Anonymous Posted on Mar 13, 2010
Infocus x2 burned out new bulb in one weeks
I replaced the bulb in my infocus x2 and it burned out within a week, is there something I can test in the projector before I put a new bulb in ?
  • 8 more comments
  • Anonymous Mar 13, 2010
    The new bulb was working, but the glass cracked, I'm afraid it might be overheating. I know the fans were running when I first replaced the bulb.
    The bulb comes in a housing that makes it impossible to touch the bulb, since you replace the bulb an the housing together, its not likely that finger grease caused the new bulb to fail.
    Hi Silverdragon, do you know where I can get the service manual ? Infocus is very secretive about it's service info.
    I already replaced the bulb, it is very simple to replace the bulb, that is not part of my question.
    the projector bulb for the infocus x2 comes in a housing that makes it impossible for you to touch the bulb. My suspicion is that the fans may be weak, or some other power supply issues.
    Does anyone have experience repairing an infocus x2 projector. I have seen several threads about the power supply for the fans, changing the color wheel and fixing the light tube when it collapses. I bought a nonworking unit off of ebay so I could canabalize parts.
    how can I test and or replace the output transformer
    I need more than general help any infocus experts out there ?
  • Anonymous Mar 15, 2010
    the fans are working, I can't replace the ballast because infocus won't sell me parts, but I did buy a "nonworking" unit off ebay to swap parts with.
  • Anonymous Mar 21, 2010
    I now know the power supply for the fans died, so I bought a power supply from the thrift store for 3 bucks, the output was 12v 1.5 amps, the fans I bought were 80x20mm and 40x15, with very similar amperage ratings to the original. I wired in the new fans to the used power supply, made a hole in the case for the cord to come out, and I plugged both the direct wired fans and the projector to a power strip, so that when you turn the power strip on the fans start running. The only thing different now is that you should let the fans run for 5 mins after you shut down the projector.
Anonymous
Level 3:
  • Master 1,871 Answers
  • Posted on Mar 13, 2010
Anonymous
Master
Level 3:
Answers
1871
Questions
Helped
492344
Points
5139
Hello :
Here I'll tell you how to replace it :
  1. Make sure that your power switch is off and that the power cord is unplugged from the electrical socket.
    It is also wise to unplug any other cables and label them in order to restore them in the right way once the lamp is replaced.
  2. In order to see the lamp, remove the access handle on the outside cover. You may need to use a screwdriver.
  3. Pull out the used lamp and clean the relevant parts using micro fiber products and not paper.
    Please note that in some projectors a small inside filter should also be replaced.
  4. Insert the new lamp into the projector carefully avoiding touching the glass of the lamp itself.
    Touching the lamp will deposit skin oil that will likely damage any new lamp during use.
  5. Reassemble the access panel, repluge the cables and power up the projector.
Things You'll Need:
Warning:
  • avoid touching the bare projector lamp
good luck
rate if useful please !
Anonymous
Level 3:
President:
  • Master 1,284 Answers
Anonymous
Master
Level 3:
President:
Answers
1284
Questions
Helped
498379
Points
3271
The only part that usually will cause premature failure of the lamp would be the ballast itself. The ballast is what powers up the lamp. It can not be checked except visually for blistered capacitors otherwise its a replace item only. If your projector has air filters make sure that they are clean as well make sure any fans used for cooling are rotating.
Anonymous
Level 3:
  • Master 990 Answers
Anonymous
Master
Level 3:
Answers
990
Questions
Helped
468593
Points
2217
If this was a new bulb and burnt out for seeming no reason the most common thing will be that you touched the bulb. The oils on your skin will adhear to the glass and the bulb is hot enough to cause the glass to fail at the spot where it was touched. Be sure not to touch bulb and if you do clean with a soft cloth and rubbing alcohol. Always use tissue or soft CLEAN cloth to handle. Hope this helps. Good luck.
Anonymous
Level 3:
  • Master 3,741 Answers
  • Posted on Mar 21, 2010
Anonymous
Master
Level 3:
Answers
3741
Questions
0
Helped
974435
Points
10483
The fan is to cool the internal part of the projectors.but in your case the fans are not able to cool the internal parts so you need to keep the fan more five minutes to cool the internal parts. most probably the problem is the fan speed its not spinning that fast so its taking some more time to cool the bulb as well as other heated parts. so also replacing the fan will help.but in some rare case the wires which you replaced for power supply to fan.that wires are bit thick from original or bit thin from original.the gauge of the wire is not same.in this case the wires needs replacement other wise its the fan speed problem. This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Anonymous
Level 2:
  • Expert 242 Answers
  • Posted on Mar 15, 2010
Anonymous
Expert
Level 2:
Answers
242
Questions
0
Helped
61683
Points
726
The most common cause for burning the bulb is overheating. To get the best life and brightness you must ensure that all filters and airflow ducts in the projector are absolutely free of dust.
also, make sure the proper tools are used while changing the Lamp/ Bulb.
See the guideline from below website.
http://www.projectorcentral.com/pdf/projector_manual_2440.pdf
Pg No. - 41
Have a great day.
Rate please if it helps.
  • Anonymous Mar 22, 2010
    That is right sir, the only thing that we have to bare with it is, we are using different components for the it and all of them are not original. You can keep it that way, i mean 5 minutes is not a big deal. And sometimes using patches are better than buying complete new, right?
    Thanks
    Jimmy
Anonymous
Level 3:
  • Master 10,319 Answers
Anonymous
Master
Level 3:
Answers
10319
Questions
5
Helped
3072177
Points
30576
The output transformer for the bulb is at fault producing to much power burning the bulb out quickly
Anonymous
Level 3:
  • Master 561 Answers
Anonymous
Master
Level 3:
Answers
561
Questions
0
Helped
179121
Points
1723
Hi
Thank you for your query
This is a common problem amongst projectors, however my only key advice is that the lamp/bulb you purchase is off a high quality one, there are alot of bulbs out there which are cheap but which burn out quickly
In response to your question unfortunatley short of taking the projector apart to see if there is a power surge somewhere causing the bulb to short, there are no tests as such.
I hope this has been useful
electronic & computer repair& servicre
Level 3:
  • Master 12,061 Answers
Master
Level 3:
Answers
12061
Questions
0
Helped
4005249
Points
36390
Yes you can check out the Power supply to the lamp, this is most likely high and it shouldn't be. You will simply have to check to see if the voltages are correct at this unit's circuit board. but before doing this you simply MUST get a service manual for your set. In there you will find troubleshooting guides, and what the Voltage levels are for all sections of the set. unfortunately there can be many number of reasons that this is happening. There is never a this-is-it, this-is-what-to-do, as there are so many interconnected "Rails" and connections and it can be dow any one of the number of branches that join in and supply it. You need to check for AC "Ripple" on said rail. look for faulty Electrolytic Capacitors, (These are a prime culprit) and or failed Voltage Regulators, and or Zener/Signal Diodes. Overheated components often cause this too. Check the components on the Power board for signs of heat damage etc. I have been doing this now for over 25 years and never the two the same, oh sure some faults have a common cause but theses are all well known about and have "Other" symptoms as well that give it away. You see the "Lamp" is ONLY A SYMPTOM, of the actual problem. and NOT the "Cause". This is where us Engineers earn our "Salt" as this is where it takes the experience and instrumentation, usually an Oscilloscope, to locate and fix the unit. Now, If you find that the job is too complicated . please get a firm "Quote" for a fix before proceeding with any repair.
Ronny Bennett Sr.
Level 3:
  • Master 6,988 Answers
Ronny Bennett Sr.
Master
Level 3:
Answers
6988
Questions
Helped
2285021
Points
21993
If there is any oil on the surface of the bulb,this will happen,When replacing the bulb,do not touch the bulb itself with your fingers,if you do,and it is good to do this anyhow,clean the bulb with alcohol,because you do not know who all might have handled the bulb during packaging,or just took it out of packaging,and handled it,
  • Ronny Bennett Sr.
    Ronny Bennett Sr. Mar 13, 2010
    I would check for the fans to be running too slow,and a restriction in the ventilation also,dirt,and dust,anything that would keep the air from cooling the bulb and components.
  • Ronny Bennett Sr.
    You might try a aux fan when replacing the bulb,just a box fan to aim in the tv,and see what happens,heet is the only thing I know that would cause this problem.
Anonymous
Level 3:
  • Master 10,865 Answers
Anonymous
Master
Level 3:
Answers
10865
Questions
0
Helped
3798900
Points
33142
Hello. Generally the problem is a poor bulb, not a faulty projector socket. If you have a volt meter you can check the voltage in the socket but i seriously doubt that the problem is with the projector.
Be careful not to move the projector when the bulb is hot. When you turn it off, leave it sit for at least 30 minutes to cool as a hot bulb is a delicate bulb. Joe
I keep replacing the head lights only to have them burn out again.
make sure you dont touch the bulb with your bare fingers. touching them will make them burn out within days or weeks. use something clean, a napkin, paper towel, or similar. avoid touching the bulbs.
1helpful
My projection is in Black and White
I have seen this with a number of X1's and yes it will need to go into service and knowing what the cost of repairs was and the age of the x1 i would start looking for a new projector.
X2 projector A somewhat irregular vertical line has appeared near the middle. A slight rainbow affect at the line, right of the line gets progresively darker. The blank screen is normal. The projector is...
this projector does not have lcd's. it has a colorwheel and a light tunnel. the light tunnel has probably collapsed and needs to be replaced if you have distortion in the middle of the display. if it were to one side or the other or a the top or bottom it may have been adjustable. But wiith it being in the middle, I'd have to say you needed a new light tunnel.
Lamp burned out on X1 infocus projector, Replaced lamp, new lamp stopped working in about 5 hours, got another new lamp and it does not light at all. Still blinking 3 red blinks(saying the bulb is bad)
make sure the colorwheel is spinning. if it is not, replace it. also, blow the dust out of it with canned air. excessive dust kills lamps quickly. you'll also need to reset the lamp timer. are you using an sp-lamp-009? the sp-lamp-018 looks exactly like it, but is used in th x1a and x2. the x1 only uses the sp-lamp-009. if all else fails, replace the power supply.
Infocus x2...the bulb melts the small square lens even w/ fan on
there is more than one fan inside. one of them may not be working. also, if there is excessive dust inside, the heat won't leave. blow out all of the dust with canned air. if one of the fans are running slow, replace it. lastly, do not use an aftermarket lamp. get a good one from the comapny.
7helpful
3answers
I need a new light tunnel for my infocus X2
Was actually looking up a different problem with an X2 and came across this thread.
I do electronic repair, and often do repair on projectors with this light tunnel problem. Probably 3 a week!
I came up with a solution about a year ago. It's a tunnel peice made of highly resilient carbon fiber, lined inside with extremely reflective mirrored stainless steel.
A company here in St Louis builds them for me and I go through quite a few!
If anyone is interested, feel free to email me at [email protected]. I charge $50 per replacement tunnel (They are pretty expensive to make). Plus $10 for shipping to anyone in the US, unless you want to come by and pick it up.
I can include a extremely easy guide to install (Its VERY easy!)
These carbon fiber replacement tubes are a solid peice, unlike the factory that is just glued together mirrors :/ They are morons! haha
I've been using this replacement tubes for about a year now and installed well over 50, so I swear by them! Very resilient to heat, and very resilient to someone installing it that isn't very careful. It's almost impossible to break!
Also sale homemade LED super high flux projector bulbs for the X1, X2, and X3. May be able to build a bulb for a different brand, depending on what the current bulb is like.
These LED bulbs have a life of 40,000+ hrs and use very little power, and produce VERY LITTLE HEAT! Cheaper to build than the factory ones, at about $175 for a complete bulb with assembly. Have about the same ANSI output as the standard bulbs, I actually think it's a little more than the rated (like 50 more lumens or so~)
If interested in either, feel free to hit me up! Willing to send parts, or can do install myself.
1helpful
2answers
2 bulbs blown.
To be honest, most people who experience short lamp life on the Infocus X2 is on the genuine infocus lamps. If you read the user opinions here, you'll know what I mean. Me personally think that the X2 lamp filter some how manage to block the vents with dust which results in inefficient cooling in effect reducing the life of the lamp. The best thing to do is vacuum the lamp filters regularly and stick to cheap lamps as the oem ones on the Infocus X2 are also no good. Or better still, just replaace the bulb on it's own from here and save a lot of money.
InFocus LP630
get it from projectordoctor.com or from infocus. do not get cheap replacements. you get what you pay for.
Top InFocus Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
