Re: my xbv410 is stuck on progressive scan mode. I
Press the set up button on the remote...the word "set up" should appear on the unit. then press and hold the stop button for 5 seconds...problem solved.
Thanks very much. This information site saved me money and made my night. You guys are great.Thanks very much. This information site saved me money and made my night. You guys are great.
You can't post conmments that contain an email address.
1) Remove any DVD that may be inside 2) Press AND Hold Stop Button (on front of Player) for 5 or more seconds 3) All Done - This will have reset player back to Interlaced Mode and you can now see your DVD!
If you have not already seen this or done it - it worked for us:
On page 18 of the user manual under Progressive scan there is a Caution which says - If you set Progressive Scan to On in error, you must reset the unit. 1) Remove any disc from the unit and close the disc tray. See that "dISC " is displayed on the display window. 2) Press STOP (9) and hold it for more than five seconds before releasing it. The video output will be restored to the standard setting and a picture once again be visible on a conventional analog TV or monitor.
that means it is stuck on progressive scan. If your tv is not able to handle progressive scan, you need to change it back or reset the player.
The DVD player may be set to Progressive Scan Mode. You will need to change it to Video Mode by using the remote control. Point the remote control directly at the DVD player, and then press the PSCAN button 2-3 times. If you are still encountering problems with the DVD player, reset the unit back to the default setting.
To Reset,
Make sure you do not have a disk in the tray. Using the DVD player remote control:
1) Press the “Setup” button.
2) On the “Down” arrow, press it three times.
3) On the “Right’ arrow, press it once.
4) On the “Down” arrow, press it three times.
5) On the “Right” arrow, press it once, then press “Enter”.
6) Press the Setup button.
*The default setting will take affect as soon as you press the setup button (step 6).
Hope it helps..please rate!
I have the Zenith XBV410 (combo dvd/vcr). I cleaned the lens using the Maxell Lens cleaner kit but nothing happened. Then I ran the Progressive Scan Mode and that seemed to do the trick. Word of caution: Progressive Scam Mode is difficult to turn off so would recommend you remove dvd from player, then press and hold the stop button for a min of 5 seconds up until whatever it takes to disablel PSM (Progressive Scan Mode)
Check for video out in the dvd setup menu, and set it for composite, It may be set for component.
another thing to try is setting the the progressive scan option off in the setup menu, you wont benefit from it, but at least it might work. if you already tried using the prog scan and your T.V isnt compatible, you'll need to reset. press stop to stop any playing disc, and press stop again holding it for 5 seconds to reset the system.
Hold the stop button for about 10 seconds. The other thing to do is move the video out cable at the back of the DVD to one of the component outs (there are three of them one for each color rgb) you will be able to read the menu again. turn off progressive scan and reconnect the video cable to dvd out
Stuck in Progressive Scan Mode??? Remove the disc(s) from the changer, make sure TV is on Blue Screen...should say "Progressive Scan Mode".......Simply press and hold the stop button for 5-10 seconds and it will reset.
Remove any discs from the unit. Make sure your tv is on the blue screen. It should say "Progressive Scan Mode"....After removing the disc(s) from the disc changer, close the changer, press and hold the stop button on the unit, not the remote, for 5 seconds or more and it will reset to normal playing mode. Progressive Scan is typically only for TVs that use Progressive Scan....most normal TVs do not use progressive scan mode. Hope this helps...It worked for me!!!!
