Question about IBM ThinkVision L170 17" LCD Monitor
Monitor wont turn on, green power light on
Monitor is a IBM Thinkvision, Its dead, wont turn on plus the green power light is on allthe time. The power light wont even go off when you power the moniter button off. the moniter is just black with no sound or picture.
  • 2 more comments
  • dnbrown Mar 08, 2008
    Tried to post the problem once before and got a solution which made no since to me at all,so I'm trying again HELP!!!
  • dnbrown Mar 09, 2008
    very helpful and explained to were I can understand it. Haven't checked it out yet but well. Thanks again and I'll let you know if I get it fixed.
  • lewislewis Apr 10, 2008
    I think I have the same problem. Green light goes on and the IBM logo just flashes on the screen before going black again. I switch the display on and off many many times until finally (perhaps 30 min or more later) the image is fixed on the screen.
  • Anonymous Jul 13, 2008
    Hi, i have exactly the same problem, what should i do?
    Novelist:
  • 138 Answers
Hi you can inspect that what's wrong with your monitors. After you turned it on and the screen went black, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Posted on Mar 09, 2008
  • JD Straw Jun 20, 2011
    What is the usual cost to have this problem fixed. I'm afraid to go inside and try to fix anything. I'd written earlier but did so before finding these other questions and answers. Are these kinds of repairs more costly than replacing the monitor? Thanks again!
I had a similar problem, IBM thinkvision L170 lcd screen, turns off about 2 seconds after turning on. Just enough time to flash the IBM logo and then turn off.
I pulled it apart and found that one of the main power supply electrolytic cap's, 1000uf 16V, was swollen. I replaced it with a 1000uf 25V cap and all is fine again.
Posted on Aug 04, 2008
Monitorwont come on
When i turn on my IBM ThinkPad laptop the battery and power light is on green but the monitor remains black.
Jan 20, 2013 | IBM ThinkVision L170 17" LCD Monitor
My IBM ThinkVision monitor flickers the correct display then blacks out. The light goes green a moment, then goes amber with the blackout. I think it may be stuck in the Energy Star/Power Saver mode. Is...
skeltonh, Have you connected your L170 to a different "known-good" PC that has ALL power-save and screen saver modes disabled? Have you connected an old monitor to your PC to see if it will act same way as the L170? 12fixlouie
Jul 31, 2010 | IBM ThinkVision L170 17" LCD Monitor
IBM ThinkVision L191p after power on, remain black.
First place to chaeck will be power supply, the problem can also be caused by bad inverter circuits, bad lamps, see example of failed monitors due to bad caps, lamps, http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Feb 11, 2010 | IBM ThinkVision L191p (Black) 19" LCD...
IBM ThinkVision 17" L170P, the problem is that the screen is black and power indicator is steady green on. Can not turn off the power indicator at all.
Check the DVI connections on your computer and your monitor. It is possible that there is not a good connection. Do you have access to another working monitor? If you connect a different monitor, and that monitor comes up, it could be the DVI cable or a bad monitor itself. If neither monitor comes up it could be a bad video card or port, or the computer may not recgonize it under Properties, Display, then settings when you right-click on the monitor, if you are using it as a second monitor.
Dec 01, 2009 | IBM ThinkVision L170p 17" LCD Monitor
IBM ThinkVision 17" Monitor displays for 1 second then black
This seems to be a common problem with these monitors. Have a look very closely and see if you can still see something there. From there, either send it to get repaired, or, if you are handy with a soldering iron, open it up and replace the 4 main capacitors (at least one of them will be "popped", but it is handy to replace them all.
In order to open the monitor, you will need to remove the stand, and make sure you get all of the screws out before attacking it with a screwdriver.
I have 5 IBM monitors at work with the same problem, and opening them up has shown the popped capacitors.
Again, only recommended if you know what you are doing. Screwing it up will leave you with nothing.
Jan 25, 2009 | IBM ThinkVision L170 17" LCD Monitor
LCD (IBM) monitor power light is green but no display
Make sure the monitor lead which goes behind the computer is in correctly and has not come loose.
Unscrew it from the PC and put it back in again.
Jan 06, 2009 | IBM ThinkVision L170 17" LCD Monitor
My IBM Monitor doesnt turn on but the CPU is on.
You may have changed setting by mistake so while powering cpu first time press f8 f8 frequently and you will go to safe mode and see the picture
Oct 29, 2008 | IBM ThinkVision L170 17" LCD Monitor
Monitor is dead (black)
ask to moniter service technition
thanks
prasanna
Mar 08, 2008 | IBM ThinkVision L170 17" LCD Monitor
IBM thinkVision
Could be the invertor board is bad and will need replacing.
Jun 16, 2007 | IBM ThinkVision L151 15" LCD Monitor
IBM ThinkVision L170 17" LCD Monitor Logo
1,110 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
