Question about Vacuums
Looking for Eureka belt 70646A for a Eureka The Boss upright
I am looking for a belt for a Eureka The Boss vacuum cleaner (upright). The belt is stamped 70646A. The belt R for the 4800 is too big...another was too short and wide. The manual is missing for this vacuum. Any suggestions?
  • 5 more comments
  • rumblebunny May 24, 2008
    My Eureka whirlwind needs a 70646A belt. That is the part number printed on the vacuum belt guard. I have looked eveywhere for this and other parts for this great vacuum. Filters are another that is hard to find. I hate to go buy a new cleaner when this one only needs a belt and filter.
  • dstiles8 Jul 05, 2008
    I'm new here and posted my problem as a solution so please read my "solution" because you'll see my problem and what I've done to fix it.
  • reallynow Aug 04, 2008
    my problem is the same as everyone elses - i need a new belt. this is the number given. What??? Belt # 70646A
  • Anonymous Aug 16, 2008
    That just happened to me too.
  • Anonymous Mar 13, 2014
    need to replace belt on eureka altima vacum cleaner
  • Anonymous Mar 23, 2014
    the brush on the boss upright has 2 triangle looking ends that are ridiculus to put back on when you have the change this belt. do you have a new version lightwt. that doesn't have this horrible feature on the brush roller. if you don't get the brush back in right the bottom plate won't fit
  • Anonymous Mar 25, 2014
    will not turn on after vacuum turned off while using
I just replaced the belt on my Eureka The Boss Smart Vac (Model 4870D). I purchased a namebrand Eureka R belt from a local vendor. I did my best to follow the instructions printed on the bottom of the machine. I turned on the vacuum cleaner and the belt brush was spinning! I dropped it into vacuuming floor mode and the belt wouldn't spin no matter what level I put it on.
I called the manufacturer (1-800-282-2886) and spoke with a very nice woman on the phone. While I was speaking with her I noticed that a silver screw was lodged within the "brush roll control" yellow selector switch. With some shaking it became dislodged and I was able to put the "brush roll control" into the hard floors setting and turn the "carpet height adjustment" all the way to the right, so that it was facing the word "low." I then followed the instructions for replacing the belt again.. (1) remove base plate (2) remove brush roll (3) place new belt around motor shaft and then around brush roll (4) insert left side of brush roll before right side (5) rotate brush roll to be sure belt is centered (6) replace base plate, making sure to insert under 4 little tabs before securing with screws.
It appears that it is very important that the carpet height and brush control adjustment are set to their highest point possible (hardwood setting) in order to get the brush to roll in a carpet setting.
"R" is the correct belt for the 4870 and should be correct for all other 4800 models.
Thank you for posting your problem to this website. If I hadn't seen that others were having trouble, I would have just given up. I hope this long post helps someone that was in my situation.
Posted on Aug 06, 2008
    President:
  • 1,673 Answers
It should be a standard Eureka U belt. That number you have is not a good number. Most repair shops should have this one. The R belt is a real thin and different material.
Posted on Mar 11, 2008
  • 701 Answers
You need the Eureka Style R belt for your model. You can get it here:
Eureka Style R Belt
Posted on Oct 29, 2009
I'm having the same problem and the U belt is the short fat one.I got it at Home Depot and didn't really have another option.  Put it on the vacuum and it lasted about 5 minutes or less before it shred.  Then we found the R coded belt at Wal-Mart but it is too long and doesn't create enough friction to move the brush correctly.  Once again, there were few options and after going through the book, the salesperson was positive we needed the R coded belt even after we brought it back.  The R coded belt has 71367A stamped on it so I know it isn't the correct one but I still don't know how to find the right one.
Posted on Jul 05, 2008
    I've done further searching on Eureka's website.  The Boss is model number 4870A and according to the website requires belt coded R, the same one that has a mismatched number and is too long.  In order to put the belt on the machine you are supposed to place the switch in the hard floors position to loosen the belt and it is supposed to return to tighten the belt when the switch is placed back into carpet mode.  Makes sense, and it does function that way but I don't feel like it is making enough friction to be effective.  I called the 800 number on the bottom of the vacuum but they are only open M-F and it happens to be Saturday.  My local warranty center is also only open M-F to confirm my findings.
Do a google search for manual
Posted on Apr 01, 2008
The belt on my used Eureka Boss 5857 upright slips off the end of the motor shaft every time the vacuum is used. When I turn the brush roll slowly by hand, the belt walks toward the end of the shaft. It...
The brush roller could be worn and in need of replacement. Some Eureka uprights have a wire guide that prevents the belt from slipping off the motor shaft.
Apr 02, 2011 | Eureka 5856BVZ Boss Bagless Upright...
Need belt for Eureka vaccum The Boss model 5848 AV-2. Can you give me a belt number for what i nee. Thanks.
The belt part number for the Eureka 5848 AV-2 vacuum is 61120A.
Should you need part numbers for other pieces of the Eureka 5848 AV-2 vacuum, click on the following site, http://www.vacpartswarehouse.com/Eureka-5848-Lightspeed-Whirlwind-s/1959.htm
Mar 14, 2011 | Eureka 5849A Boss Bagless Upright Cyclonic...
A BELT FOR THE VACCUM CLEANER (EUREKA)
Here's a link to this exact belt for your vacuum cleaner on our website:
http://www.govacuum.com/1555.html
I hope this information helped you! Please be sure to rate this helpful if it did so other Fixya users with this vacuum can easily find this belt.
Thanks,
Chris J.
GoVacuum.com
Mar 30, 2010 | Eureka Altima Upright Vacuum Model 2996AVS...
Eureka Boss - Belt is not broke but brush will not turn. I have already turned it over - checked belt - and pushed the reset button.
The belt may look fine but they can still be stretched or worn and it won' turn the brush. Try changing the belt and see what it does. You can get Eureka belts here:
Eureka Replacement Vacuum Belts
Nov 07, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Looking for Eureka Boss Belt
Go to abcvacuum.com They should have what you are looking for.
Jul 16, 2009 | Vacuums
My wife's Eureka 5855 Boss Bagless Wide Track stopped running
its probably something in the motor. you may have to replace the motor which could cost around $50.
Apr 15, 2009 | Eureka 5849A Boss Bagless Upright Cyclonic...
Eureka the boss upright bagless vacuum. how do i open it to get to the belt area? the brush seems stuck. it wont move
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=801547
Generic problem for all Vacuums
Posted by sweet0nes on July 18, 2008
Eureka the boss upright bagless vacuum. How do I open it to get to the belt area? The brush seems stuck. It won’t move.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Knowing the brand name and model number for the vacuum but I can give you a generic way of changing the belt. You 1st need to remove the bottom plate by screws, levers or clips, then you can get @ the belt, if not then you should remove the top cover and then you can get @ the belt. 1st remove the belt from the brushroll and install the new belt on the pulley side of the brushroll and then use a belt puller or a screwdriver with a bend on the end and then stretch the belt onto the motor pulley and then track the belt in a straight line so that is running in a straight line. Replace the bottom plate and the belt change should be done. Please feel free to contact your local vacuum cleaner dealer in your area.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.eureka.com Customer Service
Customer Service Dept 1-800-282-2886
Electrolux Home Care Products
P.O. Box 3900
Peoria. IL 61612
Hours of Operation
Monday thru Friday 8:00am to 7:30pm CST
Saturday and Sunday 10:00am to 6:30pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 18, 2008 | Vacuums
Eureka 5849A Boss bagless upright
remove belt to brush roll and see if noise persists. if it stops, you probably need a brush roll. at least doing this will narrow down the fault area
Mar 26, 2007 | Eureka 5849A Boss Bagless Upright Cyclonic...
Vacuums Logo
5,855 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
