Question about Toshiba Satellite A60 Notebook
Wireless switch can you help there is no switch on the right side why is this thanks martyn
  • Mark Williams
    Mark Williams May 11, 2010
    Next to the USB on the right there is no switch?
    Is it listed in the device manager? (Control panel, system, hardware, device manager, network adapters, intel XXXX?
    Is it activated by FN + F8 keys?
    New Friend:
  • 166 Answers
Just tell me your laptop brand and model number
Posted on Mar 21, 2008
My wireless capabillity is cut off and wont cut back on and i cant conect to the internet
Hi
Have you accidently slid the wireless switch to the off position
think the switch is on the front bottom right hand side of the laptop and needs to be
slid over to the right hand side to enable the wireless to work
many thanks
Jul 21, 2011 | Acer Aspire One AOD150-1920 Netbook
How torn wireless switch on msi u210
Welcome to FixYa! Having hard time to connect wirelessly, not able to detect wireless networks, please follow these step.
1 Check if there is a switch designated for wireless, its usually located at right side of the laptop or at the front.
2 If its on, Press Fn F6 to enabled the wireless capability.
Hope this information will help. Thank you for using FixYa!
May 11, 2011 | Computers & Internet
I have got a problem,when i wanna run the wireless on laptop,it doesnt allow me to connect,it keeps saying "turn on your wireless compability" and it says that you can do this by switching on a...
Here the list of FUJTISU SIEMENS-AMILO models and where the wireless switch is located. Hope this will helps. Check what family your laptop belongs to then turn on the wireless swith using the list below:
Fujitsu Siemens Amilo A Series ---- Button above the keyboard on top right
Fujitsu Siemens Amilo D Series ---- Button above the keyboard on top right
Fujitsu Siemens Amilo K Series ---- Not Wireless
Fujitsu Siemens Amilo L/EL Series ---- Fn / F1 to turn on/off
Fujitsu Siemens Amilo La Series ---- Fn / F2 to turn on / off
Fujitsu Siemens Amilo Li Series ---- Easy launch button (one of 3) on top of keyboard
Thanks for using Fixya.
Jan 27, 2011 | Computers & Internet
Cannot the wireless internet setup
Hi kschmerer,
I understand that you are not able to setup the Wireless Network Connection in your Computer.
To fix this issue, please make sure that the Physical Wireless Switch on the Computer is turned ON and then try connecting the Computer to the Wirelss Network.
You can locate the Physical Wireless Switch on the front side of the Computer. Please move the switch toward right side to turn it ON.
Once the Physical Wireless Switch is turned ON, please try setting up the Wireless Network Connection.
If you are not able to to connect to Wireless Network Connection after switching on the Physical Wireless LAN Switch, try using the Wireless Switch Setting Utility.
To enable the Wireless Network Connection using the Wireless Device Switch Utility, please double-click the Wireless Device Switch icon on the right corner of the Taskbar. Then in the open Wireless Device Switch window, please click to check the box next to Enable 2.4Ghz Wireless LAN.
This should fix the issue.
Please post back if you have any questions or require further assistance.
Thanks for using FixYa.
Dec 07, 2010 | Sony VAIO VGN-AR150G Notebook
I can't find the wireless switch on dell latitude e5500
Go to the start menu and click where it says run or type in right above the start button in the white field and type ncpa.cpl then push enter. Where it says wireless network, right click on it then click enable. If needed, right click again and view wireless networks or Connect/Disconnect then connect to the wireless network. Also there could be a tiny switch on the right side of the computer where you turn on the computer, there might be a button to click to turn it blue. Hope this helps
Sep 30, 2010 | Dell Latitude E5500 Laptop
I have a HP compaq laptop and cant log on as administrator
Hi martyn,
Probably the user profile is corrupted.
Log in to any account and type cmd in the start search bar > now right click on the cmd listed and select run as administrator. Now at the command prompt type net users administrator /active
This will activate the super administrator account. Now log in with this account and make any changes as required.
Hope this helps,
Anup
Apr 10, 2009 | HP Compaq 6720s Notebook
Window fault
sounds like the window lock-out switch on the main switch is on.
Nov 22, 2008 | 1997 Saab 900
I have purchased a wireless router and cannot find the icon on my laptop
In some Toshiba laptop, there is a small switch at the right hand side. If I remember right, it is a small blue button. It's pretty small. Alternately, some versions have it in front/right side.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Feb 12, 2008 | Toshiba Satellite A105 Notebook
Toshiba Satellite A60 Notebook Logo
24 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
