Question about Dishwashers
Replacing copper tubing with a flexible hose for water connection
I am replacing an older dishwasher that used copper tubing as a water connection. I would like to replace that tubng with a flexible hose connection. How would I accomplish that?
  • 247 Answers
Go to a place that sells plumbing supplies.
There, you will be able to buy an appliance hose and the fitting which is usually used to plumb these into the domestic water system (a stop valve with a compression fitting for hard tube on one end and a thread to take the hose on the other).
If you're replacing you're old machine with a new one, all you'll need to do is to trim the existing tube at a convenient place (with the water supply turned off) and fit the new stop valve. New dishwashers usually come with a hose, and that just screws onto the threaded end of the new stop valve.
Hints: The hose seals onto the metal fitting using a rubber washer that just sits between the two faces. This system works really well provided you don't try to "help" it with PTFE tape or anything like that. Moistening the threads with a drop of water to lubricate them sometimes helps, but then all you need to do is to assemble the joint (checking the rubber washer hasn't dropped out) and do the plastic nut up finger tight. Check it for leaks when you first use the machine. If it's all right for the first five minutes, it'll be all right for ever.
If you're trying to put your old machine back in, but with a hose to make it easier to move, you will need a second fitting with the same combination of connections as you used to connect the hose to the household plumbing - you may be able to get one without a built-in stop valve, but if you can't it doesn't really matter. Proceed as before, but attach a short stub of the tube you trimmed out in stage 1 to the inlet of the machine (using the existing coupling) and make the new fitting off to that.
A.
Posted on Mar 08, 2008
How do i turn off the water supply to the fridge if its pipe is leaking?
There should be a small valve behind the fridge. Pull it out from the wall, and look behind it with a flashlight. They are usually near the floor at the wall. Turn clockwise to close it. In older homes, the water line can be run under cabinets to under the kitchen sink where water pipes are..
Old installations use 1/4 inch copper tubing. Newer ones use 1/4 inch nylon. Some use flexible white hoses.
If you close the valve and it still drips, then the entire water system will have to be closed off to replace the valve. These valves and new connection kits are available at sears, home depot and lowes.
Jan 08, 2011 | Maytag MZD2766GES Side by Side...
Whirlpool dishwasher Leaking water
Hello there:
Troubleshooting Leaks
If the dishwasher leaks, and you know the problem is not related to tub overfilling, the pump, or inlet valve problems, the plumbing connections may be faulty. Most dishwashers are connected to the water supply with metal pipe fittings, and the leak could be at these fittings. If the fittings are threaded, tighten them with an adjustable wrench. If this doesn't work, chances are the threads are stripped or the fitting is cracked or otherwise damaged. In this case, replace the fitting.
Most dishwashers discharge used water through a pipe or a hose connected to the drain or garbage disposer under the kitchen sink. If the drain line is made of flexible hosing, it may have cracked from prolonged exposure to hot water. Examine the hose; if it's damaged, replace it. If the hose is leaking at its connections with the disposer or dishwasher, tighten the fittings or clamps at the connections, or replace the clamps. Also check for water leaks around inlet valves, drain valves, and anywhere you see flexible hoses and hose connections. Leaks at clamps can be stopped by tightening or replacing the clamps. Leaks in hoses can be eliminated by replacing the hoses.
I HOPE THAT YOU FIND THIS INFORMATION VERY HELPFUL
BEST REGARDS MICHAEL
Nov 13, 2009 | Dishwashers
Water is leaking from water hose at bottom of frige when water handle is depressed. Ice maker works.
If your hose is copper or plastic, this is a common problem.
I reccomend replacing it with a stainless steel braided, icemaker line. They are more flexible and less prone to leaks.
Oct 03, 2009 | Kenmore 53542 / 53544 Side by Side...
Refrigerator Water Hose
copper is best with compression fittings, just install an in line filter
Sep 29, 2009 | Refrigerators
Water leak at filter
I had this with a Kitchenaid Superba and wanted to get rid of the filter holder assembly entirely as I have an undersink unit which serves the fridge. I removed the plastic line (nut) at the back of the fridge (which led to the filter holder at the front) where the flexible copper tubing inserted (this was a 3/8' compression fitting-plastic) and also the returning line (1/4" copper compression nut on a plastic line) at the manifold (again in the back of the fridge) where it gets split between the water line and the ice line. I then just connected the 1/4" flexible copper directly to the manifold (1/4" nut, compression sleeve, male-male connector) using a pre-made 1/4" flexible compression line. Sounds complicated but after seeing how the water routes it was fairly quick work.
Dec 02, 2008 | Whirlpool GS6NBEXR Side by Side...
Lots of tiny bits of rubber flakes have comeoff door seal and are stiuck to washing
hi Most dishwashers discharge used water through a pipe or a hose connected to the drain or garbage disposer under the kitchen sink. If the drain line is made of flexible hosing, it may have cracked from prolonged exposure to hot water. Examine the hose; if it's damaged, replace it. If the hose is leaking at its connections with the disposer or dishwasher, tighten the fittings or clamps at the connections, or replace the clamps. Also check for water leaks around inlet valves, drain valves, and anywhere you see flexible hoses and hose connections. Leaks at clamps can be stopped by tightening or replacing the clamps. Leaks in hoses can be eliminated by replacing the hoses.
Sep 13, 2008 | Washing Machines
The water does not drain out. Water in tub bottom
Sep 13, 2008 | Amana Dishwashers
Dishwasher leaking at the bottom of the door during operation.
hi If the dishwasher leaks, and you know the problem is not related to tub overfilling, the pump, or inlet valve problems, the plumbing connections may be faulty. Most dishwashers are connected to the water supply with metal pipe fittings, and the leak could be at these fittings. If the fittings are threaded, tighten them with an adjustable wrench. If this doesn't work, chances are the threads are stripped or the fitting is cracked or otherwise damaged. In this case, replace the fitting.
thanks....................
Sep 12, 2008 | Whirlpool Dishwashers
Dishwasher holds water
if you dishwasher holds water that means the plumbing connections may be faulty. Most dishwashers are connected to the water supply with metal pipe fittings, and the leak could be at these fittings. If the fittings are threaded, tighten them with an adjustable wrench. If this doesn't work, chances are the threads are stripped or the fitting is cracked or otherwise damaged. In this case, replace the fitting.
also it may be due to faulty pump
Servicing the Water Pump
In most dishwashers, the water pump is located under the lower sprayer arm. This component pumps the water through the dishwasher. The pump has two impellers, top and bottom. These, as well as other components, can become clogged with food or detergent. Here's how to disassemble the pump:
Step 1: Remove the cap that holds the sprayer arm on.
Step 2: Remove the sprayer arm, the screen, the pump housing, a bolt, the upper impeller, the food disposer blade, a spacer plate, the impeller hood, a flat plate, an O-ring, and the lower impeller. Lay the parts out in order as you disassemble them so that you'll be able to reassemble them properly.
Step 3: Clean the parts thoroughly with a mild detergent solution. If any parts are worn, replace them with new ones made for the dishwasher.
Step 4: Replace any seals, such as the O-ring or other washers, with new ones.
Step 5: Reassemble the pump, keeping the parts in order.
To reach the water pump, remove the sprayer arm and screen and then the pump housing. Remove the bolt, and the pump components can be disassembled.
On some dishwashers, the lower impeller serves as a drain pump. This type of system usually has a reversible motor; machines with nonreversible motors have drain valves, as detailed previously. If your machine possesses this impeller pump system, and the water will not drain from the dishwasher, clean the lower pump impeller. This may solve the problem. Otherwise, call a professional service person.
Sep 06, 2008 | Dishwashers
Dishwashers Logo
2,722 people viewed this question
Top Dishwashers Experts
