Question about JVC KD-HDR1 CD Player
VAN AUTO HOOK UP KD-HDR1
I HAVE KD-HDR1 AUTO CD/RCV.GOING IN FORD 1990 ECONOLINE CONV.VAN.THINK HAS BUILT IN AMP WHERE FRONT SPEAKER IS.NOT SUPPOSED TO HOOK UP COMMON GROUNND OF ALL 4 SPEAKERS BUT ORIG.WIREING IS.HAVE SCOSCHE FD021 WIRE CONNECT.HAVENT PLUGED INTO RCV.YET.IS ANY OTHER WAY THAN WIRE EACH SPEAKER UP STRAIGHT TO RCV.?HELLLLPP.
  • MD MAN Mar 27, 2008
    HAS BUILT IN AMP.COMMON GROUND FOR ALL 4 SPEAKERS WHERE FRONT TOP SPEAKER WOULD GO SOME HAVE UNDER DRIVER SEAT.NOT ALL FORDS HAVE FACTORY AMP.NEED TO HOOK UP POWER SUPPLY SAME.BUT FIND SPEAKER LEADS ON AMP ONE PLUG ONLY SECOND NOT NECESSARY TO BYPASS AMP.NOW GO TO EACH SPEAKER AND DETERMINE +,--,GOING TO PLUG IN AMP &SPR. USING MULTIMETER, FORD WIRE COLORS UNIDENTIFIABLE.OR RUN ALL NEW SPEAKER WIRES.I HEARD 4 DIF.ANSWERS FROM 6+ PEOPLE.THANKS ME.
    President:
  • 624 Answers
This radio can not use a common ground. If your speakers are all grounded together you will blow up the amp IC in the radio. The negative speaker wires run at about 6 or 7 volts and so do the positive speaker wires.
Trust me, run new speaker wires, do not common ground any of these speakers
If this was helpful a good rating would be appreciated.
Posted on Jun 19, 2008
Installing JVC KD-R740BT in 1997 Ford truck, keep getting "miswiring, check wires and reset" message
Check speaker wires. All four speakers must be independent. Means no shorting to chassis.
Sep 25, 2013 | JVC KD-HDR1 CD Player
Jvc kd-hdr1
Most wiring now is standard colors....red=ignition(goes to a switched power source...Yellow=battery...goes to a hot all the time(even with key off)...black=ground...white=left front speaker positive...white w/blk stripe=left front speaker negative...gray=right front spkr +...gray/ blk=right front spkr - ...green=rear left +....green/blk rear left - ...violet=right rear +...violet/blk= right rear - ...light blue or blue with a stripe is the remote turn on lead either for an amplifier or power antenna...some radios have an orange/ with white stripe that connects to your parking light dimmer circuit to dim the radio light with the dash lights....and then you should have the antenna plug and possibly rca outputs that go to an external amp
Feb 26, 2012 | JVC KD-HDR1 CD Player
HOW DO I HOOK UP MY MP3 PLAYER TO MY JVC KD-HDR1?
if there is an auxillary input on the radio you can plug it in through that, if not you need a fm transmitter to do it... you can pick em up at your local radioshack
Aug 09, 2011 | JVC KD-HDR1 CD Player
Looking for jvc car stero manual for KD-HDR1
http://resources.jvc.com/Resources/00/00/91/LVT1470-002A.pdf
Jul 09, 2011 | JVC KD-HDR1 CD Player
1997 E250 ford van radio wiring diagram color code
1997 Ford Econoline Van Car Radio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink/Light Blue
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Green
Car Radio Illumination Wire: Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 6? x 8? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Car Audio Rear Speakers Size: 6? x 8? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Rear Speakers Location: Side Panels
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
This info came from website: http://www.modifiedlife.com/1997-ford-econoline-van-car-radio-wiring-diagram/ ----I used this site for my 01 grand marquis, and it was accurate.
Jun 02, 2011 | Ford E-250 Cars & Trucks
The van E150 Ford Idles too high from the I start it up to about the first 5 minutes then every time its started after that
its ur 'auto choke', its supposed to run a little high at first while it warms up, but if its too high u may have a faulty unit.
Jun 18, 2010 | 1990 Ford Econoline
How do I change out number 1 and 2 sparkplugs 1990 econoline van
try going through the front wheel wells behind front tires.
Feb 19, 2009 | 1990 Ford Econoline
Need timing specs for 1990 ford van E-150
if it only does it under load try using better gas if it is 5.0 then its 10 degrees
Feb 09, 2009 | 1990 Ford Econoline
1990 ford econoline van trans problem
Check tv cable, from throttle body to trans.
Nov 28, 2008 | 1990 Ford Econoline
No bass in my car
if it a 6x9 they is no miracle to it speaker blown cheers
Jan 07, 2008 | JVC KD-HDR1 CD Player
JVC KD-HDR1 CD Player Logo
231 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
