My mp3 player screen keeps blinking and does nothing else. it is stuckon the "ilo" screen. i've tried replacing batteries, holding the play button, connecting it and disconnecting it. so far nothing works. please help!
my mp3 player keeps blinking over and over does nothing else
AnonymousMar 12, 2008
Mine is doing the same thing. A guy told me to get on the internet and they would show me how to fix it. So.... How do i fix it!Mine is doing the same thing. A guy told me to get on the internet and they would show me how to fix it. So.... How do i fix it!
AnonymousDec 07, 2008
mine was a gift i won,i really think its cute, but i cant cut the ilo 2gb mp3 player on. the screen turns on to the usb port signal when i plug in the usb port but nothing else omg i dont knw wht to do HELLP !!!!!mine was a gift i won,i really think its cute, but i cant cut the ilo 2gb mp3 player on. the screen turns on to the usb port signal when i plug in the usb port but nothing else omg i dont knw wht to do HELLP !!!!!
mine does the same thing. It will not stop blinking on the ilo screen and will not shut off unless I take the battery out. What is wrong and what can I do to fix it?mine does the same thing. It will not stop blinking on the ilo screen and will not shut off unless I take the battery out. What is wrong and what can I do to fix it?
i listen to it shut down i me want to put new batteries in Now it blinking!!! please help somebody give me it. i listen to it shut down i me want to put new batteries in Now it blinking!!! please help somebody give me it.
You can't post conmments that contain an email address.
I have had the ilo for about five months. I have changed the battery several times. The only thing that happen is the back light comes on just blinks! What can I do to correct the problem.
note - dont use the media player in ilo player using computer.
a conflict between media player and mp3 player to copy songs to your player use real player gold it will sync your player perfectly
1) Disconnect from computer, turn it off, hold in volume + button and reconnect it to your computer - continue holding volume + until the Found Hardware Wizard comes up. 2)
REFORMAT FOR WINDOWS MEDIA PLAYER - Erases Everything: Connect your iLo player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "ILO 2GB" (wording may vary slightly), and then select "Format." - this should erase everything, and give you a fresh start.
This is the worst mp3 player ever invented - i have to tell you this up front. There is no driver, the company does not support the product anymore - I would return it now while you still can.
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
http://www.lenoxx.com/2005/mp3player/mp556.htm
if you have a ilo model mp-556 (on the back cover) this page has links to the firmware ... i follow the instruction and got mine working.
Mine is blinking on and off showing the ilo screen I've tried everything too.Need help with this too
blinking ilo
blinking ilo at power up...
i have the same problem
