Question about HP OfficeJet 6210 All-In-One InkJet Printer
Trying to print an invitation
I bought 8 1/2 by 5 1/2 card stock to print an invitation. I can't figure out how to load the card stock into to the printer. It seems that it only recognizes 8 1/2 by 11 even when I chage the printer page options in the computer. Any ideas?
  • Anonymous Jun 01, 2008
    I'm having the same exact issue
  • 26 Answers
1. load your blank card in rt side of the tray
2.keep your card matter left top of your computers file then try
first you can try it with your 8.5" x 5.5" peace of papper.
this can help you
Posted on Jun 11, 2008
There is no 8.5 X 5.5 setting in Hallmark Cards for my HP4630 printer. Can I NOT print invitations that size?
The best way to print that size is to use card stock full sheet, then use the whole page, but select the half-sheet
in the print option.
Mar 13, 2018 | In Office Equipment & Supplies
Printing 5x7 card stock in HP 1510 injet all-in-one printer
You need to set up your printer preferences to accommodate the type and size of paper you wish to use, usually listed under printer/print or page set up.
Invariably, paper is loaded, butted to either left or right of the paper feed, but on the other side of the feed there should be a sliding stop which keeps your paper in place.
If feeding from the top feed, print side towards you, if printing from a tray at the bottom of the printer, print face down.
You can download a user manual from here once you've chosen your model printer:-
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=uk&cc=uk&h_page=hpcom&lang=en&h_client=S-A-R135-1&h_query=+HP+PSC+1510&submit.x=11&submit.y=7
Apr 22, 2010 | HP PSC 1510 All-In-One InkJet Printer
Printer for Envelopments Metallic Card Stock
I recently purchased an OKI specifically for my stationery business as well (using metallic cardstock) and the company told me that no OKI printers work on metallic paper... I am STILL on the search for an invitation printer! Its frustrating to say the least....
Jul 15, 2009 | OKI C5400tn Laser Printer
Printer won't accept Card Stock
Nothing to adjust feed mechanics. If it's temporaly print, you must feeed paper 1 by 1, and when printer grab paper, push paper by hand. If it's routine print, you can adjust the pick up rubber at paper feedr mechanic. Add double tape ( 1 mm, soft) below top rubber. I have done it, and printer can grab/feed paper up to 350 grams.
Jun 29, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Inside of greeting card.
Yes and no. Unless you have a printer that prints on two sides you will have to "trick" it and use the template for both. Make a front and a back. You will have to print one one side then inset it to print on the other side. Since all printers feed difrently you will have to play with this on scrap first before using your good card stock. For example I made invitations to a wedding. The couple wanted a pcture on the fornt. On my template I had to rotate the picture upside down so when it was folded in half the picture wa right side up. It also had a raised rose on the invitations so I had to adjust the image so it would print in the empty are on the front. I then had to do the inside text and makes sure the paper was inserted correctly as not to print upside down. You can do it but it is tricky, that is why I recommend some scrap paper first. Good Luck.
Apr 09, 2009 | Broderbund Print Shop Mac 2.0 for Mac
Printing heavy weight invitation stock on Epson R200
The card is probably too thick. Try cleaning the feed roller in the Sheet feeder to improve its grip. Check the GSM of the paper is within the spec of the printer.
Nov 03, 2008 | Epson Stylus Photo R220 InkJet Printer
Hp Printing issue driving me INSANE!
use a smaller card stock in size so it will come out smoothly.
check also the page setup that you're using give some allowances.
Oct 20, 2008 | Office Equipment & Supplies
C5280
when you hit 'PRINT' the window that opens up to complete the job will have a button called 'preferences'. Check to see that the paper selected isn't photo paper. You will have you choice of paper type thickness and size.
Jun 08, 2008 | HP Photosmart C5180 All-In-One InkJet...
Print 5x7 invitations on my 950?
Change the size of the document on word to a standard sized document - such as 8-1/2 x 11. Then when you go to print the documents, set the printing preferences to print on 5x7 paper. That should do the trick.
Oct 04, 2007 | HP PSC 950 All-In-One InkJet Printer
HP OfficeJet 6210 All-In-One InkJet Printer Logo
354 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
