IBM Selectric II Won't advance properly
I love my IBM Selectric but haven't used it in a while. Now, when I type, it only slightly advances, leaving a long black, thick line where the characters should be. Also the spacebar doesn't appear to be advancing.. any suggestions that I can try myself (oil?) before I take it to a repair shop?
Kathleen
    New Friend:
  • 120 Answers
Sounds like the carrier is hitting the paper androller as it slowly moves. If you havent used it for a while it might need cleaning and lube. Lawrence
Posted on Mar 08, 2008
My IBM Selectric II typewriter skips part of a letter when typing envelopes and going over the overlapped thickness. Even repeating the letter doesn't help.
That particular key is not hitting the paper flush as it should. Carefully try adjusting it in the direction of the miss.
Nov 08, 2015 | IBM Correcting Selectric II
My ibm selectric ii type impression is messy and sometimes missing part of the letters. I have check for proper ribbon placement and cleaned the ball element, but the impressions are still dirty looking. ...
Left Rear chrome lever with ABCDE or - marks should be towards the typist and the red ball next to the typing ballo should be moved to a higher number. Messy printing is caused by paper not being held tight against platen(black roller)
Jan 31, 2013 | IBM Correcting Selectric II
IBM Selectric III stopped working
Needs servicing. it slow up because the cycle clutch needed lube, Never leave on a selectric it will over heat the motor. and shut off totally, but after it cools it will turn on again. Turn the silver bar that goes through the carrier. a slight bit top away from you and try turning it on. May work for a bit
Mar 27, 2017 | IBM Correcting Selectric III Electric...
Selectric II Pitch-shift lever won't change from 12 tom 10
If you haven't changed the pitch for a long time the lubricants dry up, if you have some WD40 spray it in the slot inthe margin bar where the L. & R. margin levers ride. Give it a few minites to work.
DickyO
May 16, 2012 | IBM Correcting Selectric II
I have a IBM Model 5651 Memory Typewriter (Selectric II carriage), and I cannot make the ribbon advance while typing. If I turn the ribbon it will type until the ‘ink’ runs out. It’s just not advancing. ...
If this takes a selectric II ribbon the Spiked driver may be gummed up. Remove the ribbon,
find the latch that holds the ribbon mech. open, release it the ribbon drive should swing freely to the right, if not spray some WD40 on the pivot point, above and below the arm then work it back and forth it should free up.
DickyO
Oct 25, 2010 | IBM Office Equipment & Supplies
Selectric III typewriter
Go to lexmark.com and click your way to publications there you will find a manual with pictures and instructions on the ribbon.
DickyO
Mar 14, 2010 | IBM Office Equipment & Supplies
IBM Selectric II Will type letters, but will
Several possible causes. Needs lubrication most commonly. Sometimes the velocity cable is hung up on the left side and under the carriage. remove the ribbon and shine a light down on the left side and look for a cable hung up on the pulley, make a hook with a paper clip and lift the cable up and past the pulley
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Aug 31, 2009 | Office Equipment & Supplies
199 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
