Back to:
Tags:
GE GSS22JFMWW Side by Side Refrigerator
Evaporator fan not working (by 2 users)
posted by poch7 on Mar 08, 2008
GE PTS22LHR, 2004 model, compressor and condenser fan are working, but evaporator fan is not. I downloaded the service manual (published in 2001) only to find out the main board in the refrigerator is nothing like the one in the maual, nor like these website's replacement part. There is no ICs or SMT parts but only relays, chokes and connectors on my current main board, but the connector designations and wire color code matched service manual, any one knows what is going on?
Both freezer and fresh food compartment are 10-20F higher than the set temperature.
evaporator fan not working,not cooling enough
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Discslinger, posted on Apr 22, 2008
I had a technician come out and tell me that my evaporator fan was shot and that he needed to replace the circuit board as well because if he only replaced the fan it would short out if he didn't put in a new circuit board. He said that he had received this information in an email from GE. Is this true? Can't you just put in a new evaporator fan without replacing the circuit board?
Best Solution
posted on Mar 08, 2008
Thanks for Trying (70)
spongeboob
Rank:Wiz Wiz
Rating: 81%, 24 votes
have you check the thermostat as follows ?
1. operation.
2. circuit from thermo switch (stat) to relay and the function of the relay, the stat should close and coild on relay should be powered, thus closing contacts to pull in evap fan.
assume you are carefull enough not to electrocute yourself in the process, short out relay contacts to see if fan runs. if it does and stat actually is okay. replace relay on board it may be faulty or may have anboard maufacturing fault such as dry solder joint etc.
alternatively if you have a good friend good al electrical work have him relace relay for you.
as an emergency fix , connect evap fan to supply, thus by passing control bard al togheter, ths should give you you 10 degress straight away and keep you rubnning till you solve board level problem.
in the process of changing
asuming you have af
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Evaporator fan not working:
I don't want to Accept this solution
Can you Help with these Refrigerators problems?
Refrigerators
My ice maker isn't making ice anymore. I took it out of...
Refrigerators
Have Whirlpool american style fridge freezer approx 2...
Refrigerators
Fridge freezer keeps making a fairly loud buzzing noise,...
Refrigerators
I replaced the P.C. Board kit, emitter & receiver...
The ice dispenser will only serve crushed ice, it will not...
Loading problems.
Repair Service
Find Refrigerator Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
