Question about Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range
I have a Jenn-Air slide-in range with a gas top and electric oven. I have tried to clean the gas grates without much success. I have also tried to clean my white exhaust cover for the down-draft. It has become discoloured with use. Does anyone have any suggestions? I wonder if I can put the grates in the oven while it self-cleans. Would it do any harm?
  • Lionslick Mar 15, 2008
    I will try your solution and let you know if it works. Thanks a lot.
  • Anonymous Mar 19, 2014
    it won't turn on
Oven cleaner works great just sprat let set and rinse
Posted on Oct 06, 2008
    President:
  • Jenn-Air Master
  • 2,651 Answers
I would NOT recommend putting grates in oven while self cleaning, dont even leave the racks in there!!!! ammonia supposedly cleans them pretty good, get yourself a plastic garbage bag and a measuring cup full of ammonia. place the grates in the bag and stand the cup up in the bag with them, close the bag and place on the back stoop over night. the FUMES do all the heavy work you rinse off under the sink.DO NOT pour over the grates but stand up the cup next to them.make sue to seal the bag as well!!!
Posted on Mar 15, 2008
Jenn-Air model svd48600. Gas stove top, electric oven. Why would the exhaust fan turn itself on whe either of the left burners is lit.
The switch for the optional grill attachment is activating...pull the tray/pan on the left side that holds the two burner grates toward the front...it should shut off. To correct the problem permanently, you'll need to adjust the position of the switch. The switch gets lose over time and slides on its mount until it gets out of range. The purpose of the switch is to activate the blower continuously when using the optional grill accessory. When you remove the left-side grates and the tray/pan the grates set in...you'll notice a protruding piece of metal on the front of tray/pan that fits into a hole in the cavity where the tray sits. Inside that hole is the switch that is out of position. Getting at the switch to adjust its position is not difficult, but you need to remove the upper front panel...KLS
Dec 13, 2009 | Jenn-Air Kitchen Ranges
Jenn air oven won't open after cleaning. What can
on some models if you unplug it for a few minutes
it will unlock itself when you plug it back in
Oct 09, 2009 | Jenn-Air SVE47100 Slide-In Electric...
My Jenn-Air SVE47100 slide in electric range does
Obviously it does not work fine. The thermostat sensor or the stat itself could be an issue. Can you see the sensor 'bulb'? Clean it with oven degreaser and steelwool. What is the temp in the oven with a 'oven thermometer'? Is this consistent with the oven readout?
Sep 24, 2009 | Jenn-Air SVE47100 Slide-In Electric...
Cleaning surface grates on 10 year old Jenn-air Gas-electric
Spray them w/ oven cleaner, put them in a plastic trash bag, and let them sit overnight. They should clean up w/ minimal scrubbig.
Sep 18, 2009 | Jenn-Air Kitchen Ranges
Jenn-Aire locked tight!
Try turning the oven tempurature all the way to the right (past clean). That is what unlocks mine.
Jan 12, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Jenn Air Range SCE30600
i would pull unit out adn look for a bad thermostat on back wall wired inline from bake and broil elemnts, probably tripped during a clean cycle or something got to hot, common for oven to shut down because of bad safety thermo, yet stovetop function without interuption
Nov 26, 2007 | Jenn-Air SCE30600 Slide-In Electric...
Don't know if the oven part of range is gas or electric
open the door on the left side low down you will find the model and serial number .
Visit the jenn-air website @ www.jennair.com or click
https://www.jennair.com/customer_care/contact_us.jsp
to email them and they can tell from the serial number and mail you back...
Nov 15, 2007 | GE JBP68 CleanDesign Electric Kitchen...
Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range Logo
168 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
