Question about Sony PlayStation Portable (PSP) Console
Cant browse memory stick contents in usb mode
The psp connects just fine when you enable usb mode, the pc recognises the connection and opens the contents in new window. however as soon as the window opens no contents or directories or folders are shown, plus the pc reports the incorrect size of the memory stick drive and sees it as a FAT32 storage drive of 888Mb. i have 4 psps all with version 5.71 but only one has this most annoying problem.
furthermore i have a downlaod allpication for the psp which does not see the memory stick drive when the psp is connected.
even though one this psp is in usb mode a drive icon for the removable disk is shown and the folder can be opened(showing empty) no files can be copied to the drive.
  • 3 more comments
  • spongeboob Mar 08, 2008
    forgive me for posting my own fix to this problem but i must point out that i was led to this discovery as a result of advice given by
    DiZzY21
    under a very correct fix for a similar disturbing problem and have used the logic to fix several problems on my PSP's since
    i have realised that a whole range of problems to do with PSp are related to firmware settings, for some reason these can become corrupted or may differ to the settings that allow the psp to run as expected, especially when non sony approved upgrades ( or downgrades) are applied.
    the solution is as follows:
    shut down psp by holding power button for 4 - 10 seconds or until the power light goes off.
    power up again holing down the R button, this will enter recovery mode.
    use arrow pads to scroll down to configuration, press X
    check that XMB USB device is set to memory stick,
    if it is not, scroll down to XMB Usb device and press X repeateadly until memory stick is selected.
    select back
    then exit recovery mode.
    ( i should point out i have 4 PSP's all with version 3.71 not 5.71 as previously incorrecly stated) and each have exihibited a range of silly and annoying problems,
    (particularly after I my let my pre-school aged children play with them! when important work needs to be done in a child free environment around the house. :-) )
    All problems so far that i have encountered have all been traced back to settings that can be accessed via recovery mode (start up and hold R button)
    i think that most PSP problems relate to the settings under this menu. i am trying to get a list of the ideal settings for this menu which as soon as i've figured out what they should be i will post on this forum.
    If only i knew now how to prevent the little blighters from deleting the games and saved games from the memory stick so that i am not constatntly spending time loading the games and backing up my progress in the games i want to play.(very slow process) even though i have my own memory stick with my stuff on it i always manage to get caught out, its as if they know just when to delete my stuff. !!!!
  • spongeboob Mar 10, 2008
    hi Yogavignesh
    make sure you shut down psp by holding the power off untill light goes out, or approx 4 - 10 seconds.
    then restart holding down the R button, psp should enter recovery mode.
    if it does not
    try removing batteries for a few hours, then try again.
  • djyzn Apr 30, 2008
    i can't go to configuration holding R does not work.
  • Anonymous Jul 19, 2008
    i hav d same problem here.. any other troubleshoot?
  • LiLDaNE Jul 20, 2008
    hey i have tried that think by shutting pspoff completly for 4 to 10 secs and then turn it on holding down R button when you turn it onand it wouldnt enter the recovery mode so if no any other way tell me
My psp memory sick got brok by me dowloading a scarface game on my memory stick without me knowing when i went out of usb mode i had a lot of memory on my memorycard i really dident know how i did it but eneywase i had and currupted data on my psp so i erased it and it took a wile so i cut my psp off and when i cut it back on i had no more memory left t deleted everything on my psp i cant even get in usb mode when i try i gata go throu manuley treo my computer and things popted up like i gata format my psp and i clicked it and it said erra
Posted on Aug 30, 2008
Ha!! best solution to my problem....never knew that recovery mode existed :) :) :)
thanx a lot
Posted on Jul 19, 2008
My psp does not open recovery menu..... what can i do... i tried your suggestion of holding R+power button ... but it wont work
Posted on Mar 09, 2008
My psp can upload pictures and music..but when it comes to videos..it just doesnt work..i do everything right and when i put a video on my psp it would take up the space but still no video at all is stored n my media section.what am i doing wrong?
Posted on Mar 08, 2008
How to download in psp games
1. CONNECT YOUR PSP TO PC
The PSP can function as a USB Memory Stick Duo reader. Using this functionality, you can copy pictures, audio, and other content to and from your Memory Stick Duo. To access the Memory Stick Duo in your PSP from your PC, you'll need a USB cable that has a "Mini-B" connector (common for digital cameras) and a "Standard-A" connector (common for printers, etc). Plug the Mini-B side into the top of your PSP and the Standard-A side into your PC. From the PSP software, navigate to the top of the settings list and select "USB Connection." Your PC (Windows/Mac/Linux) should detect a new "Removable Disk Drive" that you can then access.
2. TRANSFER SAVE GAME TO "SAVEDATA" FOLDER
Just copy the folder you have just extracted, and paste it into the PSP's "SAVEDATA" folder. But, BEWARE!, to any folder overwrite warnings! Because the PSP save game folders use the same names for the same games, copying folders into these locations could lead to lost data. For this reason, we recommend that you backup your old save games before overwriting them. For Example, I would simply rename a folder like "ULPS0004" to "ULPS0004_backup."
3. EXIT USB MODE
Because your PSP has been in USB Mode throughout this process, just push X to exit. Then you can safely disconnect your PSP from your PC.
download the games here as many as you can for free
http://www.pspmaniaonline.com/
Say "Thanks" by clicking the thumb icon in the post that helped you. Please click "YES" in solution that solves your problem as "was this helpful?"
Apr 18, 2011 | Sony PlayStation Portable (PSP) Slim...
How to download games
3. EXIT USB MODE
Apr 13, 2011 | Sony PlayStation Portable (PSP) Console
How to download from the computer to psp?
3. EXIT USB MODE
Apr 12, 2011 | Sony PlayStation Portable (PSP) Console
How to download psp games into my pc
Hi there, I came across an article which explains how to transfer PSP Data to your PC.
FORMAT YOUR MEMORY STICK
In order to be able to use your new memory stick on your PSP, you'll have to format it. When you format your memory stick, the formatting will create a set of new folders on your PSP: GAME, MUSIC, PHOTO, and SAVEDATA.
EXTRACT THE SAVED GAME
This process will greatly depend on which software you use to extract zip files. WinRAR for instance offers the "extract here" option, which will simply extract the contents of a zip file to it's current directory.
EXIT USB MODE
VERIFY TRANSFER OF SAVE DATA
To verify the integrity of the SAVE GAME data you have just transferred, use the PSP's built-in Save Data Utility. Select it from the "Game" menu.
Jan 01, 2011 | Sony PSP (Piano Black)
How to make download games from computer to psp
Hello
EXIT USB MODE
That's it, simple and smooth.
Oct 12, 2010 | Sony PSP (Piano Black)
My computer cant recognize my sps
Before you plug it in,
Make sure the PSP is in USB connect mode.
Also make sure the Memory Stick PRO Duo has been formatted for PSP. If it's not this is how you do it:
On the main menu, scroll all the way left to the "Settings" menu. Then select "System Settings." Then scroll to "Format Memory Stick" and press X.
May 24, 2009 | Acer Aspire 5500 5570-2609 Laptop
Pc unable to reveal content of mem stick on psp
You need to format the memory stick on the psp by going to system settings -> format memory stick,
Jan 25, 2009 | Sony PlayStation Portable (PSP) Console
Hey i have prob in iso games
STEP 1: CONNECT YOUR PSP TO PC
STEP 2: FORMAT YOUR MEMORY STICK
STEP 3: EXTRACT THE SAVED GAME
STEP 4: TRANSFER SAVE GAME TO "SAVEDATA" FOLDER
STEP 5: EXIT USB MODE
STEP 6: VERIFY TRANSFER OF SAVE DATA
Oct 16, 2008 | Sony PlayStation Portable (PSP) Console
Psp
* Make sure you have inserted a memory stick, and enable the usb connection via settings=>usb connection
* Check the usb cable, or simply find another one to try if it works.
* If there is a memory stick inside the psp and the psp can recognize it, then you most probably have a problem with your cable or usb port.
* if there is a memory stick inside the psp and the psp cannot recognize it, as well as the computer, then you are most likely to have a failure with your memory card.
There are too many possibilities, maybe you can give me details straightaway, so more people can help you.
Dec 26, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
685 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
