Question about Technics SL-1200MK2 Turntable
Turntable setup into an hp 7590
Wondering if theres any way to plug in the red and whites from a turntable right into the back of my hp 7590 without any amplification source such as a mixer or pre amp.
i seem to be having trouble getting sound i really really dont want to have to buy anymore equip. i just purchased alot it was a long night and im brain dead so your help will be appricated.
again thanks
brandon
  • djsufx Mar 08, 2008
    ha dont even worry about it guys figured it out like i said long night bla bla bla
    thanks anyways any more problems ill lay them on ya
  • djsufx Mar 10, 2008
    awesome thanks palm beach you didnt waste your time the input situation with quality of sound was my next little prob.. but you got it so thanks again !!!
    greatly appreciated
  • 185 Answers
In theory as long as you have a sound card installed, yes you can connect your turntable direct to your computer simply by connecting it to the audio input.
You will probably need a patch lead with twin line phono connectors on one end and a stereo 3.5mm jack plug on the other end.
Please note, the turntable or phono inputs on amplifiers are unlike all the other inputs, because they have a particular frequency response tailored for use with a headshell cartridge.
If you connect your turntable to an input that has not been tailored to the RIAA response curve, it will sound tinny. This is what probably happens when you connect to your computer. The input may also not be sensitive enough.
You may be able to adjust the frequency response if your sound card includes an equaliser. Alternatively, you may be able to download some audio software that will allow you to equalise your turntable.
All in all though, I'm sorry to say you would be better off with an outboard preamp.
Posted on Mar 08, 2008
  • Palmbeach
    Palmbeach Mar 08, 2008
    Guess I just wasted my time then...
3 wires were taken off the turntable Sharp
The RCA plugs are the Right (red) and Left (white) sound channels.
The 3 thin wires are the power connect. It's likely this will only fit one way into the unit, unless you have broken or cut of the connector. One wire will then be the + wire (under 12volts DC) the other - wire and the other earth. As long as the wires don't touch each other all that will have is the turntable will go backwards if the - wire is connected to the plus terminal.
The phono plugs reversed will simply switch the left sound coming out of the right channel etc...
Dec 17, 2012 | Audio Players & Recorders
I have a Technics turntable Model: SL-BD22-KM, Ser.#: GF3Fc73813. The RCA and ground connection panel on the turntable has been jurked-out tearing the wires apart. I need to know which wires are soldered...
hi,
Here is the wiring of the turntable RCA plug ( RCA wire will have 4 connections like red and its outer wire then White and its outer wire.). connect these as follows.
For right channel
Red wire from the turntable to the red center wire of the RCA plug
Green wire from the turntable to the outer wire with red wire of the RCA plug
For left channel
White wire from the turntable to the white center wire of the RCA plug
Blue wire from the turntable to the outer wire with White wire of the RCA plug
OK
Oct 10, 2011 | Technics SL-BD22 Turntable
Hi, I have just reconnected my sl-bd22 turntable into the main unit but there is no sound coming out of the speakers, I was wondering if I am supposed to have a transforer plugged into the 2 way (red &...
What, no manual? WHAT Main Unit? You're not telling us anything we can use. Details IN = Details Out.
Join http://www.vinylengine.com/ for free and get the manual.
This is an old school turntable so it requires a Phono Pre4amp either separately or built into your 'Main Unit". It will be labeled explicitly "PHONO".
Sep 02, 2011 | Technics SL-BD22 Turntable
I have vestax 05pro2. Left channel works but out of one speaker. The turntable input is good. Im thinking Its either the channel fader, or the rca inputs for that side. Has anyone had this problem?
Here's a solution to see if you have a problem with either your receiver or turntable.
The turntable has 2 RCA's one red for right channel, and one white or black for left channel, which plug into the back of the amplifier.
  • Unplug both RCA from rear of amplifier.
  • Plug in a cd or dvd player into those inputs on the amplifier, the sound will be lower but it will give you an indication if the amplifier is ok or not.
  • If you have sound on both channels left and right then the amplifier is good
  • If you still only have sound on left channel, then there is a problem with the right channel input on the amp.
  • If your amp, is good, unplug the cd /dvd player.
  • Put a record on and start playing the record
  • Plug the white or black RCA from the turntable into the rear of the amplifier marked left, you should have sound.
  • now unplug it from the left and plug in into the right red RCA socket, if you have sound the amplifier is working fine.
  • if there is no sound there may be a problem with the stylus cartridge on the turntable
  • now lets reverse the test
  • unplug both RCA from amp.
  • Plug the red RCA into the left socket on amplifier, if there is sound, turntable is working fine, if no sound there is a problem with either the stylus cartridge or that red RCA cable.
  • now unplug the red RCA from the left side and plug it into the right side socket
  • if there is no sound there may be a problem with the stylus cartridge or RCA cable.
I hope this helps
MobileJB
Jul 15, 2011 | Audio Players & Recorders
My Pioneer PL-990 Turntable only outputs sound through the white wire. Only a quiet buzz comes through the red wire.
The red wire is the right channel, so going back to your amp, get a single phono plug with with the wire exposed, so you can touch the wire. Then remove the turntable connections. With the amp on plug the the lose wire plug into each channel and check if the sound on the right is still low. If it is then there's a problem with the magnetic cartridge pre-amp inside the amp. They are often located near the phono socket on a seperate PC board, but if not just follow the red wire to the main board. Chances are it will be an IC that's failed.
If it has a strong buzz at the back of the amp. Then I should replace the wire between the turntable and the amp. Or the right phono plug that connects to the amp.
Nov 13, 2010 | Pioneer PL-990 Turntable
Hi I have a Technics SL-350 Turntable System that I bought at a tag sale today. It turns on properly, spins, and you can even slightly hear the sound of the music while it's spinning. However, there is a...
plug a red and white rca cable into the back of the turntable and then plug the other end into your phono output at the back of the amplifier.then turn your selector on your amplifier to phono.wowla you should have sound
Oct 17, 2010 | Technics Audio Players & Recorders
Can I hook up a photo turntable to a sony str-de435 receiver? There aren't any jacks that specifically say phono, so I'm wondering if I can just hook it up to any of the audio jacks without any problem....
If your turntable has an amplified output, go ahead and plug it in to the aux port. If not, you won't be able to use it with your receiver properly. Look on the back (or front) of your turntable for a knob labeled "level" or "volume", and that will determine if it's amplified or not. Good luck, I hope this helps!
Oct 19, 2009 | Sony STR-DE435 Receiver
Tonearm not emitting signal into Serato
there is a switch that cuts off the signal when the tone arm docks.check the wiring is not broken inside and that the switch is ok.typically,red green white black red and white are plus and left ground is green and right ground is black.the collar that screws on to the head unit has 4 pins.make sure the contacts are clean.measure the wires one at a time from the tone arm to the rca plugs on the back.the green and black go to the outside collars,and the red and white go to the center pin of the rca plugs
May 26, 2009 | Technics SL-1200 Turntable
Technics SL-1200MK2 Turntable Logo
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
