Cars & Trucks Logo
Posted on Mar 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Clio sport wont rev over 3500 rpm - Sport Renault Cars & Trucks
Anonymous
Level 3:
Brigadier General:
  • Master 3,006 Answers
  • Posted on Mar 13, 2010
Anonymous
Master
Level 3:
Brigadier General:
Answers
3006
Questions
0
Helped
960027
Points
10121
It's in protection mode.
There's a fault somewhere which will harm the engine and so the engine defaults to a setting which will enable you to drive to the nearest Renault dealer or any other repair garage with a comprehensive diagnostic computer. Note that many independent garages have cut-price, cut-featured and frequently out of date diagnostic computers and vehicle data discs. It's one of a very few occasions that I'd actually advocate going to a main dealer.
  • Anonymous Mar 13, 2010
    One further point to my answer: Protection mode doesn't necessarily prevent the engine from damage, but it does reduce the possibility of serious damage. It's only intended to be used to get the car from where you are to the nearest suitable garage and is not intended to keep you driving all week until you can book the car in. Doing so will usually make any damage worse and can make fault diagnosis far more difficult.
Daewoo leganza wont rev past 2800 rpm idles fine just wont rev past 2800 ?
In park, this could be normal. ECU does this. around 2800 to 3500 RPMs. If driving, have the codes read. No codes , could be a clogged fuel filter, bad fuel pump(have the pressure checked), or clogged catalytic converter/s. With no codes, something is restricted..
2answers
Cutting out at 3500 rpm
Check if the air filter is clogged with oil and dirt. Check the timing, then check that the cam belt has not slipped. Could be plug wires, but this will usually cause rough running as well. Could be low fuel pressure.
Only has 2nd and third gear? and wont go past 3500 rpm dont know what it is
2 problems do not inter react , 2 and 3 gear relates to clutches or syncros or badly allined shift gear , 3500 revs points to gas problem of filter prob
1helpful
530d won't rev above 3500 rpm
In related to this problem.This are the help links provided below.Click the link below directly and go through the troubleshooting:
1helpful
Clio wont 'rev up'
This is quite often due to the throttle potentiometer which is the electronic  version of the throttle cable.
It comes as a unit and is a d-i-y job to replace if you are mechanically minded
Ticking in motor, then stops for about a month, then starts ticking again. oil changed. in nuetral it wont rev past 3500 rpm
It wont rev past 3500 in driving?
The governer on these is set to NOT allow a higher rev when car is stopped and not in gear.
Try to change oil viscosity or filter manufacturer.Some filter manufactures put in a bypass valve that kicks in too early.
1990 1.5l wont rev past 3500rpm's
Honestly I wish I could offer you more info, if it revs now that eliminates the convertor, only I can figure is when you got it to rev you were "blowing the soot out" LOL I hope I have helped you some if so please rate me accordingly.
Wont rev over 3500 rpm and under hard accel. wont shift wont rev over 3500 rpm
You should go buy a Haynes or Chilton manual to figure this out. Costs about $15. There could possibly more than one reason for this happening. Anything posted in response could only be speculation.
Top Renault Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
john h
Are you a Renault Expert? Answer questions, earn points and help others
