Repair of a 1970s HP calculator: HP 27
I bought this one in college and would like to keep it working.  When using it on a fully charged battery the display (seemingly randomly) displays blinking digits (zeroes?) across the display and then goes blank.  I have purchased two replacement batteries for it, but that has not solved the problem.  Help me keep this old lady going!  Thanks.
  • 4,102 Answers
Hi the chances are the board has got damp at some point causing it to short the only chance you have of saving the calculater is to remove the case and clean any parts of the board that look coroded but even doing this might not get it working as some part could be damaged and their is no way of replacing these parts also check battery terminals are free from corosion
Posted on Mar 08, 2008
Chair dont take a charge
Get new batteries If your batteries are 2-3 years old its time for new ones. You can check the output of the charger by using a digital voltmeter Set the meter to 200 vdc and plug it into the two outter holes of the charger port with the charger plugged in you should read 27-30 volts. and with the charger unpluged you can aslo read the voltage of your batteries. fully charged they should read 25 -27 volts. If when charging you don't read 27-30 volts then the charger isn't working and you can get an offboard charger cheaper than the onboard just charge thru the charger port on the joystick. Hope this helps
Feb 03, 2011 | Jet 3 Ultra Power Chair
My battery on my samsung g600 keeps going flat, when charging after a minute it displays battery fully charged. when charger is unplugged it is flat. bought new battery which just wouldnt charge. is it...
send the phone away for a warranty repair thats if its still in the 12 months warranty. sounds like the phone. since your phone is working with the charger in it, that points to the battery but if you bought a new one then it has to be the phone unless you are very unlucky in getting 2 dysfunctional batteries. But the best way around this is to send it away under warranty
Oct 21, 2009 | Samsung SGH-G600 Cellular Phone
Ipaq 1940 losing programmes during main battery changeover
  1. Plug the charger adapter into the charging port on the bottom of the HP iPAQ Pocket PC.
    Figure : Charging the battery
  2. When the power indicator on the top of the HP iPAQ Pocket PC turns solid amber, the unit is fully charged and can be disconnected from the AC adapter (approximate time to fully charge a unit is four hours).
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.In the event of a low backup battery warning, charge the unit immediately before removing the main battery to avoid data loss. To view the amount of charge left in the backup battery, tap Start, Settings, the System tab, and Power.
Charging with the universal desktop cradle and AC adapter Use the universal desktop cradle to charge the HP iPAQ Pocket PC, or synchronize the HP iPAQ Pocket PC with a computer.
Follow these steps to charge the HP iPAQ Pocket PC using the universal desktop cradle:
  1. Plug the AC adapter into an electrical outlet and connect the other end of the AC adapter to the AC connector on the universal desktop cradle.
  2. Connect the serial or USB cradle cable into the appropriate port on the desktop PC.Figure : Connecting with the cradle
  3. Slide the bottom of the HP iPAQ Pocket PC into the cradle and push firmly to seat it.
CAUTION: To avoid damaging the HP iPAQ Pocket PC or the cradle, make sure the pins are aligned before pushing the HP Pocket PC into the cradle.
    Figure : Charging with the universal desktop cradle
  1. AC adapter into electrical outlet
  2. AC adapter into universal desktop cradle
  3. HP iPAQ Pocket PC into cradle
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.There are stabilizers located in the universal desktop cradle that assist in aligning the unit when there is no expansion pack attached. When placing the HP iPAQ Pocket PC with an expansion pack attached into the universal desktop cradle, the stabilizers will be pushed down by the expansion pack. To release the stabilizers for use without an expansion pack, press the button on the back of the cradle.
Charging with the optional USB Autosync cable Charge the HP iPAQ Pocket PC using the optional USB Autosync cable by connecting the Autosync cable to the HP Pocket PC and the personal computer. The HP Pocket PC will be charged using power from the personal computer.
For more information on charging the HP Pocket PC using the optional USB autosync cable, from the Today screen, tap Start, Settings, the Systemtab, Power, the USB Charging tab, Settings, and Help.
Charging a low battery The HP iPAQ Pocket PC will not turn on if the battery has a low charge (less than 3.2 Volts). Fully charge the battery prior to using the HP Pocket PC.
If the charge on the battery goes below the 3.2 Volts as a result of not being connected to the universal desktop cradle or the AC adapter, no damage will occur to the battery. However, the HP iPAQ Pocket PC charge indicator light will not flash until the battery reaches the minimum charge of 3.2 Volts and a normal reset is performed.
Follow these steps to charge and reset the HP iPAQ Pocket PC:
  1. Connect the HP iPAQ Pocket PC to an A/C power supply.
  2. Charge the battery to the minimum level of 3.2 Volts (this will take 5 to 30 minutes depending on the current charge level).
  3. Perform a normal reset by using the stylus to lightly press the Reset button on the bottom of the HP iPAQ Pocket PC.
  4. Turn on the HP iPAQ Pocket PC.
Keep the HP iPAQ Pocket PC connected to the universal desktop cradle or AC adapter when it is not in use.
Aug 25, 2017 | HP iPAQ H1945 Pocket PC
Adapter not charging up computer
hi thanks for using fixya!
Have you checked your battery? perhaps, you need to change also the battery. Try to remove the battery then connect the AC adapter to your laptop using direct power without the battery. Just to see where is the error.
If still the same, I suggest that you bring your laptop to a service center to check the battery and the charger that you bought.
If you need further assistance, let me know!
Apr 26, 2009 | HP Pavilion zd8000 Notebook
Battery fully charged but phone dies within a minute
A friend that worked for GTE advised me some yrs ago to do this and I have NOT had a problem with another battery since
when you get any new Battery charge it plugged in to the ac AND phone jack for a minimum of 24 hrs without using it.
all batteries have some memory and deminish power over time but if it was NOT fully charged to begin with as a yr goes by so does the battery life. hope this works,
Apr 16, 2009 | Panasonic KX-TG5438 5.8 GHz Cordless Phone
Hp r927
Sounds like blown flash bulb.
Needs to be replaced.
Mar 19, 2009 | HP Photosmart 735 Digital Camera
Compaq nx 9020 battery charging problem
Damaged battery or internal circuit problem it is hard to to say. Bring your laptop to a repair shop. They can check the battery and tell you what the problem is.
Dec 04, 2008 | HP Compaq nx9020 Notebook
HP48SX Battery drain
I suggest you use rechargeable batteries. They usually drain faster than the alcaline ones anyway.So have 2 sets of rechargeable batteries. Evaluate the number of days a set lasts. Insert the charged batteries before the old ones are thourougly drained.
The life of your batteries in the calculator depends on the usage.
About repairs: I am convinced that it will cost you more to have it fixed than to buy a new HP calculator (HP 49g*'s, HP 50g* 's).
Hope it helps.
Nov 13, 2008 | HP 19BII Calculator
My hp jornada 728 wont charge or turn on
2000 year of introduced series. 728(2002) sold only in the UK.
is not new product by far. (in dog years it's. 100 years old)
IMO it belongs in a Museum.
hihi
put a new battery in it? (hope1)
this thing is old.
does it run with the battery out?
if not then the A.C adapator is bad (hope)
hope means , not bad INSIDE.
May 09, 2017 | HP Jornada 728
89 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
