Question about Xerox Phaser 8500/DN Printer
PHASER 8500DN ERROR CODE: 09,038,46.8515
Help
    President:
  • 2,072 Answers
That is a black ink stick count failure.
It is not seeing the black ink stick.
See if a stick is broken or not in place. One may be twisted or just jammed.
Outside chance you would need an ink loader because the sensor is not detecting the ink
Check the black sticks see if you can clear it by moving them around or sliding them up and out and reloading.
Posted on Mar 09, 2008
  • Rick Kasper Mar 09, 2008
    I had to exit to look up the procedure for checking the ink loader.
    Here is it. I believe there may be a photo example on Xerox.com under support for your printer.
    Testing the Ink Out Sensors
    Use this procedure to test if an Ink Out Sensor?s flag works correctly.
    1. Remove ink sticks from the ink loader?s channels.
    2. Place the printer in Diagnostics Mode by:
    Service method
    a. Turning on the printer and as XEROX appears on the screen, press and hold the Back and Help button until Beginning Service Mode Initialization appears.
    b. Scroll to and execute test Monitor: Sensors
    Customer method
    a. While error code displayed, press UP arrow and OK key.
    b. Scroll to Troubleshooting: Service Tools: Enter Diagnostic Mode. (Printer restarts).
    c. Select test 82: Monitor Sensors. Press OK.
    d. Scroll to 01: Exit Diagnostics and press OK to return to customer mode.
    3. Insert the clean eraser end of a pencil thru the lowermost oval slot. (The eraser end of a pencil closely simulates the bottom rail shape of a Xerox ink stick.)
    Slide the pencil down the white channel guide until the sensor is tripped. A sensor change is displayed on the control panel. When the flag is depressed, the front panel will read <color> Ink Present H. When released, the reading will change to L. The test will only display a reading when a sensor change occurs. If a flag is stuck, no sensor reading will be displayed on the front panel.
    If it doesnt change states you need to replace the ink loader
Fehler 09,038.46:43406 ist ein Tintenblock gebrochen und wird nicht mehr tranzportirt. Entfernen und weiter gehts.
Posted on Oct 18, 2010
    Problem Solver:
  • 19 Answers
Flat Rate - Complete On-Site Repair Service of your broken Tektronix / Xerox Phaser Printer
iTezen.com is Now offering Complete On-Site Repair Service of your broken Tektronix / Xerox Phaser Printer at a flat rate. Basically we repair any problem you may be having with your Phaser Printer for a flat rate. The flat rate covers cost of parts, labor and travel expenses. The flat rate is all you will pay to get your printer back in order. No hidden fees or charges. We show up! We Repair it. You pay us the rate for you model.
Our Flat Rates:
MODEL: Tektronix Phaser 840 Color Printer Repair - $159
MODEL: Tektronix Phaser 850 Color Printer Repair - $159
MODEL: Xerox Phaser 860 Color Printer Repair - $159
MODEL: Xerox Phaser 8200 Color Printer Repair - $159
MODEL: Xerox Phaser 8400 Color Printer Repair - $179
MODEL: Xerox Phaser 8500 Color Printer Repair - $199
MODEL: Xerox Phaser 7700 Color Printer Repair - $209
MODEL: Xerox Phaser 7750 Color Printer Repair - $249
MODEL: Tektronix Phaser 780 Color Printer Repair - $179
MODEL: Xerox Phaser 790 Color Printer Repair - $179
To further guaranty the quality of our services we accept COD payment (Cash On Delivery of service).Our technician will arrive at your location and repair your printer, get you printing again, then collect the payment.
We have technicians in:
Alabama, Arizona, Arkansas, California, Colorado, Connecticut, Delaware, Florida, Georgia, Idaho, Illinois, Indiana, Iowa, Kansas, Kentucky, Louisiana, Maine, Maryland, Massachusetts, Michigan, Minnesota, Mississippi, Missouri, Montana, Nebraska, Nevada, New Hampshire, New Jersey, New Mexico, New York, North Carolina, North Dakota, Ohio, Oklahoma, Oregon, Pennsylvania, Rhode Island, South, Carolina, South Dakota, Tennessee, Texas, Utah, Vermont, Virginia, Washington, West Virginia, Wisconsin, and Wyoming.
Itezen, Inc.
Tel. 516.776.7346
http://www.itezen.com/
Email: sales@itezen.com
Posted on Mar 14, 2008
  • 2072 Answers
SOURCE: Phaser 8500dn error code 07,010.43:91955
What is happening is your print head is not moving properly. The 2 most likely problems are these.
Since you mention the maintence kit and tray will not come out I suspect the first.
What happens is if the printer is not sitting level, both front to back and side to side, ink will seep down the print head and get into the print head pivot block. If you remove the covers that block is a 1 inch by 1 inch stainless steel block. located on the left side of the machine, ( looking from the front). It is located about 2/3rd of the way back on the lower part of the frame. Take a look at it, you will probably see yellow ink contamination in the block. You may have to use a pair of chennel lock pliers to remove it, but once removed you need to soak it in warm water to easily clean it. clean the block, the shaft that runs through it and remove the excess ink spilled into the machine. Honestly the easiest way to do that is to remove the print head. If you need to go that far let me know if you want to remove it and I will send directions.
Secondly the print head wiper blade could be tacked to the print head. That will happen if you shut the machine doen improperly, or if there is a power failure or the machine is being unplugged instead of shut down. That would require the removal of the ink loader, ( where you add the ink sticks) to access the print head / drum area. You can then gently detack the blade from the print head. Then run the cleaning cycle.
Posted on Nov 18, 2008
  • 2072 Answers
SOURCE: xerox phaser 8560 ERROR: 09, 038, 46:15112
Yep. One of your ink sticks is stuck in the ink loader and not advancing down to the bottom of the ink loader.
Look where you add the sticks, I think off hand that .46 means its a black stick, but anyway, one stick is broken, cracked, twisted or otherwise for some reason not sliding down the loader.
If you have to remove them, take a screw, a drywall screw is best to twist into the ink block and slide it back and out to reload.
Posted on Dec 21, 2008
angelus316
  • 41 Answers
SOURCE: system error on xerox 8560dn 09 038 46 8515
ink count sensor flags are stuck.verify the ink is correct and genuine and then reset the error by doing the following
1- turn the printer on
2- wait for the xerox logo to begin moving acroos the display
3- Before the logo is centered on the display (stops moving) press and hold the back and help buttons on the control panel.
4- Hold both buttons untill the display reads beginning service mode initialization.Release the buttons and the printer reboots into service mode with the Service Diagnostics menu dislayed
scroll untill you find function menu then click ok
scroll untill you find Clear ISC fault and press ok
click back several times and then reboot the machine.
Good luck and let me know.
Posted on May 22, 2009
  • 7 Answers
SOURCE: System Error code 09 038 46 24363
09,03x
35 = Cyan
36 = Magenta
37 = Yellow
38 = Black
The error indicates an ink stick was jammed. You have to clear the ISC (ink stick count) error.
Turn off the printer.
Turn on the printer.
As soon as you see XEROX start moving across the display hold down the back and help buttons until you see "beginning service mode" on the display.
Release the buttons, it will now come up in the service mode.
Scroll down to the function menu, hit ok, scoll to clear isc faault, hit ok.
Hit the back button to get back to the first menu then exit diagnostics, hit ok when it asks if you want to restart in customer mode.
Posted on Jun 10, 2009
  • 17 Answers
SOURCE: Xerox Phaser 8500DN printer error : 09,037.45:67244
Please clear the ISC Fault (Ink Stick Count) from the Service diagnostic menu under function.
Posted on Aug 21, 2009
Xerox phaser 8500 error 19003.48:33702
19.003:48 is the error code 33702 is the number of pages the unit has printed. the error indicates a power difference of +- 20% when trying to drive the printhead. The issue is the Electronics Module (System logic and power) or the Wave Amplifier (Printhead Controller). Both of the parts are fairly easy to replace. If it is the wave amp it is a somewhat affordable part.if it is the EM you should replace the printer. It isn't worth the fix.
May 21, 2012 | Xerox Phaser 8500/DN Printer
Xerox phaser 8500dn error message 19,003.48:133950
This is an electronics problem. The voltages are 20% off from expected values.
Try running the machine plugged directly into the wall, with no other equipment on the same circuit. This is how you should run this printer, whether this solves the problem or not.
Of course you may have bad parts, such as the Wave Amp Board 960K21180 or the Electronics Module 137E14020
Whit
Item, Inc
Oct 18, 2010 | Xerox Phaser 8500/DN Printer
Error code 09.036.44:38950
09,03x 35 = Cyan 36 = Magenta 37 = Yellow 38 = Black The error indicates an ink stick was jammed. You have to clear the ISC (ink stick count) error. Turn off the printer. Turn on the printer. As soon as you see XEROX start moving across the display hold down the back and help buttons until you see "beginning service mode" on the display. Release the buttons, it will now come up in the service mode. Scroll down to the function menu, hit ok, scoll to clear isc faault, hit ok. Hit the back button to get back to the first menu then exit diagnostics, hit ok when it asks if you want to restart in customer mode.
Jun 07, 2009 | Xerox Phaser 8500DN Printer
Phaser 8500dn error code 13,266,44
You have either an intermittent Electronics module or a intermittent print head. Lowest cost new from Xerox is $750.
Phaser printers are expensive.
May 05, 2009 | Xerox Phaser 8500/DN Printer
09,03x
35 = Cyan
36 = Magenta
37 = Yellow
38 = Black
Mar 05, 2009 | Xerox Phaser 8550DX Laser Printer
Nov 18, 2008 | Xerox Phaser 8500/DN Printer
Printer staus unavailable at this time
A couple things I would check that can cause this, all related to PC to Printer communication.
  1. Cable problem: Printing locally with a non-bidirectional printer cable from LPT1.
  2. Configuration Issue: Printing via IP and having designated in the device setup more trays then actually exist. For example, checking that you have a feeder when you have only the default tray.
  3. Resource Conflict: Printing via IP when another device is using the same IP.
  4. User Error: Having multiple copies of the same printer. i.e. 8500DN, and 8500DN(1) setting one up but having the other set as default.
Jul 24, 2008 | Xerox Phaser 8500/DN Printer
Xerox Phaser 8500DN - no power
1) verify that the power is plugged into a known good power plug in the wall. make sure there is not a surge protector, extension cord connected to it.
2) disconnect any usb and/or ethernet cables.
3) reseat the ram
4) disconnect any optional accessories such as lower trays, hard drives, etc. to isolate any possible items taking down the printer.
Jun 11, 2008 | Xerox Phaser 8500/DN Printer
Xerox Phaser  8500/DN Printer Logo
993 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
