Question about Refrigerators
Refrigerator drip Water drips down along the back of the inside of the refrigerator from the freezer. I don't know if this is related but the ice-maker no longer produces ice (this problem pre-existed the drip).
  • Anonymous Mar 27, 2014
    water dripping inside refrigerator
My SZ 550 (fridge over freezer) dripped constantly. Turned out to be a frozen drain tube, located 6 inches above the refigerator floor, centered on the back wall (cold side of refrigerator). Remove both trays and the lower glass shelf to see it. This tube runs down, behind the freezer, dumping refrigerator condensate in the pan below the freezer. If it's frozen the condensate leaks out the front of the fridge, down and onto the floor.
The fix, suggested elsewhere (not my idea) is quite simple and elegant. Thaw the tube (this will take an incredibly long time.) Fish a string (I used a piece of yarn) from the refrigerator (cold) side of the tube, down and out the other end, under the freezer. I was able to use a vacuum to suck the yarn through. Be creative. Once the fish line is in, tie a piece of nylon fishing line to the yarn and pull it through the tube. You have replaced the yarn with a stronger fishing line, which you can use to pull a piece of copper wire (I used common 14 gage romex, stripped of insulation through the drain tube. Leave the copper wire in the tube. If you wind the bottom end of the copper wire around some of the warm evaporator coils under the freezer the heat will be sufficient to keep the tube from freezing. I did this about a year ago and have had no problems since. Good luck.
Posted on Mar 08, 2008
Water dripping into the fridge, was told their might be a clogged drip tray but don't know where it is.
the drip pan is under the unit,, along the edges of some models inside, are little alleys that lead to the drip pan, sometimes they fill with ice and need to be cleaned out , look along the inside walls of the freezer
Jul 19, 2011 | Kenmore Refrigerators
Model KSRS25FGWH01-water is dripping inside the freezer ice bin.
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Nov 16, 2009 | KitchenAid Superba Architect KSCS25INSS...
Outside ice despenser is dripping, no ice
water dispenser -Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
ice maker - If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
Sep 30, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Ice maker leaking inside freezer compartment, water dripping down from unit
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
Sep 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
WATER DRIPS DOWN FROM INSIDE TOP REFRIGERATOR BELOW FREEZER
Not an original solution - but a good one. Remove panels at the back of the freezer compartment to expose the heater unit or heater wire that defrosts the freezer coils and wrap a solid copper wire gently around the heater/ heater wire and place the loose end in the drain. This will conduct heat to the freezer drain and help keep it open. I did see a manufactured part in one of the appliance parts websites but it did not match my unit.
May 29, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice maker was hot and could hear water dripping on
yes.you will have to replace the ice maker.if further used without replaceing the compressor will get damaged and you will completely loose cooling in your unit.
Mar 07, 2009 | Whirlpool ED0GTQXMQ Side by Side...
Water dripping inside refrigerator
the defoost drain is cloged the drain inlet is located in the freezer behind the back wall under the coils. to clear the drain remove the back wall in the freezer and clear the ice underneth the coils then use hot water to clear the drain inlet, I use a garden sprayer to spray hot water.
Dec 24, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Refrigerators Logo
529 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
