Question about Jabra BT500 Wireless Headset
My Jabra BT500 is on mute. Callers can not hear me. It worked fine at first now nothing.
How do you turn off mute. Perhaps the mic is broken?
  • Anonymous May 17, 2008
    same, when playing online no-one can hear me either, yet on a phone i can be heared
  • Anonymous Mar 19, 2014
    the mute switch died I think. it's perma-muted. Probably have to open it up with a screwdriver
When powered up and in "talk" mode (during a call) hold the volume up and down "bumps" simultaneously. This engages/disengages the headset's mute function.... Hope this helps...
Posted on Jun 17, 2008
Is the rechargeable battery in the Jabra BT500 replaceable?
  • jabra headset battery swap - YouTube www.youtube.com/watch?v=MMLocSWjq8Q
    • BY THEDIECLAN2004
    • 3 MIN
    • 24K VIEWS
    • ADDED 2011-12-10
    Video embedded · jabra headset battery swap theDIEclan2004. Subscribe Subscribed Unsubscribe 15 15. Loading ... Plantronics Pro battery replacement - Duration: 9:15.
  • Jabra BT500 Bluetooth Headset - Newegg.com www.newegg.com/Product/Product.aspx?Item=N82E16826552001
    • 4/5
    • 69 REVIEWS
    Buy Jabra BT500 Bluetooth Headset with fast shipping and top-rated customer service.Once you know, you Newegg!
  • Jabra SPORT Bluetooth Battery Replacement - YouTube www.youtube.com/watch?v=Sm8cSkyTmfA
    • BY GREG PAJAK
    • 2 MIN
    • 27K VIEWS
    • ADDED 2013-09-23
    Video embedded · A quick video showing the ease of replacing the battery in the Jabra Sport bluetooth headphones. Jabra says when it it out of warranty they cannot be ...
  • Jabra BT-350 Disassembly and Repair - Instructables www.instructables.com/id/Jabra-BT-350-Disassembly-and-Repair Intro: Jabra BT-350 Disassembly and Repair. I wooted a few of these dandy devices a while back and they work great but the volume buttons are weak and the solder ...
  • Jan 26, 2016 | Jabra BT500 Wireless Headset
    Cant hear sound record
    Okay well, there can be a few possibilities :
    1) Your microphone is muted. May be you mute it accidentally while you are on phone. Or maybe you've made some changes to your hardware recently but installing some app- all in all just make sure the microphone isn't muted.
    2) Your phone microphone is damaged. In that case you need to get it repaired from a nearby mobile center. If you still have your phone under warranty then you can get it replaced by the company itself.
    One way to check whether your mic is broken or not is try using earphones with a mic. See if the other person is able to hear or not.
    Do try to reboot your phone. That sometimes fixes the problem.
    If that doesn't seem to work,
    Long press the menu button to access "google now" page. Hitting menu again gives settings option. From there, disable voice open for OK google.
    Oct 09, 2015 | Blu Dash Jr Cell Phone
    I'm trying to pair my jabra bt500 with my iPhone 4. I get all the way through the process when I receive the following message: Connection Unsuccessful "Jabra BT500" is not...
    I just had this same problem. I solved it by turning the iPhone Bluetooth off and then back on, after which the pairing (with passcode 0000) worked properly and so does the headset.
    Dec 28, 2010 | Cell Phones
    Other callers cant hear me Sony Ericsson C905
    Try to Pair again. ( Reset)
    or else your mic must be busted.
    Jan 15, 2009 | Jabra T-Mobile Wing / Dash / SDA /...
    Bluetooth help
    When you pair the bluetooth headset default passkey (PIN) should be used as "0000" (4 zeros). for further info you can check the user manual as I attached the link below
    http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT500/Documents/UM/BT500_UM_NA_EN_480.pdf
    Good Luck
    Feb 20, 2008 | Jabra BT500 Wireless Headset
    Jabra bt500
    yeah charge it for 14 hours......and then hold the pair and call at the same time... then repeat the pairing process
    Jan 04, 2008 | Jabra BT500 Wireless Headset
    Cant hear
    I have the same problem. The lights are on, it's paired, and my caller can hear me. but I cannot hear the beep from pressing buttons on the jabra, nor can I hear anything from the phone.
    Oct 31, 2007 | Jabra BT500 Wireless Headset
    Jabra BT500 will not power on or charge
    I would also like to know if you find a fix for this problem. I have the BT500 and it will also not turn on.
    Sep 17, 2007 | Jabra BT500 Wireless Headset
    No sound
    Had the same problem with the BT250v 'connected' to my Nokia 6021. When connected to my notebook, the 250 did produce sound, so decided the Nokia was the problem. Fixed the problem by doing a full reboot of the phone like this:
    Jabra: Turn off the 250
    Phone: Delete the BT connection to the Jabra (in BT settings)
    Phone: Switch off BT
    Phone: Turned off the phone (I've even removed the battery)
    Phone: Turned on the phone
    Phone: Switch on BT
    Jabra: Turn on the 250 for detection
    Phone: Look for audio devices
    Phone: Connect to Jabra
    Problem fixed!
    Sep 02, 2007 | Jabra BT250 Consumer Headset
    Jabra BT500 Wireless Headset Logo
    273 people viewed this question
    Top Jabra Radio Communications Experts
    Jerry Greenberg
    Jerry Greenberg
    Mohammad Nawaid...
    Level 1 Expert
    Michial Gueffroy
    Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
