Question about Panasonic PT-56WXF95 56" Rear Projection Television
DEMO MENU MY TV WENT INTO DEMO MENU AND I CAN NOT GET OUT. I TRIED THE CHANNEL UP AND ACTION BUTTON AT THE SAME TIME LIKE IT SUGGESTEED BUT STILL DOES NOT WORK. WHAT DO I DO I MISS MY T.V. MY T.V. IS 6 YEARS OLD
    Genius:
  • 1,694 Answers
Hold various combos of front panel buttons for six seconds.....
try vol up & chan up..........chan down & action........chan up &
action........vol down & chan down........etc.
Posted on Mar 30, 2008
Accidently changed something and not able to get antenna tv now - do not ahve cable here at work
I am unable to see at a glance how to correct this but it is between its menu, channel and volume buttons to alter the settings it may be worth to run through the re-tune sequence below?
To preset a channel or to change a preset channel, follow the procedure below.
1) Press the POWER button to turn on the TV.
2) Press the MENU button so that the menu display appears
on the TV screen.
3) Press the CH(annel) ? or ? button to point to "CHANNEL SET".
Then, press the VOL(ume) ? button.
4) Press the CH(annel) ? or ? button to point to "AUTO PRESET CH".
The tuner scans and memorizes all active channels in your area.
? The TV distinguishes between standard TV channels and cable channels.
? When AUTO PRESET CH action is completed, the lowest memorized channel reappears on the
screen.
? When you press the CH(annel) ? or ? button after selecting "AUTO PRESET CH", the tuner
will stop at the memorized channels only.
? The TV may recognize TV channels to be CATV channels by the receiving conditions. In this
case, try AUTO PRESET CH action again in the fine receiving conditions.
? When AUTO PRESET CH is activated where there is no TV signal input,"NO TV SIGNALS"
will appear on the display after the completion of channel scanning.
[ADD/DELETE FUNCTION]
1) Press the MENU button so that the menu display appears on the TV screen.
2) Press the CH(annel) ? or ? button to point to "CHANNEL SET".
3) Press the VOL(ume) ? button so that "ADD/DELETE" is selected.
4) Use the CH(annel) ? or ? button to select the
channel you wish to put into memory or to erase from memory.
Note: The menu will disappear in about 10 seconds.
Perform "ADD/DELETE" function while this display appears on the
screen.
? Press the VOL(ume) ? or ? button to light up the channel number
in LIGHT BLUE if you wish to add the channel into memory.
in LIGHT RED if you wish to erase the channel from memory.
5) Press the MENU button to exit the menu.
Hope this helps.
Jun 29, 2015 | Durabrand DWT1304 13" TV
Cant get demo off on a samsung tv LE32C450E1W
Try doing the same thing, except instead of holding the menu button, hold the power button
Aug 29, 2012 | Samsung Televison & Video
TV went into Demo mode on its own. Can not get the TV to stay out of Demo mode for more than a couple of minutes. Also can not find any info on this setting in any manual that came with the set. What is...
the problem of your TV is the demo button...when the button is defective it remains on contact so that it comes to demo mode automatically..
you need to do is replace the button of demo or menu in your TV
Mar 15, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
I don't have the original remote to my tv because it was given to me. the tv is locked on a parental code lock and i can't unlock it. i don't now the model.
try this:
With tv powered on, push channel + and action buttons at same time.
While still pushing action button, lift channnel + button and push POWER button until appear The user´s menu on the screen.
Now the tv was reseted at factory values.
To Do tv set up.
May 07, 2010 | Televison & Video
My Quasar TV is showing the same paid-commercial over and over. Nothing I have done stops it. I can only turn on/off the TV. Any other button causes a sign to appear in all red stating that to exit I...
on some remotes the action button is used to bring the menu up. Maybe you could try the channel up and menu button at the same time. I don't know if this will work but it's worth a try.
Sep 13, 2009 | Televison & Video
Stuck on Demo mode?
try to hit back the tv by your hand then try to resolder back the tv ic board maybe some electronic part is loose contact
Mar 24, 2009 | Panasonic CT-36G24 36" TV
Toshiba 36a40
Your set is  in demo mode---your owners manual will help----
 Try holding Menu & power on (front of set) four seconds or
 maybe vol up & channel up at same time......T.
Oct 29, 2007 | Toshiba 36A40 36" TV
Demo mode wont shut off
I have this same problem, just started 2 days ago. Changed batteries in remote and everything - driving me nuts- now i cannot change channel or adjust volume! I powered off TV, took batteries out of remote, turned back on and now still stuck. I think we bought junk!
May 21, 2007 | Toshiba 32A33 32" TV
TV Stuck in Demo mode
In the tv and with the set turned on press and hold the ACTION and CHANNEL UP buttons at the same time for more than 5 secons.Let Us know how it goes.
Oct 16, 2006 | Panasonic CT-34WX54 34" TV
Demo mode
Try pressing the vol up and vol down buttons on the tv at the same time(not on the remote)
Sep 09, 2006 | Philips Magnavox MT1905B 19" TV
Panasonic PT-56WXF95 56" Rear Projection Television Logo
158 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
