INSTALLED NEW CARTRIGES AND PRINTER WILL NO RESUME PRINTING
  • maggievalley Mar 09, 2008
    the tapes were removed prior to installation. that is not the problem,  any other suggestions?????????
    Scholar:
  • 45 Answers
Hi maggievalley,
I need you to make absolutely sure that you followed the installation procedure of the cartridges correctly. Some manufacturers put a kind of tape on the cartridge when it ships from their factories to prevent ink from leaking out of the cartridge during transportation. This tape must be removed prior to installing the cartridge in a printer to allow the ink to flow out of the cartridge.
I suggest you remove the cartridges from your printer and reinstall them following the new cartridge installation guidelines of your printer's manufacturer step-by-step.
Hope you find this information helpful in solving the printing problem and thanks for using the FixYa service
Kind regards
Posted on Mar 08, 2008
My printer is ip1600. my problem is, whenever it printing, it wont print on straight line. i done every maintenance available yet the problem still occur. help me.
you have to align the cartridges if you have recently installed new cartridges to do this go to control panel then to printer open your printer properties and there is an option to align cartriges
Dec 02, 2010 | Canon Office Equipment & Supplies
My MP510 was just printing fine then went to rear feed and now all I get is a flashing green and yellow lights
review this to determine your problem.. If all else fails simply unplug your printer wait a minute and plug back in.
Handling Error Messages
When a printer error occurs, the POWER/ERROR lamp flashes.
The number of flashes indicates the type of error that has occurred.
Count the flashes and take the appropriate
action to correct the error.
Number of Flashes
Possible Cause
Try This
Two flashes Printer is out of
paper/Paper does
not feed
Reload paper in the Sheet Feeder or Cassette and press the RESUME/CANCEL
button.
Three flashes Paper jam/Paper
Output Tray is
closed
Clear the jammed paper, reload paper in the printer, then press the RESUME/
CANCEL button. If the Paper Output Tray is closed, open it.
See “Paper Jams” on page 72.
Four flashes Empty ink tank Press the RESUME/CANCEL button to resume printing with an empty ink tank.
Replace it with a new ink tank immediately after the printing. It may damage the
printer if you continue printing with an empty ink tank.
See “Replacing an Ink Tank” on page 42.
Five flashes Print Head not
installed/Print
Head not installed
correctly/Defective
Print Head
Install the Print Head. If the Print Head is already installed, remove the Print Head
and check the electrical contacts for foreign matter, then reinstall.
After reinstalling the Print Head, you may need to realign it.
If this error still remains, the Print Head may be damaged. Contact the Customer
Care Center.
Six flashes Inner Cover is open Close the Inner Cover and press the RESUME/CANCEL button.
Eight flashes Waste ink absorber
almost full
The printer has a built-in waste ink absorber for the ink used during Print Head
Cleaning.
Eight flashes indicates that the waste ink absorber is nearly full.
Press the RESUME/CANCEL button to cancel the error so you can continue printing.
Before the waste ink absorber becomes completely full, contact the Customer Care
Center.
Nine flashes A specified period
of time has elapsed
without receiving a
response from the
digital camera/The
digital camera or
digital video
camcorder
connected is not
compatible with
this printer
Disconnect the camera cable, press the RESUME/CANCEL button and reconnect
the cable.
If the error is still unresolved, there is a possibility that you are using a digital
camera or digital video camcorder that is not supported by this printer. Use a
digital cameras or digital video camcorder compatible with this printer
Mar 29, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Hi,I am experiencing nothing printing on paper even though ink cartridges have been replaced and cleaning has been performed.ink absorber warning appears and says that absorbers are almost full and to push...
your print head is either clogged or damaged, A print head is the unit your ink cartriges sit in. If its a nedw or newer printer (under warranty) you can contact the manufacturer and they will send you a new print head at little to no cost-good luck
Dec 19, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Installed new cartridges in Canon i850 and printer seems as though it is printing but does not grab the paper from paper feeder and gives an error (no number). Instructs me to press REsume button and power...
I changed the USB port that the printer was connected to and... VOILA...works like a charm with the new cartridges installed. Not sure what the problem was as windows recognized the printer and the drivers were correctly installed before the new cartridges even came into the picture.
Nov 25, 2009 | Canon i850 InkJet Photo Printer
Replaced yellow and Magenta to receive replace messages for both.
yes you reset your printer resume button press 2 times then solve your problem inshallah
Aug 12, 2009 | Samsung CLP-510 Laser Printer
Esp3 printer, has new cartriges, printing very fient
Have you tried the maintenance tool - if you open the kodak printer status monitor in your taskbar (next to the clock); at the top right hand side you will see an icon showing crossed hammer and spanner, click on this and run the tools from top down (dont need to do the test page).
If that doesnt work you could try this:-
my new esp3 printer (replaced due to not printing black) came with a suppliment document for action if no black or faint print appears!!:
verify paper is loaded into paper tray then press and hold the Cancel and Copy/Resume buttons simultaneously until the On/Off light flashes -apparently this fixes the no black/faint issue.
hope this helps
Jun 10, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Distorted printing on i560 printer
Double-click print centre icon.
when it opens up, select I560, then click configure.
click I560 then click select
click the down arrow to select test print.
nozzle, alignment etc...
run the tests try resolve the problem.
Hope this helps
Regards
Apr 16, 2009 | Canon BubbleJet i560 InkJet Printer
Canon S400 lite binks 6 times won't print.
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal
Dec 27, 2008 | Canon S400 InkJet Printer
Canon service 6000
Well... here it is :
The POWER Lamp Flashes Orange title-bar.gif An error has occurred in the printer. The number of flashes indicates the type of error, as outlined below. Check the cause and take the appropriate action.
When a printer error occurs, the POWER lamp flashes. The number of flashes indicates the type of error that has occurred. Count the flashes and take the appropriate action to correct the error.
bullet.gif Two flashes: Printer is out of paper /Paper does not feed
Reload paper to the sheet feeder or cassette and press the RESUME button.
bullet.gif Three flashes: Paper jam/Paper output tray is closed
If paper is jammed, remove the jammed paper, reload paper in the printer, and then press the RESUME button. If the paper output tray is closed, open it.
See Paper Jams
bullet.gif Four flashes: Empty ink tank
Press the RESUME button to resume printing with an empty ink tank. Replace it with a new ink tank immediately after the printing. It may damage the printer if you continue printing with an empty ink tank.
bullet.gif Five flashes: Print head not installed/Print head not installed correctly/Print head is defective
Install the Print Head. If the Print Head is already installed, remove the Print Head and check the electrical contacts for foreign matter, then reinstall.
If this error still remains, the Print Head may be damaged. Contact a Canon service representative.
bullet.gif Six flashes: Inner cover error
To print on paper:
Close the inner cover. Then press the RESUME button to start printing.
Do not move or close the inner cover during printing. It may damage the printer.
bullet.gif Seven flashes: The CD-R or DVD-R is not set on the CD-R tray
Reset the CD-R tray feeder with a CD-R tray containing a CD-R or DVD-R, and then press the RESUME button. Printing will resume.
This function only works with models that support CD-R printing.
bullet.gif Eight flashes: Waste ink absorber almost full
The printer has a built-in waste ink absorber for the ink used during print head cleaning. Eight flashes indicates that the waste ink absorber is nearly full. Press the RESUME button to cancel the error so you can continue printing. Before the waste ink absorber becomes completely full, contact a Canon service representative.
Important
Canon recommends that you call for service as soon as this error occurs. Once the waste ink absorber becomes completely full, printing will no longer be possible.
bullet.gif Nine flashes: A specified period of time has lapsed without receiving no response from the digital camera / The digital camera or digital video camcorder connected is not compatible with this printer
Disconnect the camera cable, press the printer's RESUME button and reconnect the cable.
If the error is still not solved, there is a possibility that you are using a digital camera or digital video camcorder that is not supported by this printer. Use a digital camera or digital video camcorder compatible with this printer.
bullet.gif Ten Flashes: Cannot print on both sides of the page
The size of paper may not be compatible with automatic duplex printing. For information on the size of paper compatible with auto duplex printing, see "Automatically Printing on Both Sides of the Page." Pressing the RESUME button will discharge the paper, and restart printing from the front side of the next paper. The reverse side will not be printed when an error occurs.
bullet.gif Eleven flashes: Cannot perform automatic print head alignment correctly
Possible causes are as follows:
bullet_s.gif A4 or Letter-sized paper is not loaded on the sheet feeder.
bullet_s.gif Ink has run out or ink tanks are not installed correctly.
See Ensure that the ink tank is installed properly.
bullet_s.gif Ink level is low.
bullet_s.gif Print Head nozzles are clogged.
Press the RESUME button.
For information on how to print a nozzle check pattern, see "Printing the Nozzle Check Pattern."
bullet_s.gif The paper output slot has been exposed to a strong light source preventing correct print head alignment.
Press the RESUME button to resolve the error. Align the printer so the paper output slot will not be exposed directly to a strong light source.
After carrying out the above measures, if the problem continues after aligning the print head again, press the RESUME button to resolve the error, and then perform manual print head alignment. For details on manual print head alignment, see "Aligning the Print Head."
bullet.gif POWER lamp flashes alternate green and orange:
An error that requires contacting a Canon service representative may have occurred.
Disconnect the printer cable from the printer, and then turn the printer off and unplug the printer from the power supply. Plug the printer back in and turn the printer back on after leaving it for a while.
If the problem remains, contact a Canon service representative.
Apr 21, 2008 | Canon PIXMA iP1600 Printer
Computers & Internet Logo
107 people viewed this question
David Payne
David Payne
