Question about Vivitar ViviCam 5385 Digital Camera
Lens error message
The camera will turn on, but a "lens error" message appears and the camera turns itself off. There are pictures and video that are priceless on this camera. What can be done to retrieve them?
If the pictures are on an SD card you can simply remove the card and use a card reader on your computer to copy the pictures off.
Stores will often also have picture printers that can read the SD card.
Posted on Apr 22, 2008
Err 99 message on canon 450d
CANON ERROR 99 1. Turn off the camera. 2. Remove the lens, battery, and CF card. 3. Allow the camera to sit without power for approximately 20 minutes. 4. Insert a fully charged battery, and turn on the camera. 5. Depress the shutter button as you would to take a picture. Does the "ERR 99' message appear? If it does, then the camera should be serviced. If it does not, then please proceed to the next set of steps: 1. Turn off the camera. 2. Insert the CF card. 3. Turn on the camera. 4. Format the CF card in the camera. 5. Depress the shutter button as you would to take a picture. Does the "ERR 99' message appear? If so, then the CF card is the most likely source of the issue. Try using a different card. If the message does not appear, please complete the following steps: 1. Turn off the camera. 2. Clean the lens contacts by gently rubbing them with a pencil eraser or soft cloth. Be careful that you do not let any debris fall into the camera body. 3. Reattach your lens. 4. Turn on the camera. 5. Depress the shutter button as you would to take a picture. If the "ERR 99' message only appears when one particular lens is attached, then that lens should be examined by a service technician. If you see the "ERR 99' with a different Canon lens attached, then the camera should be serviced. http://www.youtube.com/watch?v=WkXyLieNUDI - - - - - VIDEO & VOICE INSTRUSTION. Error 99
Aug 12, 2012 | Canon Cameras
Canon error 99
.1. Turn off the camera.
camera body.
Jun 08, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Canon 450D, ERROR 99 only when flash pops up
Err 99 usually means your lens contacts are dirty either on the lens itself or on the camera.
To isolate the cause of the issue, do the following: -
4. Insert only a fully charged battery, and turn on the camera.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Mar 31, 2009 | Canon Rebel XT / EOS 350D Digital Camera
I am getting an error cf..tried to format card and get error 99
I Googled the error code you're getting, and found a list of things to try and steps to attempt directly from Canon. Try out some of the stuff below, it should help.
To isolate the cause of the issue, we suggest that you do the following:
Does the “ERR 99′ message appear? If it does, then the camera should be serviced. If it does not, then please proceed to the next set of steps:
Does the “ERR 99′ message appear? If so, then the CF card is the most
camera body.
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera should be serviced.
Mar 19, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Error 99 appears in pattern, every time
Not sure about the pattern of errors, but the advice for error 99 diagnosis is to try the following diagnosis steps to isolate the cause of the issue:-
Feb 09, 2009 | Canon Digital Rebel / EOS-300D Digital...
Error 99
Error 99 is an "unspecified" error. It can sometimes be due to poor communication between the lens and camera. Here are some things to try:
1) Turn the camera off. Remove the memory card. Remove the lens. Replace the lens. Turn the camera on. Replace the memory card.
2) If that doesn't fix the problem, try cleaning the contacts on the lens and camera. Turn the camera off and remove the lens. Hold the lens upside down (contacts down) and gently rub the contacts with a clean pencil eraser. Be very careful to ensure that the eraser debris falls on the table and not into the lens. Repeat with the camera body, also holding it upside down (contacts down) as you clean. Replace the lens.
If neither of these work, then you need to send the camera in to Canon for repair.
Dec 16, 2008 | Canon Digital Rebel XT / EOS 350D Digital...
Canon 300d gives error 99 and does not work
Try the following diagnosis steps: -
Nov 28, 2008 | Canon Digital Rebel / EOS-300D Digital...
Lens error
Hey Wiggs12485,
This error message appears when the camera detects a problem with the lens when it's turned on. This is often caused by the user pressing on the lens when it is trying to extend, or the camera is being used in a dusty or sandy environment. When this message appears turn the camera off and back on, and this should resolve your issue. If this message continues to appear you should have the camera looked at by an authorized service technician because there is probably a problem with the lens.
Sincerely,
Allan
Go Ahead. Use Us.
May 04, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Error 99 on 30D Canon
Had this problem before and i found this guide online
camera body.
Feb 22, 2008 | Canon EOS 30D Digital Camera with 18-55mm...
Vivitar ViviCam 5385 Digital Camera Logo
93 people viewed this question
Top Vivitar Cameras Experts
Steve
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
