Question about Sony BRAVIA KDL-40V3000 Television
No picture I have a Sony Bravia KLV-V40A210 and when I turn the TV on their is no picture but there is sound. The green light is on. The TV is hooked up to a Sony Digital Box so I'm not sure if this is causing the problem. I have checked all connection and they seem fine.
  • Anonymous Mar 20, 2008
    This is the second time that my Sony Bravia HD TV on HDMI just displays a green screen. Last time it happened I went and bought a new cable. Now what?
  • anninlet Nov 29, 2008
    Have sound but no picture on KDL-52V4100. Have checked all connections. DVD player works fine. Screen was green last night but is black this morning. Input display will come up on screen but cable television picture will not come up when the cable mode is selected. span.jajahWrapper { font-size:1em; color:#B11196; text-decoration:underline; } a.jajahLink { color:#000000; text-decoration:none; } span.jajahInLink:hover { background-color:#B11196; }
  • 2,323 Answers
Try to connect a DVD player or some other device to get video into the TV, just to make sure is not your digital box.
Try all the video inputs if possible.
Posted on Mar 08, 2008
Sony Bravia not turn on! blinking led....
These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/. If the blinks continues, and non-stop, the fault should be with its main system control IC, and with the memory IC.
Dec 15, 2013 | Sony BRAVIA KLV-S32A10 32" HDTV-Ready LCD...
Sony Bravia KLV-V40A10 When turning the tv on the on switch flashes 7 times then turns the TV off. Thanks
sony bravia klv v40 schakelt op willekeurige sijden ove rop slaapstand. lampje knippert dan 8x en vervolgens 4 sec. puaze en op nieuw knipperen.
Aug 07, 2010 | Sony Televison & Video
Model no. klv-22bx300 problem- green light
my sony KLV-22BX300 Tv when turn power on green led blinking,
and menu function not working properly
Jul 19, 2010 | Sony KDF-E50A10 50 in. LCD HDTV
There is no picture and no sound on my sony bravia KLV-40u100m
Check the U24 (CPU reset IC) on the "A" board. It may be burned. If you have a DVM (voltmeter) check for 3.3V across SW1 connections near this device. If you don't have 3.3V, U24 is bad. This part is not available from Sony. The TV may work if you just remove U24 from the board. I posted this fix on Agoraquest also, you can read more there (I'm "Roundabout" on that forum). Hope that helps
Jan 01, 2010 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
My Sony Bravia KLV-32U300A 32 in. HDTV-Ready LCD TV just lost the picture. Just see different colors. Hears static sound from the back of the unit. This was a progression. Few days ago, clicking sound...
hi..It's probably a loose cable. The first one to check is the
green connection but make sure they're all tight. RCA cables
tend to pop out part way which is enough to stop the signal.
If the green signal is lost, you get no picture. If the red or blue
are lost, you get a picture with bad coloring.
If you still have the problem check this
LOOK in the back of the TV when you have it turned on. Look in the slots near the top for a white glow coming out of it.
IF you see it, you need your signal board replaced...
IF NOT, then you need your power supply board replaced...
Apr 19, 2009 | Sony Bravia KLV-32U300A 32 in. HD-Ready...
Screen goes blank / black, sound still works
It sounds like your LCD Screen is no longer working. I would try contacting Sony and ask for a refund. I had the same T.V and the LCD Screen had gone out. A techniction came out and Condemned the screen and i had to pay $500 for a new T.V.
Apr 13, 2009 | Sony BRAVIA KDL-40V3000 Television
It was working fine then no picture dark sceen sound work fine
More information is required. Your backlight is lit (screen not dark) but I need to know what you have connected to the TV (your sources) and how they are connected. Does the menu/OSD (on screen display) work?
Oct 19, 2008 | Sony BRAVIA KLV-S40A10 40 in. HD-Ready LCD...
OK SOUND NO PICTURE
More information is required. What do you have hooked up to the TV and how is it connected? Do you have a menu/OSD (on screen display)?
Jun 25, 2008 | Sony BRAVIA KLV-S40A10 40 in. HD-Ready LCD...
Sony BRAVIA KDL-40V3000 Television Logo
277 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
