Question about Motorola Mobility RAZR V3
Replaced Flip-Hinge; now can't hear incoming calls
So uhm, the side hinge on my phone fell out when I first got it. That was a year or so ago, I bought a replacement hinge and haven't had any problems since.
...until today. Now, I noticed the hinge was out and went to put it back in. After replacing it, I thought everything was fine. Then my phone rang, and I answered it but I couldn't hear any sound. The other person could hear me talking, the phone still makes other sounds, I just can't hear incoming calls I guess.
What should I do? I'm trying to take the hinge out, assuming maybe I slipped it in wrong (or something..?) but I have no idea how to take it out. Any help is much appreciated.
  • 1 more comment
  • HELP_ME_PLEA May 26, 2008
    I'm having the exact same problem, except when my left hinge cover fell out, a piece of it was broken off. It was not stepped on, nor did it fall on something hard, so I don't understand how it broke. Anyway, even though I've put it back in its place, I can no longer hear incoming or outgoing calls unless I turn on the speaker phone. How do I fix this?
  • Anonymous May 26, 2008
    I have the same problem. Speaker phone works fine, can't hear anything on the regular ear piece.
  • HELP_ME_PLEA May 11, 2010
    ^^ Thanks for a reply, but how does one make sure the speaker and cable ribbon are in their correct slots? I've never taken this phone apart before.
    Also, if the left hinge cover falls out, is should the screen be loose on the left side? The screen still works with no resolution problems, but I just can't hear anything not coming from the speaker at the bottom of the phone.
    Brigadier General:
  • 7,752 Answers
Check and see if the speaker located to the bottom of the main-board is place back in the correct slot if not put it in or replaced it....replaced also the cable/ribbon that is located on the lcd.
Posted on Mar 21, 2008
One side of oven door hinge won't fit back in when putting door back on after cleaning
when you insert the hinges back into place flip the small lock tab at the hinge pin the locks the hinge for removal
Oct 19, 2017 | Indesit KP9508EXG Dual Fuel (Electric and...
My side by side refrigerator door swings open (somewhat out of control). It appears that the door stop is no longer working How can I fix this?
There is a self closer stop mechanism under the door between the door and the hinge, The door must be removed by removing the top hinge and lifting off the lower hinge flip the door and you will see a plastic piece which is probably broken there is also a piece on the hinge . Both should be replaced
Feb 27, 2011 | GE Refrigerators
I HAVE CHANGED BROKEN FLAP 2 MONTHS AGO BUT THE FUNCTION OF OPERATE SYSTEM AFTER CLOSE THE FLAP CANT WORK PROPERLY, SO PLEASE TELL ME WHAT CAN I DO?
Was the flap changed by a techician ?
I have played with my 1200 and thus
know the flap hinge area has two special aspects :
(a) embedded-into-hinge-on-one-side, a spring loaded mechanism, for the firm open-close action.
(b) a small circular magnet embedded within the hinge framework (this magnet working from the right location should be essential to trigger the answer-when-flip-open or disconnect-when-flip-is-closed systems).
So your problem could be due to one or both of these things not being (re)installed correctly.
Good Luck.
fixya[at]technife[dot]com
Nov 05, 2010 | Motorola Mobility A1200
The washer/spacer on the bottom of my right side door fell off, and the door now rubs when I open it. Can this be replaced?
Yes , order the parts by model number , then remove the 3 top screws (hinge) , then lift door up and off bottom hinge .
Jul 16, 2009 | GE GSS25JFM Side by Side Refrigerator
I have a 1998 Mercury Villager, and have repeatedly replaced the hinge to the sliding doors glass window. Could you tell em the correct name of this part, as I need to call around to find this part. This...
These hinges seldom fail. Must be something wrong with the lock or other hinge. It's called "Body Side Door Hinge" go here for villager help. see files and photos. http://autos.groups.yahoo.com/group/villagerquest/ ebay has parts cheap. so does car-part.com. See page with asterisk for lowest price. New parts tascafordparts.com
Jun 10, 2009 | 1998 Mercury Villager
My Cell Phone Is Blank!
I had the same problem with my Razr V3, it was way out of warranty so I had a go at fixing it, and it wasn't too hard.
(I had the blank/off screen problem but the rest of the phone seemed functional)
I took off the rubber pegs on the inside of the flip-screen to reveal the screws. They need a T5 screwdriver head (tiny star shape). I removed all 4 from that side.
I then 'forced' the back casing of the flip-screen off (side with camera). The key is to open the end furthest from the hinge, then it will simply lift off.
(I read a complicated guide suggesting that you use something like a creditcard to slide it off, I'd give that a go first as I did do some scratch damage when using the screwdriver)
Once open (might be dusty), there was a thin 'belt' coming through from the main part of the handset (by the hinge), it has a black square on it. This was simply flailing about, so I inserted it securely back into it's socket (the only place it can go, same shape)
[I guess thats the power supply to the screen]
I would re-attach the back panel hinge end first (camera end).
Then simply screw it back together.
The T5 screwdriver isn't everyday stuff, most sets only go down to T10 it seems. Maybe if you have family friend who fixes things you could borrow one. Apparently those types of screws are used somewhere in cars so maybe a mechanic or car-person?
(I was a bit narrow-minded and frantically bought a little set for £5)
Hope that helps.
Jan 06, 2009 | Motorola Mobility RAZR V3
Whirlpool LSB6300PW2 Won't Agitate or Spin
if you lift andclose the lid do you hear "clicking" noise??? i bet not. simple repair, lift the lid and with a hollow shafted screwdriver(1/4in nutdriver or similliar hollow shaft implement)you fell with your hand the bottom half of the left side lid hinge. as you open and close the lid you can fell the opposing end of hinge under the top no need to dissasemble you can fell it right there. when you find it simply slip the hollow ended shaft over the hinge and apply pressure towardds the rear of unit.While doing this the top will want to close( your pushing against the hinge).. after appling slight pressure youll bend it slightly, enough to activet the lid switch mounted to the rear of the main lid assy.
Nov 13, 2008 | Whirlpool LSB6300PW Top Load Washer
Top flip section of phone broken,
Yes you can do this but it is safe to take the phone to a mobile repair shop and have them repair it for you.
Aug 14, 2008 | Samsung SCH-u740 Cellular Phone
SCREEN
the hinge is the middle of the phone where the top and bottom of the phone meet think of it this way if u close ur razor the top of the phone is the hinge its the things where it has two shiney cirlces on each sides hope that advice helps thanx.
May 19, 2008 | Motorola Mobility RAZR V3
Motorola razr v3: hinge on left side fell out
I know what you r talking about because the hinge on my phone is loos, it didn't fall off yet. I have the blue razr but it's with t-mobile and it's unlocked so they wont fix it. T-Mobile is very helpful but u should call moterola and they will fix it 4 u. And if they give u a hard time talk to the manager.
Jun 15, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
143 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
