Question about Compaq Presario 5000 PC Desktop
Hard drives replacement
Hard drive defected, would like to purchase hard drive
Veris caleen up
Posted on Mar 09, 2008
3 Suggested Answers
SOURCE: i need a new hard drive
You can go up to 120 GB for this model computer. Following is a link to Drive Solutions, Inc. It shows a 120 GB ATA drive available for your drive. ATA is the formal name for an IDE drive.
Here's the link:
http://www.drivesolutions.com/cgi-bin/shop/ug2store.cgi?command=listitems&kind=acl&pos=0&type=itemid&itemid=acl228
Good luck.
Posted on Mar 18, 2008
pankaj_dic
  • 1252 Answers
SOURCE: replaced defective hard drive, won't boot up
go to the BIOS check whether its detecting hdd or not
Posted on Nov 20, 2008
When i plug in the usb to my computer it is not recognized and does not show anywher
If you have a SimpleTech SimpleDrive connected to your computer and you're experiencing problems with the external hard drive, there may be several reasons why it's malfunctioning. Troubleshooting your computer can help rule out common problems and the possibility that the hard drive may be defective. If you recently purchased the device and suspect there is something wrong with it, return the defective drive to SimpleTech or the reseller for a replacement. Incompatible USB Port Problems SimpleTech SimpleDrive plug and play options makes it easy for you to connect the device to your computer. But you may encounter problems if your computer's USB (Universal Serial Bus) ports are not compatible with the external hard drive. Make sure your ports are powerful enough to operate the drive. USB 2.0 ports are recommended, but if you're using an older computer with 1.0 ports, the hard drive will function much slower or you may receive an error message that the device is not compatible with your system. b> Missing External Drive Letter If you're unable to find the SimpleTech external hard drive's letter on your desktop after you have installed the drivers for the device, it's possible that the external drive may be assigned to another drive. Sometimes, the hard drive is assigned to a network drive and you may need to manually change the drive's letter in Disk Management. b> SimpleTech SimpleDrive Incorrectly Formatted b> SimpleTech SimpleDrive is normally pre-formatted for Windows NTFS (New Technology File System), but Mac users may need to copy the backup software and reformat the external hard drive for FAT32 or Mac OS to be able to use the external drive. If the external hard drive is not formatted correctly for your system, it may not function or work properly. b> External Hard Drive Inaccessible If you receive an error message that says "Drive Inaccessible," the SimpleTech SimpleDrive may not be able to read the service area of the platter. If the external hard drive emits a loud or abnormal sound, this could mean the device is failing.
Test the drive on another computer to see if it is working properly. Otherwise, the external hard drive's surface area may be damaged or corrupted.
Replacing a Defective Hard Drive You can return a defective hard drive that is under warranty to SimpleTech. The manufacturer will exchange the device if the seal is not broken. But if you break or tear the seal on the case, any warranty claims will not be accepted and the device will be returned back to you. SimpleTech will only accept the device if you contracted a commercial data recovery company to retrieve critical data from the external hard drive and the seal needed to be broken. Before returning the defective drive, you will need to secure a RMA (Return Merchandise Authorization) approval number from SimpleTech and furnish any invoices or documentation regarding the data recovery company's services
or if its a usb external drive you might need a usb 3 card installed on your computer your computer might not have enough usb output power USB 3 card will provide more power when needed to the device to gain maximum throughput and conserve power when the device is connected but is idling http://blog.premiumusb.com/2010/09/usb-2-0-vs-usb-3-0/ these can be purchased on Ebay cheap and easy to install http://www.ebay.com.au/itm/PCI-e-PCI-Express-USB3-0-Card-new-NEC-720200AF1-chipset-/330608109325?pt=LH_DefaultDomain_0&hash=item4cf9c7670d for roughly $9 or $10free postage Hope this helps.
b>
Dec 14, 2012 | SimpleTech 500GB SimpleDrive Pro External...
Won't recognize external hd
Dec 11, 2012 | SimpleTech SimpleDrive Pininfarina 500GB...
I just bought an Buffalo extern harddisc. And it worked perfectly, but today, when I tried plugging it in, it began to beep. and it is doing it constantly when it is plugged in, and there is no connection...
1. If this is a usb connection it is possible the electronics have failed or the usb cord has become defective.
2. If you have a AC adapter then this also can be defective.
3. you may have to purchase another case and install the hard drive in the drive station to the new case
4. If the case is purchase with in the last 15 to 30 days you can take it back for a replacement at the store you purchased it from.
Feb 08, 2011 | Buffalo Technology DriveStation HD-HC500U2...
I bought my 2G thumb drive yesterday and this morning my computer is not detecting it but other thumb drives I have.
Since you just purchase you Thumb Drive Yesterday and you said that other usb devices have been detected you can ask the store where you purchase it to check and if it is not working they might replace it with a new one provided that it has a warranty on it.
Thanks for using Fixya.
Jan 27, 2011 | Dane-Elec DaneElec 2GB USB Drive Red Hard...
I have just purchased Transcend 500 gb external hard disk. My system is not detecting the drive? Please help me with this. This is irritating me a lit
Try connecting it to a different computer. If still not detected, it is "defective".
Take it back to where you bought it, and exercise the warranty to get it replaced, at no cost to you.
Nov 11, 2010 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
Iomega hard drives seem to give my MAc finder brain freeze
It's possible that ONE (or maybe BOTH) of the drives are defective. Disconnect one of them, and continue to use your computer. If the "freeze" never appears, then the non-connected drive is defective, and, since it is a "new" drive, you can get it replaced, for free, under warranty. If the "freeze" appears, then the currently-connected drive is defective, and needs to be replaced.
Apr 02, 2010 | Iomega 33089 250 GB Hard Drive
WD Elementstm Portable- 250GB
If you look at the Power supply box there should be a green light. If you unplug the cord and plug it in again it might just blink then stay our.. it is a common problem with these WD Elements. If it is newer, then it is under warranty.
How to check the warranty on a WD drive or product
Link: http://wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduser/std_adp.php?p_faqid=915&p_created=1047361575
Title: What would void the warranty on my drive?
Link: http://wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduser/std_adp.php?p_faqid=916&p_created=1048294698
If not they will sell you another one.
A replacement or extra power supply for your external drive can be purchased from our phone support team by calling 1-800-275-4932. Any technical support representative will be able to sell this part. Please have the serial number or model number of the hard drive ready, as this is needed to determine the correct adaptor type for the hard drive.
I hope this helps,
Randy
FixYa Support Team
Jan 11, 2010 | Western Digital Elements powered by WD 320...
How can I claim for replacement of this defective drive
Technically this is classed as a problem on your behalf. This means that warranty will not cover for the damage. Also as you did not purchase it directly the guarantee is voided to.
The best way is to find a new HDD.
I recommend: http://www.misco.co.uk
or get one more local to you from a specialist dealer.
Apr 11, 2009 | Hitachi HTS541612J9SA00 120 GB SATA Hard...
Both hard drive and CD drive can be purchased from your local technology store. For example, Futureshop or BestBuy.
You're looking for an internal IDE cd drive, and an internal IDE (NOT SATA) 3.5" hard drive. Get a 7200RPM hard drive for better performance.
example hard drive:
http://www.futureshop.ca/catalog/proddetail.asp?logon=&langid=EN&sku_id=0665000FS10035171&catid=10484
example cd drive. This is a cd/dvd read write combo drive:
http://www.futureshop.ca/catalog/proddetail.asp?logon=&langid=EN&sku_id=0665000FS10087822&catid=
you don't need the cd. you just need the drivers. download them from HP's website.
http://h10025.www1.hp.com/ewfrf/wc/siteHome?dlc=en&lc=en&cc=ca
Mar 10, 2008 | Computers & Internet
Compaq Presario 5000 PC Desktop Logo
26 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
