Question about Samsung WEP200 Headset
Samsung WEP200 Headset will not charge up
I place my Headset in the charger and the red light stays on for hours. The light does not change to blue which indicates it is fully charged.
What should I do?
  • Tabish Ali May 23, 2008
    i have the same problem .... someone please answer
  • Carlos Pel
    Carlos Pel Nov 21, 2016
    Me too my wep 200 not change to green and the red light are blinking
    Master:
  • Samsung Master
  • 469 Answers
I think we have purchased a fake samsung bt. guys...though if any one has a solution let me know. AmanStino Lightning Cable Apple MFi Certified 1M Nylon Braided Charging...
Posted on Nov 21, 2016
Unplug it and replug after a few seconds and that should cause the red light to change to blue.
Posted on Jun 07, 2008
Posted on May 10, 2008
I am having the same problem! Have you had any help?
Posted on May 02, 2008
I've same problem, and I can't turn it On
Posted on Mar 25, 2008
It flashes blue three times then the blue light fades out and it wont work. have tried charging it .
You can buy a replacement very cheaply www.a4c.com/product/samsung-wep200-bluetooth-headset-black.html
Apr 03, 2014 | Samsung WEP200 Headset
How do I acitivate it
Charge your headset
Charge the headset's battery fully before using the headset for the first time.
1 Put the headset in the supplied charging case and close the cover.
2 Plug the travel adapter into the case's charging socket.
Put your headset in pairing mode
1 Ensure that the headset is off (see Turn headset on/off below).
2 Press and hold the Multi-Function button until the indicator light turns on in blue (approximately 8 seconds).
Turn on Bluetooth on your phone and pair with headset
1 Set your Bluetooth phone to discover the headset by following your phone's guide.
Typically, the steps involve going to the Settings, Connection, or Bluetooth menu on your phone and then selecting the option to discover Bluetooth devices. Your phone will find the Samsung WEP200
headset.
2 Select Samsung WEP200.
3 When the phone asks if you want to pair with it, confirm by selecting Yes or OK.
4 Enter the headset passkey or PIN, 0000.
Your phone and headset are now paired and ready to make and receive calls.
1 Place the headset over your ear.
2 On your phone, make a call to the number you want.
3 If your phone and headset are successfully paired, you will hear ringing on the headset
After you have successfully paired your phone and headset, you do not need to repeat these initial setup steps each time you use the headset.
To turn the headset on
Press and hold the Multi-Function button for4 seconds until you see 4 blue flashes on the indicator light, then release.You will hear a tone and see the indicator light flashes while the power is on.
To turn the headset off
Press and hold the Multi-Function button for 4 seconds until you see 2 blue flashes on the
indicator light, then release.You will hear series of 2 tones and see the indicator light stops flashing.
http://ars.samsung.com/customer/DownloadAnsTempl?AT_ID=70171&SEQ_NO=2
Jun 07, 2011 | Samsung Bluetooth?® WEP200 Headset...
Hi I have a samsung AATH200HBC bluetooth headset that was a gift and I've had it on charge for 24 hrs. Blue light is working but dont seem to be able to get any connection with it. Trying to pair it with...
this works with the Samsung range quite well also but you must get the sequence correct - phone blue tooth active BEFORE you turn on the headset then press and hold the on button until the blue light stays solid blue.
Jan 15, 2011 | Eforcity Samsung Bluetooth Headset WEP200...
Can i use samsung bluetooth headset WEP200 in Samsung Gravity SGH-T469W cell phone?
yes u can....just turn wep200 on until the blue light stays on not flashing...then the gravity 2 will find it.
Jun 01, 2010 | Samsung WEP200 Headset
I charged my set all nite and the light is red but
Hi, i want to try this get another BAT The bat could have expaired can't take voltage .
And also see if your charger is ok may be there is no output
have a cool weekend
Sep 12, 2009 | Samsung WEP200 Headset
I have been trying to charge my samsung wep200 but the red light keeps turning off, does that mean its fully charged or is there a problem with it?
I had the same problem. Red light would be on for a second, then nothing.
This sounds like the dumbest, most obvious thing, but I started playing with the connections. Assumed it was the two contacts inside the box not touching, but that wasn't it.
Finally wiggled the charger plug that goes into the hole in the box, and when I pushed it in really hard, tada, the red light went on and stayed. I still have to jam the plug in for it to work, but it charges the headset fine now.
Must be a design flaw. If your unit is still under warranty, you might try to get a new charger with a better plug fit, if your problem is similar to mine.
Nov 26, 2008 | Samsung WEP200 Wireless Headset
It doesn't turn on
Mine was doing this as well. I held the headset on the charger with the lid open and the red light on and then held the button down and the blue light flashed. I did a couple op checks and it works fine now.
Jun 16, 2008 | Samsung WEP200 Headset
Charging
just open the main board
and clean with solution
and give a little bit of heat with smd
Dec 30, 2007 | Samsung WEP200 Headset
Endless charging
Dear Chaterbox,
Sounds like your batteries needs replacements, try using new ones.
Sid
Nov 20, 2007 | Samsung WEP200 Headset
Samsung WEP200 Headset Logo
750 people viewed this question
Top Samsung Radio Communications Experts
ivan georgiev
ivan georgiev
JP Services
JP Services
Are you a Samsung Radio Communication Expert? Answer questions, earn points and help others
