Question about Frigidaire ATF6000ES Front Load Washer
Frigidaire Front Load Washer
Mine is about a year old. Door has never functioned properly. Constant errors and have to open and reshut many times to get the error beep to stop coming on and the wash to start. Then after it partially fills with water the error beep comes on again for the door and I have to reopen and shut several times then reset the washer and start again. Every few washes the error beeps start at the end of the wash when it's spinning the last spin. It won't finish. Have to either restart the ENTIRE wash (approx 45 minutes!!!) or just put it on the 12 minute spin cycle to finish. Hate this washer and would never recommend to my worst enemy. The icing on the cake is that the door broke today and now it won't close at all. 1 years old. What junk. Have to pay for a repairman. Will never buy Frigidaire again!!
  • FLShopper Mar 11, 2008
    Me again: So I had purchased a warranty 4-year extension and called it for the first time. They said it's not covered. I asked what WAS covered. It was repeated that again this isn't covered...told to me by an obviously outsourced to somewhere in India person who was inaudible because of his extreme accent. Never buy extended warranties and never buy Frigidaire. I've looked them up online since this experience and have read pages of complaints about their products. It's an easy fix: DON'T BUY FRIGIDAIRE.
    Problem Solver:
  • 7 Answers
It looks like the door switch was not making because the door is defective. Also the switch may just be bad.
Posted on Mar 08, 2008
Has a e62 error
Frigidaire Washer Error Code E62 - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Apr 4, 2012 - 10 posts - ‎4 authors Hello, We have a 6 year old Frigidaire front load washer model GLTF2940ES3. Up until now it's worked fine. The machine now constantly ... Frigidaire Washer error code 31
May 1, 2015
Frigidaire Affinity Front Load Washer Won't Start ...
1 post
Dec 4, 2013
Frigidaire washer E6E error
Jul 31, 2012
frigidaire affinity E62 error code
Oct 30, 2010
More results from forum.appliancepartspros.com
Oct 19, 2015 | Washing Machines
How do i get the door open on a frigidaire front load washer?
check underneath the washer below where the handle is for a ring. pull to manually release lock.
Dec 02, 2014 | Frigidaire Washing Machines
Door is locked and get error code do
Check out this tip that I wrote, it will tell you how to get into the washer manually...
http://www.fixya.com/support/r3864434-washing_machine_door_jammed
heatman101
Apr 25, 2010 | Maytag Neptune MAH6500A Front Load Washer
Frigidaire Front load washer with ''ddo'' code
The DDO trouble code means that the detergent(D) dispenser(D) door is not closed properly((O)open).
The door uses a reed switch and a magnet to send the door closed signal to the control card.If the
magnet becomes dislodged you will get this code.You will need to have the magnet replaced in
its proper position to clear this code.
Apr 05, 2010 | Frigidaire GLTF2940ES Front Load Washer
It wont start washing or spin
MIne had the same code. It is the error code for the motor and control board. The book that tells you how to read the code is under the washer behind the front panel. My washer was 4 1/2 years old and was shot. To repair this was $479 for parts and labor, I replaced with a new Amana front load washer for $496.00. Glad I had AHS home warranty only cost me $60.00 for the service call and they sent me a check for a replacement. I probably would not buy another Frigidaire, because a washer should last more than 4 years. Good Luck.
Jan 04, 2010 | Frigidaire ATF6000ES Front Load Washer
My Frigidaire Model fails to spin after wash
my washer had same problems, turned out to be door lock switch. around $75.00. Washer 2 years old. Questioning quality also.
Dec 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Front Load Washer won't Spin
i fixed mine about 5 times and its always some thing diffrent.
try buyng the inexpencive parts first and leave for last the electronic control panel.
it could be that your washing a smaller amount than the recomended.
Take it to a profesional. dont do like me a DIY guy. Some times i need to take pictures when taking the monster appart and then because they are somany screws missing duct tape, rope or hangerwire becomes usefull.
All mechanics are wise guys you and me are thevictims.
Dec 02, 2009 | Frigidaire Washing Machines
My frigidaire affinity wont start
Yes, the original issue was the control from the beginning. the control is damaged and it cannot register the latch at this point. this is necessary and , it will fix the issue.
May 29, 2009 | Frigidaire Affinity ATF7000E Front Load...
Door Leak
Not usually ,replace the gasket if you cant re set the old one.
May 27, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Affinity/dr error
dr code means door not closed
get some crc spray and spray into lock on machine
that will lube the workings and should fix problem
Mar 13, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
159 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
