Question about Teac Audio Players & Recorders
My Teac Z-7000 will not record tapes
My Teac Z-7000 Master Cassette Deck will not record tapes. I have the manual and know the procedure for recording, but when everything is set up and ready to go...I press the play button and it won't record. The tape does move. The level meters go to zero. When I press pause, the meter levels start up again.
The unit plays prerecorded tapes fine.....and what a sound!!!!
Any suggestions?
  • 1 more comment
  • dgd21ro Jul 09, 2008
    my teac z-7000 have some little problem and i need a service manual , audio level is low on right chanel
    pls help me , or someboby to repair my unit ....
  • Bill Oct 30, 2008
    dgd21ro,
    I got a manual on eBay. Once in a while one will show up. Is your
    problem with recording, or is it in playback? (Does a prerecorded tape
    exhibit the problem, or is it just manifested in tapes that you record?)
  • Bill Jan 19, 2010
    Thank You witke64 my problem is solved!
    I replaced the fade in pot with an Alps RK097111T064 100K Flat 25mm unit. The phone volume pot with an Alps RK097122T017 10K Flat 25mm dual unit. (The 10K works fine for headphone volume control) I procured these from Mouser Electronics. They have an excellent catalog with good details on all parts.(www.mouser.com). The original pots are obsolete and no longer available. These were a close fit, but not perfect. I was able to grind out the insides of the knobs and epoxy them to the shafts of the new pots. The new pots do have the push in and out feature.
    My Z-7000 now works perfectly!
some weeks ago I got this really impressive deck (Teac Z 7000) from a colleague, and found the same problem. I fixed it, and the fix is not too complicated. It´s the potentiometers that do fail. All pots are from the same manufacturer (Alps) and construction. The problem is that the wisher is broken away from the holding plastic and will loose contact completely. You can check that with a normal ohmmeter: You´ll find the total resistance over the outer terminals but endless resistance from one of the outer terminals to the middle wisher contact. The values are: 100 kOhm linear for each of the upper left pots (fader,space), 2x22kOhm pos.log. for the lower left pot (phone volume). So, what does a broken wisher at the "fade in" pot do? The Recorder "thinks" that You selected an "endless" fade in time, and the result is : no record level. You can do an easy "quick and dirty" fix just to see if that´s the problem: Hold- or better solder- a say 47kOhm resistor in parallel to the conducted potentiometer terminals and try to record.
4 of 5 pots have been defective in my deck, and I´ve replaced them with standard types from my local electronic supplier (Conrad electronic, has a shop in Frankfurt/Main). Well, the new parts didn´t fit perfectly, I used a file to get them in (not visible from outside). Also I lost the possibility of pushing the knobs in and out, but that is not a really problem.
I assume this fix might also help owners of the Teac Z-6000 and Z-5000, which- most probably- use the same type of potentiometers.
This text was written by Boris Witke, Kelsterbach (near Frankfurt/Main), Germany. E-Mail:
witke1@web.de Please tell me if You were successful, possibly we get lucky users of these really fascinating machines.
Posted on Feb 24, 2009
How do you dub cassette to cassette
Hi
If you have a dual cassette deck, then one deck will only play cassettes,whilst the other will have a record facility as well.
Basically you need to place the original cassette in the play only deck and the target cassette in the record/play deck.
Start the playback in the play only deck and immediately press the record and play buttons together on the record deck. Some decks have high speed dubbing but this varies so much that you will need to consult your manual for this.
Cheers
Apr 09, 2015 | Audio Players & Recorders
I want my teac w600ro pla y deck a then deck b then stopyt
The unit needs work but it might not be worth repairing- that is up to you but most dual cassette decks were very poorly made units. That is why I always steer people away from them. I worked at Teac in Chicago and in fact still work on decks now under the skywave tape deck repair if you were to look me up.
Apr 16, 2014 | Beltronics TEAC W-600R Home Double...
Record button wont press down
Record button can be pressed down only if you placed a cassette into the deck and if this cassette was not protected against recording. This protection is mechanical, and can be found at the top of the cassette. One for the A-side and another one for B-side.
Thanks,
gylacz
Feb 01, 2014 | Teac W-505R Single Dual Cassette Deck
Kenwood KX-79 CW dual cassette hook up?
Just connect the deck via tape 1 the out of the deck going to the in of the amp. While the out of the amp goes to the in of the deck.
The tape deck itself will automatically choose the player that plays the cassette. One will play the other will be on pause (if you press both play buttons) till the tape stops then the other will play. For recording from tape to tape one deck will be the copy and the other the copier. There should be a dubbing button which you press to record tape to tape. Some models have a high speed dub also. For recording from the amp unless both decks have record buttons you will only be able to record with one deck. Make certain the dub button is not set.
Dec 25, 2013 | Kenwood Audio Players & Recorders
I need to know how I can hook up my Teac EQA 5 equalizer to my Sansui AUD 9 power amp.. I lost the manual to the E/Q
It is very easy, you don't need a manual for this. The EQ line in and Line out get hooked into the record out and Tape in of one of the tape loops on the Sansui amp. Record outs go to EQ in and the EQ out goes to tape play.
Oct 10, 2013 | Sony TC WE435 Stereo Dual Cassette Deck...
I can't find the manual to my Technics RS-TR272 Stereo Cassette Deck. How do you tape something on one cassette to another?
Place the tape you want to record into the left deck, Then the blank tape into the right deck. Press play on the left deck and record on the right deck.
It may be opposite depending on which side your recording deck is on.
Which ever deck has record, place blank cassette into that one and the cassette you want to copy into the other deck.
Hope this helps and please rate thanks
Mar 13, 2011 | Technics RS-TR272 Single Cassette Deck
Teac A-21 Stereo Cassette Tape Deck turns un, but won't play cassette tapes...
very likely that the drive belt has broken. I have fixed a TEAC myself using a large O-Ring from a hardware store (I know I was lucky to find a very close match). Open the unit and find the broken belt and take it to a hardware store to "size up" a replacement. Use the opportunity to oil the gear shafts and clean the rubber pinch roller.
Jun 22, 2007 | Teac DUAL CASSETTE A/R 110/220 Single Dual...
1,152 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
