NAD 7155 Receiver's tuner not working. - Audio Players & Recorders
  • andbennett Apr 03, 2009
    Amplifier side of receiver works okay,CD & Cassette deck play okay, But nothing from Tuner side can not change display when turning to tune stations.Is this a Fuse or Capacitor fault.
    New Friend:
Electronic switch cleaner applied to all tuner related switches. You will have to take top off. Remember to let electronic cleaner dry off before power on. Also, work the switches real good while applying cleaner.
Posted on Jul 20, 2014
I Have a Captive Works which suddenly loose signal when a file is loaded.
I factory reset it and Quality and level returns but as soon as i reload a bin file i loose signal.
Can you help with a solution?
Harpic
Posted on Mar 08, 2008
Harpic
Can i hook up a power amp to my Nad 7155 receiver and how
If the Nad has pre-amp out sockets that are currently connected to the power amp in the receiver. Then you can sever those link and put the pre-amp out into your Aragon inputs.
Otherwise I don't see how you can connect the amp.
Aug 10, 2016 | NAD Audio Players & Recorders
How do you hook up a Tascam 122 cassette deck to a receiver i tried to hook it up to my Nad 7155 receiver and no sound what am i doing wrong please help
cassette decks have line OUTPUTS. If it records there may be line inputs. Connect the OUTPUTS to the appropriate INPUTs on ur amp. Select the correct input on the amp. If it doesn't work u will need to verify the amp inputs work and that the tape outputs r active.
If so chg the cables.
Jun 02, 2016 | Tascam Computers & Internet
How do i hook up my tascam 122 cassette deck to my Nad 7155 reciever i tried
The RCA outputs sockets on the 122 connect to either tape 1 or tape 2 "PLAY". on the Nad.
The Line In Jacks on the 122 connect to the record of tape 1 or tape 2 rec of the Nad.
If you connect it to tape 1 connect both to that.
To listen to the deck you select either tape 1 or 2 depending which you have connected it too.
May 29, 2016 | Tascam Audio Players & Recorders
NAD T752 display totally lit up. FM sound works but no frequency display.
Sounds like display driver board {IC} has damaged. Contact any service technician. Electro help
Dec 08, 2014 | NAD T752 A/v Surround Sound Receiver
I have a Nad T760 receiver/amp (not sure what the difference is). The remote cannot function. Is there a universal remote that I can buy? As this is quite an old piece of kit not sure if there is a
some remotes can be programmed by entering a manufacturers code using the numeric keys. i use a Sony RM-VLZ620 remote. it lists NAD as a supported receiver.
P.S. - a receiver is an amplifier with a built in radio tuner.
Nov 15, 2014 | NAD T760
NAD 7140 input selector does not work
The selector chip is not working, either there is no B+ to the ic or the chip has malfunctioned or one of the surrounding components dead, for this type of problem a schematic will be needed to track the problem. try www.nad.com contact customer support and the technical department for additional help.
Jun 15, 2012 | NAD Audio Players & Recorders
WILL T-763 PLAY MY CD'S OR DO I NEED SEPARTE CD PLAYER?
That's a receiver only, so its only built in function is the tuner. You'll need a separate CD player, plugged into the CD input jacks on the receiver's rear panel.
Jan 01, 2011 | NAD T763 Receiver
NAD 7155 with one speaker channel not working
In my case, if I push in on the balance knob, I can get the channel that quits to work for a while.
This leads me to believe that the pot is dirty as opposed to a circuit or component failure.
A couple of years ago, I sprayed circuit cleaner into the pot as best I could and the problem disappeared but, it has returned.
My next attempt will be with one of the newer cleaner/lubricators that are available now.
I don't know if this will solve your problem but, it might be worth a try.
BTW, getting access to the volume/balance pots takes some doing. As long as you are there treat both pots.
Greydog(1)
G
Jun 08, 2008 | NAD 712
NAD tuner
Depending on your audio power needs, any will work except receivers that already have integrated tuners.
Apr 21, 2008 | NAD C425 Am Tuner Tuner
Receiver (tuner) signal fade-out ---heat related
The main problem with the 7140 is that there are at least 3 versions that I am aware of. The varient is based upon the serial number. Can you post that here. I will look up the info for you. I have access to some NAD stuff. Post the part designations as well (Qxx) and I'll at least get you the exact part numbers etc.
Dan
Mar 23, 2008 | Audio Players & Recorders
458 people viewed this question
 Grubhead
Grubhead
