How long have you had it plugged in and did you lay refrigerator down during the move? Sea Breeze
OK Thanks for your reply. Sometimes this is the hardest place to get someone to answer. I will need to continue through the Q&A process to eliminate different things so please have someone to go through that process with me. If your refrigerator is cooling at all would be good to know but seems you mentioned no ice and above 5 degrees the ice maker will not work and 8 days plugged in then the refrigerator must b e cooling a little. Would you please pull the refrigerator away from wall and unplug, remove compressor cover area feel the top of the compressor for warm to cool or too hot to keep your hand there. I need to know if it is doing something we call short cycling. That is when they start cooling a little and then overheat. I'm going to leave my contact information. appliancepartsse(at)yahoo.com If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
Thanks, Sea Breeze
Can you answer those questions for me? I will be ready to help now or later. This movie below is what happens when Freon leaks. And If your compressor runs and stops and gets hot we need to check compressor start components. Sea Breeze
Replacement parts can be
purchased at any of the following web sites:
searspartsdirect.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts
directly.
Go through this troubleshooting help links.
This is list of refrigerator problems,
which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly
in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on
refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
It was not layed down at all and was unplugged for about 4 hours. We have had the refrigerator plugged in for 8 days now.
