Sirius pc tower and trust speakers. cant get eny sound
Cant find a place to connect my p.c speakers to plug into.
Did a system recovery on my e-machine can't restore my network adapter,multimedia and ,soundcard.
Posted on Mar 08, 2008
Equipment is Alpine CD9855, and Sirius KCASC100 interface. When listening to Sirius only, the left speaker crackles then goes out. Whe listenting to stero, CD and IPOD, the speaker is fine. Have the...
It sounds like their is a un stable connection that loosens after a wail. Is the unit securely mounted. I would all so check the ground and power connection. A improper ground bolt can cause a situation like this.
Jul 28, 2011 | Car Audio & Video
Where do I connect the speakers to the monitor. I have a Flatron L1922P monitor. I ordered 2.0 USB Multimedia speakers that come with a 3.5mm stereo plug and USB plug. I must not being doing something...
Your speakers do not plug into your monitor. Your speakers should be connected to a USB slot on your PC tower and the 3.5mm stereo plug should be put into the green stereo jack on your PC tower. If your audio jacks on your PC are not colour coded, then you should look for the jack which has a picture of a set of earphones over them.
Depending on your speakers, you may or may not be required to keep the stereo plug connected in order to get sound. Some models transmit model over the USB connection and others just use the USB connection as a way to supply power to the speakers and need the stereo plug to be connected in order to have sound. I suggest trying both.
Mar 25, 2011 | LG L1922P 19" LCD Monitor
I have connected the speakers to the red jack plug at the back of the tower but no sound
sorry sir, speakers must be connected to the green jack. red jack is for microphone. Let me know how you go either way....cheers from narayanan
Dec 04, 2010 | Sony VAIO PCV-RS320 PC Desktop
I cannot get any sound from my speakers or the monitor speakers. I have plugged the green cable to the monitor and to the green connector on the tower with no luck. I have also plugged the extra speaker...
It sound like you have connected them correctly however unless they are multi-channel speakers you should only have to connect the green cable. Check to see if the volume control on your speakers/monitor and also OS are turned up and not on mute and also check to see that you have sound drivers installed for your sound device/card.
Oct 23, 2010 | Acer Aopen MS698 Computer Speakers
Harman-Kardon HK695-01 Speakers Connection Quesion
According to the manual
http://tv.manualsonline.com/mdownloads/14ae515f-03bc-a2d4-8940-672bfa19f017.pdf
leave the black connector unconnected.
Hope that helps.
Oct 02, 2009 | Harman Kardon HK695 Computer Speakers
When i place my sirius radio into the base, driver side speaker goes off and on but most time i only hear the passanger side speaker working, I had my sirius sportster for 3 years. I think it is the base,...
when you listen to a cd or the normal radio does the drivers side speaker work? if it does then it is most likely the base is the problem. you might have a loose connection in your car. or the speaker is blow.
Jan 01, 2009 | Sirius Satellite Radio Sirius Sportster...
Speaker hook up
Shari,
It is my hope that I can help. This applies to the type of sound card on your PC.
- If you have a 2-channel sound card: Select 2 on the source selector switch on the subwoofer. Connect the green plug from the audio input cable to tyhe front jack on your PC sound card. With this input setting, your speakers will upmix the 4-channel signal and create a center signal for your speakers.
- If you have a 4-channel sound card: Select '4' on the source selector switch on the subwoofer. Connect the colored jacks on the audio input cable to the jacks on your PC sound card, making sure to match the colors.
- If you have a '6'-channel sound card: Select '5-1' on the source selector switch on the subwoofer. Connect the colored jacks on the audio input cable to the jacks on your PC sound card, making sure to match the colors.
Your sound card is located on the back of your PC Tower.
Good luck
Jun 24, 2008 | Logitech Z-5300 Computer Speakers
Stiletto 10 is not reconized by My Sirius Studio
Firmware version was too old to be reconized by new version of My Sirius Studio (MSS). Put Stiletto into recovery mode, pulled the latest driver from sirius, updated, which allowed MSS to see the unit.
Mar 27, 2008 | Sirius STILETTO 100 MP3 Player
Cant get sound from my pc
Please spell the name of the speakers again, I have no listing...accordianman
Mar 08, 2008 | RaidMax SIRIUS (ATX-701WS) ATX Mid-Tower...
No Sound
Make sure you plug into the GREEN speaker port on the PC.If using a digital connection,try going back to analog.The difference is almost non-existent,and much less hassle.
Oct 21, 2007 | Creative Labs I-Trigue 2.1 3300 Computer...
47 people viewed this question
 Grubhead
Grubhead
