Problem with LG WD-8023FB washing machine
The machine makes a loud grinding noise each time it changes direction while washing, more so on short cycles. Thanking you Diesel Dog
  • 5 more comments
  • diesel dog Mar 10, 2008
    The machine does not make any noise while spinning. The noise is always on a short cycle and with heavy items in the machine.
    It has nothing to do with the motor.
    The bearings are not gone, something I have noticed is leaking oil around one of the shock asorber suporting the outer plastic case, but if this was faulty it would not spin and there is know problem with it spinning.
    This washing has made this noise since we purchased it but it has progressively got worse. The washing machine was purchased second hand supposed to be only 3 months old and it has not done much work. I would like a exploded view of this machine which I think would help me. This machine is only about 18 months old now.
  • diesel dog Mar 12, 2008
    I think I have solved my problem. I put some belt dressing on the belt and the noise has gone for now,so I hope my problem has been fixed.
    No the manual did not help at all
  • Anonymous Mar 16, 2014
    When the machine, is connected to the mains supply, it gives a musical chime, however the display is dead. Play with the program start button, and the display becomes activated and you can then continue with the wash.
    The problem now is, even messing with the program start button, the display remains dead.
    I think the problem is with, this start button, or is there anything else that can give this problem
    Thanking you in anticipation.
    John
  • 790 Answers
Hello sir,
  1. If a washing machine is rumbling, and very **isy on spin, the main suspect is the drum bearings. Drum bearing failure is common on many washing machines due to water getting into them if the drum bearing seal fails. To check for drum bearing failure you can take the belt off and spin the drum by hand. If the drum rumbles when spun then the bearings may have gone. There should be a constant rumble all the time the drum is revolving.
  2. A**ther drum bearing failure symptom is excessive up and down play in the drum which can be checked for by lifting the drum up and down from the drum lip behind the door seal. A further symptom of drum bearing failure can be a brown rust patch underneath the washing machine and down the back of the outer drum, underneath the drum pulley (where the belt goes) although this patch is **t always present. There are usually two small holes at the back of the drum bearings where water that has got past the drum bearing seal trickles out, and it's usually stained with grease and rust if water has got into the bearings.
  3. Loud **ises when turning the drum by hand can also be caused if the drum itself splits, or the spider at the back of the drum has come away from the drum, is corroded or even broken. This would **rmally be a loud **ise on each revolution of the drum whereas the **ise when drum bearings have gone is constant all the time the drum is turning. Lifting the drum checking for excessive play can often reveal a broken or loose drum spider which sometimes only occurs at certain points round the drum (the spider has three arms and is bolted to the drum at three points)
  4. Coins or other obstructions trapped inside the tub under the drum can make horrendous **ises as they get tossed about on spin. They often don't make the **ise unless laundry is in though. Look out for obvious dints and creases in the drum itself as evidence of a coin or similar stuck inside although be aware that it only shows there's been an obstruction in at some point and the coin could have fallen into the sump hose or filter and **t actually be the cause of the **ise at this time
  5. Other causes of a **isy washing machine are coins and other obstructions inside the water pump. This will cause **ise when the washing machine is emptying the water. Coins or other obstructions can get trapped between the outer tub and the inner drum. This would produce a lot of **ise on spin as the coins get tossed around inside. Often, spinning the drum by hand will **t reproduce the **ise in the case of coins because the coins drop to the bottom of the tub and lay flat when the washing machine isn't spinning
  6. A light scraping or ratchity **ise when the drum is turned by hand is commonly a bra wire trapped between the tub and drum. They can often be removed from underneath with the sump hose taken off. It's always worth checking that the wire isn't poking through one of the holes in the drum which can be pulled back out from inside the door. It's rare, but I've retrieved 3 or 4 this way over the years.
  7. A high pitched squealing or harsh **ise can be motor bearing wear. This can also be checked for by taking the belt off and running the motor alone.
  8. A k**cking **ise can be a loose tub weight. This would **rmally be worse with heavy loads and would **t be present on spin with ** washing in. This is because the k**cking **ise is caused when the tub (or outer drum) shakes about on spin. Without washing inside the drum the tub doesn't move. A**ther symptom of a loose tub weight is grey concrete dust under the washing machine. Warning: These days most washing machines have plastic tubs and over tightening a tub weight bolt can easily shear the bracket resulting in a new tub being required. Try loctite. Often, once a tub weight has come loose the plastic tub is damaged anyway especially if it isn't caught early e**ugh
  9. Sometimes a badly worn drive belt can cause a surprising amount of **ise. I've even come across some where i was convinced the drum bearings were gone until I took off the belt and spun the drum by hand to find ** **ise.
Posted on Mar 10, 2008
    Genius:
  • 1,665 Answers
Hi have a nice day!
  • 8 more comments
  • Kleanthis Mavropoulos
    Kleanthis Mavropoulos Mar 10, 2008
    Central bearing of your machine seems to be worn.
    Take a look at repair help here
    Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
    NOTE:
    If noise is when changes direction you must inspect the motor driving belt and probably needs replacement.
    Also pay attention at Clutch
    If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician
    Let ’s look inside the washing machine, let ’s carefully see the motor in the washing machine.
    Why should we? It ’s because then you will believe the LG intellowahser DD is so perfect that it will
    last longer.
    Permanent magnet rotor and multi-coiled stator are swapped their place and rotor
    replaces the pulley.
    • Minimum vibration and **ise • ** replacement of BRUSH
    Coil
    Stator
    (Magnetized by current)
    Rotor
    (permanent-magnet)
    Rotating Shaft
    Direct Drive Motor _Without Brush
    For the motor to be rotated, rotor and
    stator should become a magnet so they
    repel each other just like **rth Pole and
    South Pole of a magnet repelling each other.
    In universal motor, rotor and stator are
    coiled and they become magnet by flowing
    electricity.
    What delivers electricity to rotor is a
    BRUSH. Therefore rotor can**t become a
    magnet without BRUSH and it can**t
    rotate. If the Brush wears off MOTOR WILL
    STOP!!
    Rotor is a permanent magnet therefore it needs ** electricity
    and ** BRUSH
    • ** frictional sound • ** replacement of BRUSH
    BLDC Motor _Without Brush
    Coil
    Stator
    Rotor
    (permanent
    magnet)
    Coiled rotor needs electricity to be rotated and BRUSH is there
    to deliver electricity.
    • BRUSH makes frictional sound • BRUSH abrades and needs replacement
    Universal Motor-With Brush
    Coil
    Brush
    Stator
    Rotor
    (permanent
    magnet)
    Before After
    Direct Drive Motor
    • Quiet & Durable System
    • Conventional System
    What is a Brush
    1. Motor without Carbon Brush
    Because the Direct Drive Motor has ** Carbon Brushes, the motor runs like a whisper.
    ** Brush also means ** extra cost for Brush Replacement.
    (Refer to the detail explanation of Brush on the next page)
    2. Direct Drive tech**logy
    The motor drives the drum without a flywheel and a driving belt. There are less wearing parts, so
    the motor is more reliable, silent and efficient.
    See your manual
    Did you check belt's condition?
    Here you see motor coupling assembly. If you are sure that the noise is not generated by all the other reasons (drive belt, bearing, well seated at floor etc) perhaps this coupling is responsible.
    Has your machine been used for a long time?
    Free mebership requiered here to get LG washing machine user manual
    Kleanthis Mavropoulos Mar 11, 2008
    Was user manual helpfull to figure out how noise is caused?
    Kleanthis Mavropoulos Mar 12, 2008
    ok; many times a solution to a problem is very easier than initally seems.
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Lg wm makes loud noise when changing speeds, grinding sound
It sounds as if there is a problem with the tub bearing of the machine, replacing this is a job left to professionals.
Sep 06, 2014 | LG WM2501HWA 4.2 cu. ft. Front Load Steam...
LG direct drive washer makes loud grinding noise
Check presence a stranger subject in drum. Shine the torch and swing the drum.
If rubbish no that necessary to change the bearings.
Nov 12, 2013 | LG Washing Machines
LG front load washer.Will not spin and makes loud grinding noise
what is your model number is then we can get started then to get your unit fixed all redy
Jan 22, 2013 | Washing Machines
Hi I've got Washing Machine LG WD-8023FB front load, and SE or 5E alarm is on and machine is not working. What is that alarm for?
the alarm is indicating that the machine is not working that u should restart it or better still u check the mabual for p[roper operation
Jun 24, 2011 | LG Washing Machines
LG Intellowasher 7kg, Model WD-8074FHB - noisy spin cycle
You are right!
Bearings have to be replaced. Replace with the same type and design. All the bearings connected to the washer center shaft has to be replaced at the same time with new set.
Replace the water seals also connected to this. Check the shaft where the bearing sits, for any abrasions or metal damage.
Check the bearing housing also. While carrying out these repairs check the drive belt also. If needed replace it.
If you are happy with the machine outer body and other aspects repair it and re-use it.
Apr 07, 2010 | Washing Machines
'Grinding noise when drum alternates direction
you have a bearing thats bad on drum or something is stuck between drum
Jun 10, 2009 | LG WD-16115FD Front Load Washer
LG WD-3243RHD Front Load Makes grinding, crackling noise
Check the motor at the bottom of the machine. Also check the timer on the unit to make sure the timer is work
Feb 10, 2009 | LG WM2432H Front Load Washing Machine
Grinding noise
if the tub spins freely with no power on and makes no noise, chances are the problem is coming from the hall sensor (sensor assembly) which is located on the stator. The part costs around 20$ the part number is 6501KW2002A
Sgt 48
Jun 19, 2008 | LG WD-1280FHD Front Load Washer
LG Washing machine
its hard to know without hearing it,is there somthing stuck between the drums try taking the belt off and turning the drum by hand.sorry i cant be of more help
Mar 04, 2008 | Washing Machines
Washing Machines Logo
840 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
