-35H Slide Projector
Faulty TRV-35H
general cleaning start with forward and rev button with good contact cleaner and then go inside use air blower or compresed air(radio shack)check:lever which make the movement of forward and backward confirm it is clean-check of selonid and it is return spring has a good tension change it if it is weak or broken.apply a light grease over all moving parts.
best wishes
Dec 11, 2007 | Elmo Projectors TRV-35H Slide Projector
Elmo Projectors TRV-35H Slide Projector Logo
305 people viewed this question
Top Elmo Projectors Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Marvin
Marvin
Are you an Elmo Projectors Office Equipment and Supply Expert? Answer questions, earn points and help others
