Question about Canon PIXMA iP4200 InkJet Photo Printer
Ip4200 ink cartridge problem
I installed new cartridges in my 2 year old printer but the magenta cartridge doesn't work. Bought another Canon cartridge, but I still get an unblinking red light above the cartridge. The printer won't print anything, even documents with no color. What can I do to convince the printer it has ink? JC Juneau, Alaska
    Master:
  • 555 Answers
Is the replacement a "genuine Canon™ Ink Cartridge," or a generic? Sometimes the little chip on the generic cartridges don't communicate with the printer properly, and the printer decides that the ink cartridge is bad.
Posted on Mar 08, 2008
  • Canon Master
  • 19,396 Answers
You need to clean nozzles / heads. first try using the option to clean nozzles from windows, either in printer options or in Canon control panel.
  • Ginko
    Ginko Mar 08, 2008
    Do clean nozzles a couple of times from system.
    If this still does not work, you will need to open the printer and clean the obstructed magenta head manually.
    Best regards
    Guru:
  • 1,894 Answers
Hello
  • dewan nafees ahmed Mar 08, 2008
    are you sure the cartridges are compatible with the printer??
I have a canon IP 4200 printer. The ink cartridge light on the Magenta ink cartridge doesn't work so it won't accept/recognize that a new ink cartridge has been installed. Is this something that...
It sounds as though you have a break in the carriage ribbon cable. A new carriage would hopefully cure it but its just possible the logic board has failed and is not sending any signal to the magenta ink tank. Its certainly repairable but you would need to know the costs and the labour charge to see if its worthwhile.
Aug 27, 2011 | Canon PIXMA iP4200 InkJet Photo Printer
Canon Pixma yellow color problem
Either the ink you are using is not going to give the color you want, or you have print heads that are blocked.
Mar 11, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
Cartridges don't work
Sounds like you got a defective cartridge, it happens once in a while. On some Canons, you hold the resume button for 5 seconds and it will ignore the error, not sure on your model printer.
Jul 03, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Printer won't recognize the new ink cartridge
Each cartridge has a electronic chip pre-porogrammed at the factory.
If it is a reputable store they will exchange for the right color as they can return the PM to Canon as defective,
Mar 27, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Canon ip4200 one cartridge/nozzle does not work
Put isoproply alcohol on the nozzel with a connon swab until it melts(desolves) the drived ink.
Feb 07, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
More than one ink tank (yellow) is inserted
The best solution for me is to get rid of the printer. If not South Africa, your assistant plans could maybe work for me. the problem is the exchange rate between SA Rand and $.
Thanks for the suggestion
Sep 21, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Canon pixma ip4500
u should carry the printer to Canon Care Centre, they will check the case and if found that the Cartridge u r using is Genuine your Cartridge will be replaced.
Regards,
manoj joseph
+91 9352008418
Jun 15, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Only Prints in Magenta
The cartridges may still be at fault, or there is a problem with the processor board in the printer. I have also seen problems with the ink jets in these.
Jerry G.
Apr 19, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Only prints in magenta
if your cartridges are new one then do this, reinstall printer driver and check in the printer driver features that you have selected print in black and colour option
Apr 02, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Magenta ink colour
I had the same problem. Try cleaning the print heads. They tend to clog. Remove the cartridges, then remove the print head. Tilted slightly, it comes out easily. Run very warm to hot water over the print heads until they all run clear. Use a turkey baster to apply strong pressure to each head until it runs clear. Blow off the excess water with mouth or blow dryer. Insert into the printer and proceed to print. If that doesn't solve it, you might have a bad cartridge, but there isn't much that can go wrong with the cartridge. I have an ip4200 and an MP830. They have the same print heads and same cartridges. I have cleaned each twice and they work like new.
Sep 10, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Canon PIXMA iP4200 InkJet Photo Printer Logo
146 people viewed this question
old marine
old marine
