Question about Mintek DTV-323 32 in. LCD TV/DVD Combo
DVD keeps ejecting
When I insert a commercially prerecorded dvd it initially accepts the dvd and displays "loading" on the screen. Shortly thereafter however, the dvd is ejected without playing.
I just learned Mintek went out of business and the manual does not address this issue. Thank you for your assistance.
  • margipearson Aug 24, 2008
    Page 46 of the owner's manual describes troubleshooting for this problem. "There is no disc in the unit. Put the disc on the disc tray properly with the label side up. Clean the disc. Moisture has condensed in the unit. Remove the disc and leave the unit on for about an hour." None of these solutions worked for our unit. We still are unable to use the internal dvd player. Any suggestions?
    Problem Solver:
  • 6 Answers
I have the same problem.I can only get the recorded dvd's to play on the cheap dvd players like apex and such.
Posted on Mar 09, 2008
Artisan 730 keeps ejecting CD/DVD tray?
Possibly the the eject switch is stuck, open the case carefuly check and rectify.
Mar 25, 2015 | Epson PRINTER,ARTISAN 730
I have a DVD that is stuck in my LG television.
Hi,Ok look at the DVD drawer carefully , you will see a tiny hole , this hole is expressly to eject the DVD when the electronic eject has failed . Take an ordinary paper clip and straighten it out . now insert the clip into the hole and press , this will release the drawer mechanism and with it your lost DVD Too easy !!!
Also
Removing the back cover would only allow you access to the frame and shields which must also be removed. Thereafter the DVD deck must be removed and repaired or replaced otherwise the TV will not be usable as it will still be locked in DVD mode. The system is waiting for a trigger pulse from the DVD deck that the disc has been released / ejected before it will accept any command to switch to other sources.
Unplug the unit for an extended period of time (an hour or so). The ides is to discharge and force the system to revert to factory defaults. Thereafter, try the above again. Should that still be not corrective, then perhaps your best bet would then be to consult with and/or seek the services of an authorized Service Center (specially if still under some form of extended warranty) or a qualified professional
if the DVD unit uses a slot type entry, have you tried using a credit card like something to 'fish' / 'jar' the erring disc while pressing on the EJECT button? Spraying with a can of compressed air through a nozzle like tubing may also be considered. The idea is to float the disc to initiate the eject procedures. A likely possibility is that the center hole of the disc is stuck to the spindle of the player.
Good luck and thank you
May 28, 2011 | Cell Phones
DVD ejects itself shortly after inserting
If you have tried cleaning the laser lens and the unit does spin,You have a defective laser assy,this is common with these players.If unit does not spin,try spinning it when you insert a disc by hand as this may start the unit spinning,if starts spinning then unit has a bad spin motor.
Apr 13, 2010 | Philips Televison & Video
ACOUSTIC SOLUTIONS DVD PLAYER WON'T EJECT JUST KEEPS DISPLAYING LOADING. THE DVD INSERTED MAY HAVE BEEN A DATA DVD BY MISTAKE
Hi
I made that same mistake. I had to unplug the dvd player, open the dvd door and with a screwdriver turn the wheel under the tray and manually make the tray come out of the door.
Hope it helps
Alison
Feb 21, 2010 | Televison & Video
I have a Samsung DVD-R155. When I insert a DVD, the screen reads "load", but eventually it screen will say it can't read the DVD, and then ejects the DVD. It doesn' t matter if it is a new or used DVD. I...
Try using a DVD scanner eye cleaner. It is aDVD with a brush grafted to it. I suspect the scanner eye is dirty so it cannot read the boot starp properly and so ejects
Aug 15, 2009 | Samsung DVD-R155
When a DVD is inserted, the screen indicates its loading, but it never goes beyond that point. The only other info that might be relevant is that initially the eject mechanism wouldn't function, so the...
there might be some compatibility problem . some times the dvd is not recognised by many players. not ot panic , just try ur dvd on some laptop to check whether there is problem in dvd or the system
Aug 11, 2009 | Soundstream VCM-81D 8in Overhead Monitor...
My recorder has stopped accepting NEW DVD-RW discs and ejects them. There is no problem loading DVD-R (new or recorded)or loading previous recorded DVD-RW, initializing and re-recording I have tried...
I had the same problem. After trying several brands, the only one which is working perfectly is Maxell (yellow discs). I found them is the US (Seattle), have not seen them in France where I am leaving. Hope it can help !
Nov 08, 2008 | Pioneer DVR-5100H DVD Recorder
Emerson EWL20D6 tv/dvd combo
This sounds like a possiable compatiablity problem, does it do this on all DVDs or just on prerecorded or recording ones?
Jun 06, 2008 | Emerson EWL20D6 Television
Loading DVD-RW discs
I have tried several different DVD-RW makes. Puzzling??
Nov 03, 2006 | Pioneer DVR-5100H DVD Recorder
Mintek DTV-323 32 in. LCD TV/DVD Combo Logo
251 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
