Question about Dishwashers
Matag dishwasher reassemby prolem
I have a Matag Model# MDB4100AWB dishwasher.
I removed the spray arm to clean out clogged jets.
Upon reassembly I can not get the thread started on the spray arm keeper cap.
Is there a trick?
Please help.
Thanks Jason
  • 247 Answers
Try turning it the other way.
Some of these things have left hand threads (as in "you have to do it up to get it off") so they won't unscrew themselves in use - and this is often made more confusing by the fact that you're trying to screw something on towards you.
A.
Posted on Mar 08, 2008
Have a Maytag Model MDB4100AWB and the top wash arm needs cleaning but I'm not sure how to take the nut off without breaking it. What's the method of removing it? Thanks JB
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Mar 20, 2011 | Maytag 24 in. MDB4100 Built-in Dishwasher
I have maytag jet clean quiet plus II model mbd6000aww. The jets are not spinning and the water is not spraying. I was hoping to get some DIY assistance. Thank you. Jennifer
The most common thing I've seen causing this is when the holes in the spray arms ore clogged. Take the spray arms off and check the holes carefully for debris and clean out whatever you find.
Feb 14, 2011 | Maytag Dishwashers
It is not cleaning the dishes leaving grit and hard stains that I cant get off een hand washing (use same soap Ive used in old dishwasher) seems to not have alot of water flow either
The spray arms could possible be clogged or blocked with debris that wasn't chopped and removed by the filtration system. You can easily remove the spray arms (upper and lower if your model has both) and flush them under the faucet. I have sometimes had to use tweezers to remove bits of paper, plastic or even bone from the jets. This would improve the water flow and give the jets the strength to really "squirt" your dishes!
Nov 15, 2010 | Frigidaire 24 in. FDB635RF Built-in...
White film on glasses. Cannot find solution,
Check water quality. clean the drain filter in the machine. Check spray arm spray jet holes. Clean if clogged.
If you suspect salt chamber try removing all the salt by flushing with water externally. Refill with fresh salt.
Jul 08, 2010 | Servis 23 in. M4306 Free-standing...
Dishes do not come out clean. It runs thru the whole cycle and dishes are hot and steamy but not clean. It seems like there must not be water coming out of the jets to scrub? How do I fix/ what do I...
My first guess is to check the spray arms are not blocked from spinning by a large plate or utensil and /or the spray arm orfices are clogged. Removal of the spray arm should be fairly simple and run water through the center of the arm and see if it comes out the jets.
Jun 14, 2010 | LG LDF6810 Built-in Dishwasher
Sprayer is clogged.
REMOVE SPRAY ARMS AND REMOVE DEBRIS. THEN REASSEMBLE REMEMBER THE ORDER OF PARTS REMOVABLE.
Feb 26, 2010 | Dishwashers
Dishwasher-bottom arm not spraying
The spray arms can usually be removed by unscrewing (clockwise or counter clockwise depending on brand and model), or squeezing a retainer to release the arm. Before removing the spray arm, place the spray arms (all) in a specific position and activate the dishwasher for a few seconds with wash action. Then examine the position of the spray arms to determine if there was movement from the spray arms. If not, then the spray arm(s) are probably clogged and restricting water flow (which makes them turn). Make certain that you are positioning the plates, glasses, etc. in the dishwasher so that they have access to the water. If still no luck, contact an appliance service company.
Feb 20, 2010 | Jade RJDW2470A Free-standing Dishwasher
If the lower and upper spray arms do not turn what could be the problem? I have a MDB4100AWB and I of course have hard water in our area and wondering what is causing the spray arms to turn.
could be the plastic shaft extension that screws onto the motor shaft to drive the pump. The threads on the plastic extension would sometimes get stripped out so that even though the motor is running, it isn't driving the pump mechanism. Assuming the dishwasher is filling with water and motor is running during the wash cycle. also check spray arm openings to make sure they aren't plugged up.
Jan 24, 2010 | Maytag 24 in. MDB4100 Built-in Dishwasher
The top wash arm does not move on my Kenmore Dishwasher model #66515894100. How can I fix this??
Not familiar with this specific model, but I had a similar problem where the water jet slots in the dishwasher's top spray arm were blocked by food debris. The filters were nylon and had started to disintegrate, and when water was recirculated debris was pumped round & blocked the jets. Suggest check your filters are ok/seating properly & then check the jets are not clogged. My spray arm came off easily to enable me to clean it out.
Aug 24, 2008 | Dishwashers
How to remove Sprayer Arms
metal sleeves at the end of the lower spray arm?? dont remove them they only protect from hitting against heate and melting. should be a center thumbscrew in spray arm loosen that nut and should come right out, pokin with wire or toothpik willwill clear joles but you gotta remoe the debris from the arm other wise first run will shoot right back nto holes
Feb 22, 2008 | Jet Tech Systems STEALTH Dishwasher
Dishwashers Logo
175 people viewed this question
Top Dishwashers Experts
