Question about Vacuums
Need to find a replacement handle lock for dirt deviel upright
    President:
  • 1,673 Answers
Try your local repair shops, they will need your model number. They should be able to order it if they don't have one.
Posted on Mar 13, 2008
X1.1 model has plenty of suction through the nozzle, but doesn't 'pull' across the floor anymore or pickup dirt when using upright
Assuming that the automatic height adjuster is working properly, most likely your Sebo needs a new brush roll because the bristles on the old one are worn to the limit. To test the height adjuster, put the machine in the normal operating position (with the handle not upright) then switch on - the green "down" light may come on briefly (or may stay on if the brush is worn). Then, leaving the machine switched on, move the handle to the locked upright position - the green "up" light should come on, and you may be able to see the whole machine tilt backwards slightly as it lifts the brush off the floor. If that happens, the adjuster is working properly and you definitely need a new brush roll.
I hope this helps. If you need more guidance, just post a reply here and I'll get back to you soon. Please remember to rate this answer as I do value feedback. Good luck!
Mar 19, 2010 | Sebo Automatic X1 Bagged Upright Vacuum
My hoover upright powermate cyclonic vacuum came upplug in the handle how do I get the handle out so I can plug it back in the model number is U5182-900
there should be 2 to four screws on the backside where the handle meets the dirt catch area.take the screws out and the handle should slide off the top where the dirt cup is
Apr 08, 2009 | Bissell Vacuum - Momentum Cyclonic 1 ea...
The dirt cup clip broke and can't find the part!! Eureka whirlwind lite model#4388
I am assuming that you're looking for the handle at the front of the dirt cup... Part # 28131-288N, it has been replaced by part # 74985 Dirt cup grip assembly. If you call Eureka Customer Support at 1-800-282-2886 they will be able to find you a local dealer.
Apr 02, 2009 | Eureka Whirlwind 4388 Bagless Upright...
Not picking up dirt.
There is a Clog in the machine...
Somewhere between the motor and the bag.
When you use the machine, the dirt picked up by the roller has no place to go but backwards.
You will need to disassemble it and look for the clog.
Nov 22, 2008 | Oreck XL2200 Bagged Upright Vacuum
Dirt Devil upright vac
It could be a broken handle release, but it also could be the the clamps where the handle asm, and the base hold together came use, this will cause this problem on some Dirt Devils. The top has to come off to check this out.
Jul 13, 2008 | Kenmore Progressive Bagless Upright with...
Broken upright locking mechanism
I need to know what brand the vacuum is. Various brands have different ways of locking the handle, but most incorporate a pedal that engages the handle. It sounds like you will have to replace the pedal. I hope it's not the handle portion. That becomes more complicated and expensive to replace.
Feb 08, 2008 | Vacuums
Dirt Devil vacuum Release pedal not working
take off the bottom like you are replacing the belt. You will find a little metal clip that controls the upright lock.  It may be lose or broken.
Oct 01, 2007 | Vacuums
Vacuums Logo
27 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
