Question about Whirlpool AWM6100 Front Load Washer
Whirlpool AWM6100 - Will starrt but then just stops part way through the cycle
This will happen several times during a cycle - we've tried runnning it without washing and it seems better but then put the washing in and it plays up again. Appreciate any help
  • After Dark Mar 09, 2008
    greendude - the fault is that when we load the machine and close the door and press the start button it starts and runs for a few seconds and stops. Pressing the start button again gets it underway but it has started to stop a number of times through the cycle - hope this helps - Graham
  • Ian Greenland May 11, 2010
    what is the fault
    Sergeant:
  • 351 Answers
It may be the door switch cutting out if you push on the door does it start.does the water come in before it cuts out.will it work on spin or does it cut out as well.if its only on wash it may be a valve problem.are both the taps turned on.its hard to know without being there.hope this is helpfull.Ian.ps you may have a board fault.
Posted on Mar 10, 2008
Why would a whirlpool duet sport model number WFW8300SW05 starts fine stops during cycle. No error codes door locked red light on water in machine.
you have a plugged or partial plugged drain pump for sure. maybe there is a 20 stuck in it this time! easy to find just follow the drain hose back and you will find your pump.
also could be the cycle your using has a bad area in timing cct. check a different cycle like the delicate cycle and that will confirm pump or cycle
Jun 10, 2014 | Washing Machines
Door open flashes during rinse cycle - does not continue cycle even when we turn the power on and off
sounds like you have a faulty door lock sensor i would have it replaced
in most of our repairs regarding this problem it fixes the issue ,
good luck
Jul 22, 2010 | Whirlpool AWM6100 Front Load Washer
Whirlpool AWM 5080 stops during cycles
Sound like could be faulty pump however you need to make sure no
Could be pump at fault 1st you need to make sure no coin stuck in there ...
Mar 31, 2010 | Whirlpool AWM6100 Front Load Washer
Whirlpool AWM6100 front loading - door open when not!
it's probably the innerlock, is the door locked?? if not it could be the innerlock
Mar 09, 2010 | Whirlpool AWM6100 Front Load Washer
My Whirlpool washing machine AWM6100 is weird. it washes no problems but when it comes time to drain there is an awful noise any idea? it does drain and spin its just the noise
you may have something stuck in the drain pump that is rubbing or grinding on the impellar wheel
check for any obstruction in the drain pump and the hoses that led in and out of the drain pump.if you do not find anything then you may need to replace the drain pump. as long as this noise only happens in the drain cycle.
Feb 09, 2010 | Whirlpool AWM6100 Front Load Washer
Whirlpool AWM6100 Front Load Washer Logo
148 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
