Microsoft Windows? Vista Home Premium Edition Upgrade Version for PC (1 Computers) (66I-00021) Logo
Posted on Mar 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Downloaded infected program
I downloaded something and an infected program was atttached. Windows shuts down on startup.
Tom Carson
Level 3:
  • Master 3,083 Answers
  • Posted on Mar 13, 2010
Tom Carson
Master
Level 3:
Answers
3083
Questions
0
Helped
683961
Points
8555
You will have to push F2 or F12 when you boot up, and get into the Startup menu. From there, you will have to restore your system to a previous date (if you're running XP or Windows 7, you can do this). Otherwise, your bios may be infected and have to be reflashed, but a computer shop will have to help you with that, unless you're pretty technical.
Delete freeze
Depress the power button for a few seconds till the computer turns off. Wait a few seconds and restart.
Where does it freeze, during startup, or once within Windows? If you make it somewhere into the Windows operating system, restart, and during startup, peck on F8 key till you get to the B/W Startup options. Cursor down to "Safe Mode with Networking", and press the Enter key. If it makes it to Safe Mode, use "System Restore" (SR) to back up to a date before the problem occurred. If SR isn't available, or doesn't work, enter Safe Mode again, use your IE, Firefox, Google Chrome, or Opera browser to go to www.download.com. In the right-hand column of Most Popular Downloads, you'll find Malwarebytes. Download and run that program to see if the problem came from a malware infection. Follow the instructions to scan, and afterwards to remove the infections, then restart the computer.
tip
How To Tip #1: Disabling your Startup Items
Is your computer reacting slowly when it starts up and shuts down? The cause of this is likely due to the fact that many people have an enormous amount of programs that launch when Windows starts up. Hence when you boot into the Operating System, Windows wants to load each program while you just want to do something else.
The same goes when trying to shut down your computer. Windows needs to close all open programs and services in order to shut down. The less you have running, the quicker it is to start up and shut down. Additionally, you may also notice a sharp increase in your computer's performance since it won't be using as much of the computer's resources with all those background processes running.
If you have a ton of programs that are loading during startup, it's very easy to disable these. This won't uninstall that program, it just won't start at the same time as Windows. It will still be on your hard drive and ready to work when you want to open it.
To stop these programs from starting up with Windows, simply click on Start, type in MSCONFIG, then hit Enter. Remove the check mark next to Load Startup Items and then reboot. That's all there is to it.
on Feb 25, 2011 • Computers & Internet
tip
How To Remove A Virus From Your Computer
Requirements: On an uninfected PC connected to the Internet, download the following programs to a thumbdrive. We will need this to fix the infected computer.
Instructions:
  1. Shut down the computer as soon as you realize there is a problem. Pop-ups, program errors, dll errors, fake Anti-Virus scanners, and similar are signs there is a problem. Shut down the computer normally, or hold the power button in until the computer shuts off.
  2. Power on the computer, and hit F8 before the Windows Startup screen appears. Select Safe Mode.
  3. Login if asked to, if not select Yes to continue.
  4. Click on the Start menu, select Run, type msconfig and press Ok, or type msconfig into the Start menu search box and press Enter.
  5. Under the General tab, select Diagnostic Startup. Press Apply.
  6. Under the Services tab, check the Hide All Microsoft Services box, and uncheck any services you don't recognize in the window.
  7. Under the Startup tab, select Disable All. Press Apply and Ok.
  8. Don't restart the computer yet.
  9. The System Restore Utility backs up selected files automatically to the Restore folder. Quite often are infected files stored there as backup files, and many Virus Scanners are unable to delete these files. If you suspect your computer may be infected, it is recommended that you disable the System Restore Utility to remove the infected files from the Restore folder.Select your OS for directions on how to disable the System Restore Utility - XP, Vista, 7
  10. While in Safe Mode, insert your USB thumbdrive and open it in My Computer.
  11. Open Combofix.exe, select Ok when it asks. Let Combofix scan and remove any infections it finds. It should restart the computer when it is done. When it restarts, boot up into Windows normally.
  12. Login if asked to, open your thumbdrive in My Computer again, and run Combofix.exe once more.
  13. Open up SmitFraudFix.exe from your thumbdrive. Press any key to continue when asked. Type 2, and press enter. When the scan is complete, restart your computer.
  14. If you had a fake Anti-Virus Scanner infection, open up Remove Fake Antivirus.exe from your thumbdrive. Press Start, and press Yes. When the scan and removal is Complete, restart the computer again.
  15. Install Microsoft Security Essentials, or your choice of Anti-Virus Software when the computer returns back to the desktop.
  16. Restart if asked to, and when the computer restarts, run a Full Scan in Microsoft Security Essentials.
1helpful
2answers
Running in safe mode as normal start up is really slow or does not load.
Follow this trick to fix infected Laptop:
Disable Unwanted Programs from Running at Windows Startup
Running too many programs at the Windows startup reduces the system performance. To speed up Windows 7, you have to disable the unwanted third-party programs from running at Windows startup.
  • Click Start ' Type MsConfig and press ENTER
  • Click Startup tab.
  • Uncheck the entries of the programs that you do not wish to run at system startup.
  • Click Apply.
  • Do the same for the entries in the Services tab.
  • Click Apply ' OK.
  • Restart the computer when prompted.
To fix this problem instantly use PCFresher system utility.
I cant use my camera because its being used but another app... but i have no idea how to locate or close the app
I would suspect it in a startup program, say CyberLink. It's set to start at Windows Startup. Open the webcam software for your laptop and disable Start at Windows, OR download CCLEANER freeware at : http://www.filehippo.com/download_ccleaner/ .This is a good program to learn to use. You can clean the junk from your machine and in the TOOLS section, STARTUP, look for your webcam startup program, disable it. Disable ALL unnessary startup programs to speed boot and shut downs.
1helpful
2answers
Shut down
Possible corrupt operating system. The cause of corrupt operating system is Windows file corrupted or virus infected Windows.
Solution corrupt Windows files:
1. START - All Programs - Accessories - System Tools - System Recovery Options - System Restore (restore to the date when the OS is still normal)
2. START - All Programs - Accessories - System Tools - System Recovery Options - System Image Recovery (restore using a backup system that you created)
Solution files corrupted due to virus infected windows
Update anti-virus and virus scan (if the virus is detected, the primary action = repair, secondary action = quarantine). Then repair the operating system with System Restore or System Recovery Options.
Note:
If the operating system infected with virus (virus infected not long ago), the best solution is to use System Restore. Restore to a date when the windows are still normal.
2answers
Toshiba satellite A70-KL1 notebook shuts down
Scan the Computer using any latest updated anti virus program for any potential threat.
If the computer is not infected by any virus or trojan then you may also try performing System restore to the time when the Computer worked normally.
If the Computer keeps shutting down randomly after turning ON then the Power Supply Unit in the Notebook requires service.
2answers
Startup main error problem
Depending on the operating system your running, click on the start button in the bottom left or the vista icon, then either click on "RUN" or in the search box type MSCONFIG and press enter.
Click on the startup tab and then clickon the disable all button. Then click on apply and then okay and then let the computer restart.
After it restarts if the error message stops appearing then you know its something that is starting up when windows boots.
Go back into msconfig and then you can enable any of the programs that you want to startup instead of the ones that you don't.
3helpful
2answers
Windows shutting down
You should probably use something like CCleaner (www.ccleaner.com) to clean up your temp files. Also, uninstall any old software or stuff you no longer use. Run a scan for viruses and/or malware to make sure you are not infected.
2answers
Geetting an Error : Rundll32.exe
RUNDLL32 is the Microsoft Windows program that loads DLLs into memory so
that they can be used by specific programs or by Windows. This behavior
could be associated with a programs not responding properly or is associated
with spyware programs and viruses. Anti-virus software and firewalls do not
fully protect your system against the majority of spyware and privacy
threats. Spyware is commonly bundled with software downloads, attached to
e-mails, or transmitted through networks so it can appear to be legitimate
software, but once installed it can be nearly impossible to detect and
remove without the help of a dedicated spyware removal tool such as:
Ad-Aware 6.0 (build 6.181)
http://www.lavasoftusa.com
SpyBot 1.3
http://www.safer-networking.org/
SpyWare Blaster
http://www.javacoolsoftware.com/spywareblaster.html/
HiJackThis
http://www.spychecker.com/program/hijackthis.html
Please make sure that you download the updates for each of these programs to
ensure complete detection of known spyware programs. Although nothing is
absolute in removing spyware and keeping it off, downloading and executing
the programs above can dramically decrease future infections.
Also please utilize free virus scans from the following sites:
Trend Micro
http://www.trend.com
Bit Defender
http://www.bitdefender.com
Panda
http://www.pandasoftware.com/
McAfee
http://www.vil.nai.com/vil/stinger
After Spyware / Adware is remove, you may get an error finding files on
reboot
After you use anyone of these programs (with the exception of HiJackThis)
you may receive an error of some sort after rebooting your system. This is
pretty common. Many spyware programs add themselves in the Startup location
and execute when Windows boots. If you recieve an error when rebooting after
removing spyware, do not panic. This is more than likely a startup remnant
trying to access the spyware program that is no longer on your computer.
HiJackThis is a great utility to find and remove these startup remnants.
However, there is a less technical way of removing these items:
(1) Click START to RUN and type: msconfig
(2) Select the STARTUP tab
(3) Uncheck the file that pertained to the startup error message you
received
(4) Click APPLY and OK
(5) Reboot your system
If this fails to fix the startup error message after reboot, there are still
options:
(1) Navigate to C:\Documents and Settings\All Users\Start
Menu\Programs\Startup
(2) Delete the icon that pertained to the startup error message you received
(3) Navigate to C:\Documents and Settings\username\Start
(4) Delete the icon that pertained to the startup error message you received
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
