Question about HP Compaq Presario 2500 HP Pavilion ZE 5000 NX9010 Series (chassis bottom)319470-001 (319470001) CD-ROM Drive
Setup problem my laptop goes straight to setup when power on instead booting to windows
  • 520 Answers
When u say setup do u mean bios setup or windows setup.if windows setup u have os disk in cd.if not , in bios choose save and exit if no joy have hd problem maybe need to reinstall os.
Posted on Mar 08, 2008
SOURCE:
Entering m100 bios
Two different problems stated, answering in order;
1) "entering Neoware m100 BIOS"
That would be HP Neoware m100 Mobile Thin Client, Notebook PC.
Do to the two statements back to back like that, I feel I need to explain a few things.
If not then ignore, and come back in a Comment; and set me straight.
BIOS
Basic Input/Output System.
A small program.
Used to be 64KiloByte in size, (64KB), but believe smaller now; plus it's smaller in size for a laptop anyway. (Believe 4KB)
When you press the Power On button, the plastic Power On button presses against a carbon contact switch.
The Power On switch is a Momentary Contact Switch.
Touches (Contacts) BRIEFLY, then opens back up.
Power is initiated to the motherboard.
The first chipset to receive power is the BIOS chipset.
The Basic Input/Output System program is initialized.
BIOS looks to see what devices are installed, does a Ram Memory count, turns the Processor on; and hands the computer over to the Operating System.
(Windows)
The BIOS program has a BIOS Setup utility. Most of the time just referred to as BIOS Setup.
In the old days was referred to as CMOS Setup.
B) To enter BIOS Setup (utility), watch the bottom of the monitor screen, CLOSELY; after you press the Power On button.
The proper key to press to enter BIOS Setup; will be shown.
This window often goes by F-A-S-T!
Keep your peepers glued to the screen.
Write the key down.
2) Windows does NOT like having the same build of Windows, put over it. Does not like lesser versions being put over it either.
Do to this you have to force it.
Go into BIOS Setup, and in Boot Options; set the first boot device to CDROM.
This way when you put the O/S disk in the optical drive, it forces the computer to boot from the disk.
HOWEVER, things change when trying to put WinXP over Vista, or Win7.
Awaiting reply, please post back in a Comment.
Regards,
joecoolvette
Mar 25, 2013 | Neoware m100 Notebook
How to skip bios setup
F2 is your BIOS Setup enter key?
As SOON as you press the Power On button, start tapping on the F2 key.
Tap in 2 second intervals.
You may hear beeps. These are Stuck Key Error code beeps. You know what they are now, so just ignore them.
The BIOS Setup screen goes by F-A-S-T. You have a very small window of opportunity. This is why you are tapping on the enter BIOS Setup key, as soon as you turn the laptop on.
In BIOS Setup there is an option to bypass the P.O.S.T screen.
For additional questions post in a Comment.
Regards,
joecoolvette
May 21, 2012 | Computers & Internet
My Acer will not boot up. When I turn it on, it loads straight to configuring updates then restarts and goes back to configuring updates. Its a never ending loop. i can not start in safe mode nor do i...
Sounds like you have a corrupted Windows Update. Unfortunately if safe mode is not working, then your only option is to re-install the OS. Usually Acer laptops these days don't come with recovery disks. Instead they have a recovery partition built right in to the hard drive. Check in the manual for the hotkey to press to start the system restore when the system is booting up.
Jul 06, 2011 | Acer Aspire 3680 Laptop
My son accidently shut his laptop down whilst installing microsoft office and now he has an error on startup: status: oxcoooooe9. I tried rebooting and starting in safe mode but it always goes back to...
Instead of re-installing the Operating System you can do an Operating System repair. Boot to the Windows Operating System installer disc,. If you have XP, boot to the XP installer disc then enter the setup program. There will be an option that says "Press R to Repair Computer". Press letter R then let the setup finish. For Vista/7, boot to the installed disc then select "Startup Repair" This will repair all corrupted Windows file and will keep your data intact,
Hope this help.
Mar 26, 2011 | Toshiba Satellite L305-S5908 Notebook
I Have an old HP pavillion model N3410. I am trying to access BIOS or change boot order but it won't let me. I've tried pressing f2 during reboot but it goes straight to normal windows me startup.Also...
Turn the computer off.
Hold down any key on the keyboard, and turn the computer on.
You might get a "keyboard error, press <something> to enter BIOS SETUP".
Also, instead of F2, try F1 or F10 or F11 or F12 or DEL.
Aug 20, 2010 | HP Pavilion N3410 Notebook
My laptop will not boot up, instead it goes directly into a screen I haven't seen before and says, "Operating System not found"
usually this means that the previously installed windows/linux operating system is corrupted....best to re-install operating system via disc windows/linux....so that it replaces corrupted informatiom/instructions on hard drive....if you have files you want to keep then dont do a format on install as you will definately lose them......
Jun 12, 2010 | IBM ThinkPad R40 2722 Notebook
The pc will not boot Just shows the window logo and an attempt to boot instead keep trying without actually booting
There should be missing OS file or corrupted files, Press F8 several times while you power on the PC and select safe mode, uninstall recently installed software, scan with updated antivirus and clean all the temporary files, cookies, etc. If this doesn't solve, you need to repair the windows/Operating System by using the OS Setup CD. Good luck..
Apr 26, 2010 | Fujitsu Siemens LifeBook C1020 Notebook
For no apparent reason my laptop will not now work. I turn it on and it goes through the setup system, it gives a message that it was not shut down properly, I click on start in safe mode and nothing...
First run disganostics on the system and see if you get a failure code. (Fn +Power Button on Dells) of from the F12 menu, or Boot to Resource CD. If those pass, boot to a windows XP CD, press R to enter Recovery Console, and run the COMMAND CHKDSK /R then see if the system will boot to windows. If that fails, you'll like need to reinstall Windows
Jun 08, 2009 | Computers & Internet
IBM ThinkPad
well actually your battery of your laptop has been dead and it is your software error in the window which shows your battery level full...
if not then try installing new windows....
if this does not work then reply me...
i will tell you other mothods to corrct this error...
reply me soon...
Dec 01, 2007 | IBM ThinkPad T41 Notebook
Open Questions:
See all HP Compaq Presario 2500 HP Pavilion ZE 5000 NX9010 Questions
Computers & Internet Logo
280 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
