Question about Vacuums
I can't open the inside filter. - Vacuums
  • stelyg Mar 31, 2008
    CAN'T OPEN UP MACHINE TO CLEAN MOTOR
My husband found the user's manual so he was able to open that filter. thanks a lot.
Posted on Mar 09, 2008
I need to find out how to open the cover to change the motor filter on my Electrolux Epic Series 6500 sr canister vacuum.
There is not a replaceable motor filter inside the body of the vacuum. There is an exhaust filter under the cover on top which can be removed by pushing a little tab at the rear of the cover.
Nov 15, 2017 | Electrolux Vacuums
The seals on my dyson ball have broken loose in a couple of spots and prevents the ball from rolling freely
How old is your Dyson?
I suggest you contact Dyson Support directly to see what they can do for you. Make sure to have your model number and Serial number handy when you contact them.
Here's the link to their main page; once there, click on "Support" Dyson vacuum cleaners fans heaters accessories spares official site
Jun 17, 2016 | Dyson Cinetic Big Ball Animal Bagless...
What to do if I have a over heating motor
The ball is jammed because the spring inside which holds the filter has become stretched. Open the Door on the ball and squash the button on the filter down. Then refit filter. Refit window on ball
Aug 04, 2014 | Dyson DC25 All Floors Bagless Upright...
Got a Filter Queen Majestic Limited Edition, the one with the high and low power switch, an I have to change the power cord. How can I open the main unit to reach that power cord? Thanks,
first remove the top cap under your handle.
Then, remove the three screws under the handle.
remove the rubber cover on the switch
undo the clamps on the side of the unit
lift off the chrome cover with the cord on it by the handle itself.
When you have the access there, change the filter inside the upper chamber as well.
Good luck
Nov 15, 2010 | Filter Queen Majestic Canister Vacuum
How do I install new filters on a Miele Blue Moon?
There are two filters on the blue moon. The hepa filter and the motor filter. You get to both filters the same way. You open the lid, like you do when you change a bag. The motor filter is right behind the bag inside a plastic cover. There should be two tabs you can pull down to open and access the filter. The hepa filter is located toward the back of the bag chamber but on top. There is one tab in the middle that lift up on.
Sep 23, 2009 | Miele Blue Moon Bagged Canister Vacuum
Hi there I have a Shop.Vac QS800 57519-63 its about 6 years old. I don't have manual for it & want to know how I can use it in the wet mode Thanks for your help. Jasper
To use a shop vac to **** up water you just need to remove the filter element inside. open it up just as if you were going to empty out the dirt and on the top center you will see a filter. unscrew the retaining nut on the bottom and remove filter. After unit is dry and you are done using it in the wet mode replace the filter and put the retaining nut back on.
Aug 09, 2009 | Vacuums
Hoover Vacuum Cleaner Bad Smell
change filters. the filter inside the unit and the one on the side needs to be changed once a yr. (these are not to be washed, only the side filter if foam can be washed ). also flat belt change every 6 months and the v-belt once a yr.
Jul 19, 2009 | Hoover U6616-900 WindTunnel Bagless...
Electrolux #1521 Canister Vacuum won't stay closed
hi from uk your problem with the canister cover/door coming off whilst vaccing ? you have renewed bag ? ok but there is a filter/gauze also inside the canister where bag is fitted if you check inside you should see the filter at opposite end from where bag is secured it is usually fitted behind a slotted pull out plastic gate ? this filter/gauze is to allow air out of canister when vaccing and the filter traps any dust that may accumulate inside the canister case so the dust does not get blown out to atmosphere/rooms SO if this filter is clogged it will not allow vacced air to escape out of canister so result is build up of pressure within cylinder and eventually cover flips open ! so for now you can remove filter/gauze and wash then dry refit this will allow air to escape from canister but still retain dust particles from escaping as it is designed for however may i suggest you replace filter when convenient ? all above is on assuming that the latch on cover is working ok and not now damaged ? hope this helps best wishes
Mar 01, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Filter queen 95X (1991) Motor is noisy but still work fine. Can there be a loose screw inside ? Can I open the motor and look inside ?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=766802
Generic problem for all Vacuums
Posted by alexun on Jul 10, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The sounds coming from the motor sounds like it is the 2 sheet metal fans that do loosen up and start to make noise; and if you are handy and can do service work yourself you can replace the fans, but make sure you mark the wires when you remove the wire and the motor. If you have questions feel free to contact your local vacuum cleaner dealer in your area or cal the Filter Queen cust serv line listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.filterqueen.com/
Customer Service 1-800-344-1840
custserv@filterqueen.com
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 10, 2008 | Vacuums
Removing the filter on Dyson DC07
on the 07 model it is on the right side push clip and pull inside will be a foam filter wash and dry
Dec 13, 2007 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
