Question about Hobart HEC501-208V Electric Single Oven
Hobart HEC40 208V to a 240V source
I have a HEC40 Hobart 2 Dec oven. My electrician says it is a 208 volt but we ahve 240 volt in the building. Can a 208v oven be hooked to a 240v system? Is there a wiring change in the HEC40 that will allow it?
    Scholar:
  • 68 Answers
The only difference should be the elements. Consider installing a buck-boost transformer. It may be cheaper.
The Hobart part number for the 240 volt element assembly is --
# 342170-00002. Your local Hobart can get you a price.
Posted on May 03, 2008
Blodgette issue convection oven 208/240 60Hz haveing issue with plug over heating what size breaker should i use 20 or 30amp. Wiring is on a line seprated. What gage wire should i use.
Check the manufacturer's website for the manual. If the cable is getting hot, the wire gauge is too small. 30A needs a 10G wire, 40A needs a 8G wire. Again, check the manufacturer's website for the manual. If you are not sure, call an electrician. Be safe!
Dec 21, 2016 | Ovens
Imperial icve-1 standard depth 208/240 volt connextion help
Are you in the EU or US and can you be more specific, it is fairly straight forward. If in doubt get a professional to connect it for you.
Apr 10, 2014 | Imperial ICV-1 Turbo-Flow Single Oven
Can I use the existing 40 amp double pole breaker?
Rule of live by: Each unit must have its own breaker. Cooktop needs 30 amps and a double oven needs 40 amps. Never combine the unit as the amps flow if too high can cause the wires to melt. I hope this helps. Be safe!
Sep 13, 2012 | Thermador Ovens
I am looking for self cleaning instructions for a GE oven. MOD. VJ33VWLW-3 SER.ZH273130 VOLTS 120/208 KW 8.6 120/240 11.4 LR 27 TYPE B45 CAMCO INC. Made in...
You should have a selector knob turn it to clean then lock door with lever in the front select hrs on the timer should start up
Sep 18, 2011 | GE Ovens
Do i need to hard wire a single oven
Welcome to FixYa.
You don't HAVE to hard wire, you can install a regular oven plug and receptacle outlet, but this is the recommendation of Bosch.
**Before installing the oven have a qualified electrician verify that your home is provided with adequate electrical service and that the addition of the oven will not overload the branch circuit on which it is to be installed. A separate three-wire or four-wire single phase, 240 Volt, 60 Hz., or a 208 Volt, 60 Hz. branch circuit is required.**
I'm not sure how clear this will come out when I post it, so if it is not acceptable let me know. I can send you the complete installation guide "pdf" via email if you post an email address.
I'll watch for your reply, good luck. Thank you for choosing FixYa today for your inquiry.
Regards,
Macmarkus :)
Jan 09, 2011 | Bosch HBL 442 / HBL 446 Electric Single...
No power to oven element changed thermostat bypased oven timer
Call the manufacturer, the oven will have a high limit thermostat, it could be tripped. Check for burned wires, Sounds like you have a meter. DO NOT check the voltage to ground, but check it between the 2 element wires. It should read around 208/240 volt If you dont get that voltage, there is a burned/shorted wire
Apr 11, 2010 | Ovens
Kitchenaid oven model #KEBC207
this was taken from the installation guide
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=kebc207&siteCd=WHRCOM#installation_instructions
Oven must be connected to the proper electrical
voltage and frequency as specified on the
model/serial rating plate. (The model/serial rating
plate is located on the oven door or on the oven
frame.)
Models rated from 7.3 to 9.6 kW at 240 volts
(5.5 to 7.2 kW at 208 volts) require a separate
40-ampere circuit. Models rated at 7.2 kW and
below at 240 volts (5.4 kW and below at 208
volts) require a separate 30-ampere circuit
Nov 15, 2008 | KitchenAid KEBC207 Electric Double Oven
Wattage for oven pleb30s9fc
  • Connected Load (kW Rating) 240/208 Volts: 3.5/2.6
  • Amps @ 240/208 (Approx.): 14.6/12.6
  • Minimum Circuit Required - Amps: 30
  • Bake Element Wattage 240/208 Volts: 3400/2554
  • Broil Element Wattage 240/208 Volts: 2750/2065
  • Armored Electrical Cable
What kind of wires did you buy?
Jul 25, 2008 | Frigidaire PLEB30S9DC Electric Single Oven
Hobart HEC501-208V Electric Single Oven Logo
561 people viewed this question
Top Hobart Ovens Experts
Craig Butler
Craig Butler
Dan Webster
Dan Webster
Gil Shultz
Are you a Hobart Oven Expert? Answer questions, earn points and help others
